Everything posted by LJP
Family duties took longer than expected. The false stern panel also took longer than expected. To get the false stern panel to fit within the sternwheel braces, I needed to deconstruct part of that assembly. I prepared a cardboard mockup of what the panel would look like and then built the panel. I used dry erase lettering for the boat name and home port. The interior panel was white for the boiler deck although the panel is only currently at partial height. The main deck interior panel is painted yellow at the top and with a grey bottom. This is the colour scheme that I noted at the Dawson City boat graveyard but also what was used on S S Moyie. My intent is to leave the main deck panels off on the port boiler and engine rooms so you can see the interior boat detail. I am not certain if I will also leave the port panels off on the boiler deck to allow visual access to the saloons and staterooms. I have lots of time before that needs to be decided. Next step is to build the crew quarters in the engine room.
It will be hard to see when completed, but this is what the pillow block looks like. Still needs a grease cup/oiler. I tried to leave the keys where you typically would find them as they were used to tighten and true up the sternwheel. This is a temporary setup of the sternwheel with the starboard pitman connected to the crosshead by the engine. Lots still needs to be done. On this side, the engine piston is all the way forward so the crank is horizontal. The other side, when completed, the engine piston will be at exactly 50% compression- so the crank will be vertical. Again, this arrangement was used to keep the engines from locking up the sternwheel. Keith Black, I used the ArcherTransfers.com transfers that you told me about on the pitmans. These are nearly impossible to see but the rivets (sorry wefalck, not nuts & bolts!) are resin but attach just like a decal. Tiny but easy to apply. I still need to complete the port side, add the oilers, trim parts, paint, &c. I will pull this entire assembly off so I can work on the rest of the engine room first. I wanted to get this out now, although incomplete, because I have family duties that will keep me from working on the model for the next few weeks.
wefalck, In re the German gentleman, I am not certain if I am more amazed that he made several feathered sidewheels in brass, or that he did in in 1:100. Incredible! Cathead, Thanks! In our model boat club, we had one member a few years ago who used CAD and a laser cutter to do the wheels. Recently, another member drew and 3-D printed the entire sternwheel for the Delta Queen. The 3-D is ridiculously detailed. LJP
Source: WikiMedia Commons Hi Keith, Sorry that I was not clear in my definition. My concept of a feathered wheel is where the buckets would adjust as they went around. It was proposed that the buckets were more efficient in pushing the water. As you can see, this would be an absolute horror story to try and recreate in a model. LJP
KeithBlack, Thanks much. Like your built but the scale is something else! wefalck, I am very happy the buckets were not feathered, this was bad enough. I had seen those type buckets on sidewheelers but do not recall seeing them on sternwheelers. KeithAug, Thanks much. I have found that the research is easier than my building abilities. I have tried to make it as accurate as possible, but there is always room for interpretation and "creative license". John, I appreciate your support from Down Under. You have a beautiful country and love Sydney. LJP
The sternwheel was constructed the same as with the Thistle. I used the same template for the paddlewheel. I inserted the template in a plastic sleeve and then taped the arms down over the flange and the circle. This is what one of the paddlewheels looks like during construction. There are lots of parts and pieces in the sternwheel construction. It is hard to see, but the shaft is K&S hexagonal brass with a small round dowel insert. And the final construct looks like this. A considerable amount of time was spent in order to get to this point. Now I need to spend time on the cylinder timbers, braces, and pillow blocks before I can add the cranks to the pitman bar. After I complete that I will set it aside. I want to work on the engine room before I affix the cylinder timbers and sternwheel assembly.
