Helli
Everything posted by Helli
  1. Hi, Because of the ship model building, i am actually interested about everything. The history, the connections and the way of thinking. About why this was done. Helli
  2. Hello John, Thank you very much! Helli
  3. Hello, Can anyone tell me what the "red point" on the english flag means? Thank you Helli
  4. Hello Robert, As the previous speaker said, I´m sure you will make it. It`s very easy with filling and sanding. The planking looks very good and with patience the result will convince you. Helli
  5. Hello Robert, I like the planking very much. The wooden nails are great. It`s a shame that they disappear under the second planking. Keep it up. I`m already looking forward to the next step. Helli
  6. Hello, Now i have finished the main yard. First thing i did the yard. Afterwards i mounted the octagon and the iron fittings. I made these from shrink tubing. I made the quarter boom iron out of brass. Now i´m rigging the main yard. I will now be busy with rigging for some time. I will report again afterwards. Helli
  7. Hello, I´m already looking forward to the progress. Helli
  8. Hello, OK! Thank you very much for the photo. Then i really have to get over the cannon. That was what i couldn´t imagine. Helli
  9. Hello, In the pictures you can see what i mean. I come with the rope through the hole under the stairs and then go over the cannons to the attachment point. Have i understood that correctly? Helli
  10. Hello, How to drill a hole wasn´t my question. I wanted to know how to get from the hole to the attachment point with the rope. Helli
  11. Hello, I have a question for the HMS Victory builders. In the book "The Anatomy of Nelson´s Ship" on page 95 it is described how the sheet of the main yard run. Here is an excrept from the book. The standing part of the sheet is made fast to another eyebolt below the block. Forward of the block and above it there is an oblique lead lined hole through the quarter deck bulwark; the leading part of the sheet reeves through this hole and belays to a large staghorn on the quarter deck bulwark. Of course, i didn´t install this pipe. Now i am looking for an alternative method. And now my question. How did you solve it? Here are two more pictures so you know what i mean Thank you Helli
  12. Hello Robert, Many thanks. You don´t have to be afraid of rigging, you grow with the tasks. I am sure you can do it. This is only my first ship. Hope i do better with the next one. Helli
  13. Hello, Now I´m a giant step further. I´m finish with the dinghies. After that i continued with the braces. Here I have hung up a dinghy for testing purposes. Here i am at the buntlines and leachlines. Now the rigging on the fore mast is ready. Next i will start with the main mast. Helli
  14. Hello, Roberts Orca Thank you very much for the compliment. I made the rigging truck on the lathe. Now it goes on with the fore topgallant yard. Helli
  15. Hello, Got a little further again. I have now made and installed the fore topmast yard. But now it is slowly getting full of lines. Now i must made the rigging truck because i don´t have one in the kit. I will then report on the further construction progress. Helli
  16. Hello, Thank you very much. It was very helpful. Helli
  17. Hello, It is the Victory from Caldercraft 1:72 On the topmast yard and the topgallant yard there are double and sigle row truss. Helli
  18. Hello, If i have a double row truss i take the one line and go around the yard. Then back through the block and down to deck. The other line is the same. I hope this is correct. But if i have a single row truss i don´t know how attach the line on the yard. I have made a picture so that you know what i mean. Thank you Helli
  19. Hello, I have a question. Can someone tell me how to mount a single row truss? I can only find something through multiple rows. Many Thanks Helli
  20. Hello, Thank you for the likes and comments. The fore yard didn't have to wait long for assembly. Now it is already installed. Next I will focus on the fore topmast yard. Helli
  21. Hello, I'm done with the dinghies except for a few small things. Now I have started with the yards. The fore yard I have now finished. Now it waits for the assembly. I am now doing one yard after the other and work my way to the stern. Cheers Helli
  22. Hello, I have made a little progress again. Now I have all four dinghies in the shell finished. With the two small boats I have planked only once. Since this is not very strong, I have applied a layer of GFK. This is now also sanded and filled. The decks are already made and weathered. Now the interior begins. Cheers Helli
  23. Hello, Since I have a forced break in the rigging, I started with the dinghies. The method of gluing the frames was too risky for me. Therefore, I have separated them before gluing to use them afterwards as placeholders. After that I sanded the first planking filled and sanded again Now I started with the second planking Add a few more details and fill a first time So the whole three times I will report again on the further progress Helli
  24. Hello, Before it went to the fitting of Deadeye Futtock Strops I soldered them. But with a maximum of 10w soldering iron because otherwise the brass anneals and cracks. Then I mounted all the blocks and the futtock shrouds. And again ratlines :-) Now I have a forced break because I lost one when painting the deadeyes and I have no more in reserve. Due to the lockdown all stores are closed so I have to get them online. But there are still enough other things to do. Helli
