Anthony Hearne
NRG Member-
Everything posted by Anthony Hearne
not sure if i've asked this before but is the proxxon mini mill any good for light duty work , or should i get a more expensive one , i plan to use it for scratch building
i ordered 2 books on the 18 of november , when i called they said that they were returned to sender so they have sent them to me again , Cathy even gave me a tracking number , i have ordered several books from them now one came within a few days but all the others have taken a little bit of time , but they did get to me and in perfect condition, the books are worth the wait so be patient and you will be rewarded
all great suggestions , i did look at the band saw tutorials when i got my band saw and i think i have it setup as best as i can , i haven't used it much so some practice pieces are a great idea , i've also contacted an orange orchard near me to see if they can spare any timber but haven't had a reply yet ,
technically not my first project but i am going to try my first full ship, the Hayling Hoy< i am just about to finish a blandford cross section that i used mostly cherry for , that worked out well ,i was wondering if i should stick with the cherry or try something else . i thought about boxwood but cant seem to find it anywhere same with pear, what are your thoughts on this and if you do have a suggestion , where can i get it from? thanks Anthony
i know about this one but i'm not sure about the material used for the construction , not sure about its longevity ,
not sure if i have made a mistake or not, i wanted to build the victory , i have built one from a corel kit and although it came out ok in the end i wasn't happy with it so thought about doing another one , i wanted the caldercraft one as i know it is the most accurate but decided on the panart one after visiting the Lauck street shipyard , at the time it looked like the best option for me as it would need a lot of scratch building to make it look good , i've had the kit since my birthday in august but told my wife to hold onto it till xmas as she never knows what to get me . yesterday i had a quick look at the kit and i am not impressed , it will require a lot of work to bring it up to decent standard but i'm wondering if its worth it, my first question is how accurate is the hull shape , if its ok then i can work with that , but this will be a future project and if i keep it then i would like to know that i can produce a decent model from it , if not then it is time to pass it on to someone else. i have a couple of projects that i would like to tackle before the victory (again) so it would probably be in a couple of years , what are your thoughts , is it accurate , worth it , or should i try for the caldercraft one (eventually)
again thank you , i am leaning towards a mill as i can see where it would be useful ,are there any brands to steer clear of ? is the proxxon one the same as the micro mark one?
i have the byrnes table saw , the disk sander and the thickness sander , a cheapish scroll saw that works and an oscillating drum sander , plus various hand tools . i bought the table saw after selling the micro mark one that i bought and used once , it was horrible . thats when i realised that you have to pay for quality tools , thank you flr all the suggestions i will look into the rasp
i am going to be embarking on my first full pof build , the Hayling Hoy from the book and plans by David Antscherl , i already have most of the tools that i think i will need but i don't have a set of chisels for carving and fairing the inside of the ship , i don't want to buy cheap (throwaway tools) but something that i will be able to use for more than one project , can someone recommend a make that is fit for the purpose? also the next tool i would like to buy and i will have to save for a while to be able to afford it is either a lathe or a mill , i think the mill would be more valuable before the lathe but what is everyones opinion on this subject and possible recommendations ( i"ve been looking at the sherline series of metal working equipment), thank you
HMS VICTORY 1759 by isalbert
Anthony Hearne replied to isalbert's topic in - Build logs for subjects built 1751 - 1800
absolutely beautiful -
tilt arbor table saw
Anthony Hearne replied to Anthony Hearne's topic in Modeling tools and Workshop Equipment
Cool , thank you for clearing that up . Guess ill be getting the tilt table -
I think I understand what your saying ,thats why jim says to tilt the saw to make the table flat. -
again thank you , does anyone have a picture of the table set at 22.5 degrees , i would like to see the gap from the table to the bed please , or maybe i'm not understanding exactly how it works -
thank you , i know its easy to fit to the saw i just have questions about using it , do you have any pictures of the table in use , -
i did see that one , thats why i have questions about the use of the table . is there a video of someone actually using it? -
there seems like a big gap between the table and the bed , is this a problem for smaller cuts? -
i searched for videos on using the tilt table and only found one , he was complaining about the need for 3 hands to set it up and that the 2 small allen head bolts that hold the angle weren't strong enough for multiple cuts , also that these bolts had to tightened up to the point of stretching the threads which would fail over time , is this correct ? i have the sliding table but as of now , haven't used it , but then again i'm only at the beginning of my scratch building journey , i have , however , on several occasions needed to cut specific angles on the x section i'm building now , so i feel that i have a need for something just not sure that the tilting table is it. -
i have searched for the answer to this question but get differing responses . i own a byrnes table saw , which is excellent , and i completely understand the reason for keeping the blade at 90 degrees . i looked at the tilting table attachment , but find more negative reviews than positive , but i find that i need to be able to cut at an angle more than i realised so i'm trying to find a solution to that problem, the only thing that i have found is the tilt arbor table saw from micro mark , but its $350 , is there something that i have missed that i could use to make angled cuts (fairly easily) with the byrnes saw?