In re stoves. Later steamboats , like S. S. Moyie, had radiators in the pilot house. Earlier versions had steam pipes that went back and forth to achieve the same result. You can also look for a chimney in the pilot house roof. Love your build, LJP
- 732 replies
- Lula
- sternwheeler
Keith, Thanks for your comments! Much easier at 1:64 versus your Lula scale. wefalck, Love your idea on boiler plating using aluminum and a ponce wheel. I will use on my next boat. That will really improve the skin on the boiler. You are correct on the boiler end. These were bolts and not rivets. I cheated on using what looked like rivets instead of trying to recreate bolts. The upper were bolted across the length of the boiler, while the lower were attached to the internal chimney. Not certain if that is the correct term but there was an internal open area and "chimney" at the back of a Scotch marine boiler. I used a generic Western steamboat poppet engine on JHC. These seemed simpler than the Corliss, even though the later Thistle my have had a Corliss. Again, Corliss may have been a generic name rathe than the manufacturer or the patent. Some Corliss' were really different from the Western engines. Two views of a type of Corliss is below. Thanks all. LJP
There are two differing sources for the J. H. Crawford engines. 1. Local 1894 newspaper accounts list the engines as being constructed by J. A. Barnes of Oshkosh. The cylinders were recorded as 13 by 50. 2. The Milwaukee Public Library, Great Lakes Marine Collection, listed the registered engines as Corliss condensing engines, with the cylinders noted as 20 by 42. Corliss was a local manufacturer located south of Milwaukee and close to Kenosha. The boat was listed on the sheet under Thistle and not J. H. Crawford. J. H. Crawford was never federally registered - as it was supposed to have been. The subsequent Thistle was registered finally in 1900. In fact, most Fox Wisconsin Waterway boats ignored registration until caught and threatened by the federal government. That being said, neither dimensions are really that different at 1:64 scale. Likewise, Corliss made poppet valve engines along with a myriad of other types. It is possible but unlikely that JHC/Thistle would have had its engines changed out in the 1899 hull extension and name change. As with the feed pumps, there are many, many examples of engines. Alan L. Bates’ The Western Rivers Engine Room Cyclopedium had numerous types and photos if you want a more in-depth discussion. I chose to use this Bates photo for my build, although I have seen this photo in several 1890s books and on internet feeds. Another useful engine graphic is both labeled and provides a quartering perspective. Source: Western Isles Photos/Graphics Note the following photo used a pendulum attached to the pitman to run the valves, unlike many other boats that used an eccentric attached to the sternwheel itself. Some boats actually used both the pendulum and the eccentric. Source: Steamboats.com JHC did have a pendulum based upon the cropped and enhanced photo below. I left the model’s engines with solely a pendulum for the steam cut-off control. I also used a simplified rocker assembly. Heavily cropped and enhanced. Note the pendulum. Source: University of Wisconsin LaCrosse Murphy Collection Dime time with the finished but unpainted engines. The left engine is fully extended while the right is exactly at mid cylinder. The final painted products. I needed to add the pendulum and slide for clarity. The entire unit will be removed from the model until later assembly. Makes life much easier. And this is sorta what it will look like with the feed and manual water pumps are added. But still lots of detail to be added. I need to make the sternwheel now. I will use the same process an I did on Thistle. The process, along with upcoming family duties may require some time before completion.
Keith, Unbelievable detail at so small a scale! I know how difficult these engines are to build. Way to go! LJP
- 732 replies
- Lula
- sternwheeler
There are numerous examples of feed pumps out there. I did not use Moyie’s pumps as they are completely different and much more modern than many of the period single pumps. While I used photos of several different pumps for the period, the two following are the ones I most relied upon. My build used rocker arms (top photo) versus the older slide model on the bottom litho. The dime is back! The finished but unpainted main and auxiliary pumps are below. I have included a photo of each side to show the detail. The air chambers are cut down corsage pins. The rest is numerous pieces of Evergreen plastic, wire, and thread. The finished products, again showing both sides. And “saved” with paint. Now onto the engine assembly. This means I will need to build the engines, slides, pitman arms and the paddle wheel – along with the cylinder timbers and sternwheel bracing. This will take time and will be several individual projects. I want to build each of the individual components and then place them where they should be in the final build. That way it will be easier to install during final assembly. Once completed, I can then build the crew quarters and layout the engine room before re-installing the engine assembly.
Keith, Great job! But your "Valuable lessons learned should I have the opportunity to make another sternwheeler. " should read WHEN I make the next sternwheeler... LJP
- 732 replies
- Lula
- sternwheeler
My major source for images of some of the machinery and the engine room is the S. S. Moyie (1898). Moyie is now a museum boat in Kaslo, British Columbia. It had an incredibly long life and ran Lake Kootenay until 1957. It has numerous YouTube videos, both of the ship as a museum, but also when it was still in operation. Several years ago, the museum website (which also has a Facebook account) had an interactive video (since discontinued, unfortunately) that afforded an true in-depth look at the boat. I have gotten screen shots from several of the videos. Moyie had two manual pumps that I replicated. In the engine room was a manual fire pump while in the boiler room was a manual feed pump. These are two photos of the fire pump. This is the build without the handles. Note a new dime – wore the other one out. The diameter of the dime equates to 3’ 8” in scale. I lightly glue small parts to scrap balsa to make it easier to airbrush or paint. That is what you see at the base of the part. Finished product, with arms. Ready to be placed in the engine room. I do not have a great photo of the manual feed pump but it still provides enough detail for a build. Another dime time before painting. And the finished product. This will be placed on the main deck in front of the boiler pit, just like Moyie. Next, onto the steam main and auxiliary feed pumps.
Hi John, Here is the finished boiler assembly. And John’s comment in Keith Black’s Lula build on painting saving the day is right on the money. Here is my final painted ( a/k/a “saved”) boiler assembly. The actual boiler colour is a dark black. I enhanced some of the photos to show the detail as dark black obscures the detail.. This one is slightly enhanced. The gauges are on the right. The curved pipe on the rear of the boiler is the blow out pipe. The breechings are overly large due to photo perspective and have been cut off. Side view, unenhanced. The safety valve and man hole cover are prominent. There is another view of the gauges and blow-outs. Quartering rear view. This has been enhanced to show detail. This view shows the main and auxiliary water feeds. And here is how it looks in the hull. It has not been glued in yet as I do not want to damage it as I am working on other things. The black squares in the foreground are coal hatches. Now onto the other machinery: engines, feed pumps, hand pumps & such. Still tiny stuff, probable re-dos and much more self-discussions. These are each little mini-projects so I will do a few at a time. I will start with the hand pumps.
I got to working on some of the tiny boiler assembly detail. The door to the firebox was a challenge. I used plastic for the top layer and detail while there is a wood backing. The dime gives some sense of size. Another tiny addition was the safety valve. I used a safety valve litho from the International Library of Technology book from the 1890s. This was one of the books for engineers. It contains way more information (and mathematical formulas) then I ever want to attack. The part used six different type and size Evergreen plastics. Same dime, different boiler part. An unusual construct on my boiler is the layout for the glass, stop cocks and water gauge. Marine Iron Works has a print from a photo (which means it actually was built) where all of the items were on a separate pipe apart for the boiler. I simply had to use this layout. As noted on Keith’s YouTube schematic, gauges &c. were often attached to the boiler itself. Source: Marine Iron Works of Chicago USA. This is what I ended up with. This is a temporary layout that still needs to be painted, trimmed and then secured. I had to rearrange the components because of the dual stack breeching. This was a horrible build with redos and many conversations with myself. For the glass, I used a section of straight hobby bead . The gauge was a brass part from my possible box (everything possible is found in there). The pins will be trimmed after painting. Yup, same dime put to use again. An issue I could not completely resolve was the breeching layout for dual stacks on the bolier. There were lots of single stack examples for a single Scotch Marine boiler, and numerous examples of multiple Western Marine boilers on dual stacks – but no dual stacks on a single boiler. I used a poor quality photo of the 1922 burnt Valley Queen (Ryan built ex- Leander Choate) from the Oskosh Public Museum for my layout. The breeching will seem huge in relation to the boiler. This may be due in part to the boiler being situated in a boiler pit within the hull as opposed to on the main deck. No dime, no photo. The final boiler will also include the upper & lower blow-outs and main and auxiliary water feeds. On to assembly and painting. This should not take too long.
