DavidEN
Posts posted by DavidEN
11 hours ago, Beef Wellington said:
David, wlecome to the ever growing Diana/Artois club! Great stat to your planking, those treenails looks very nice. This is definitely a challenging, but fun and rewarding kit to grapple with. I'm sure you've already looked at many of the build logs which highlight some of the unique challenges. You cannot think too far ahead with this build, especially if you plan to make modifications! You already point out probably one of the biggest initial challenges which is the astern alignment, so expect to have to make some adjustments there. Establishing the position and alignment of the quarter galleries based on the run of the upper/gun deck will allow you to then establish the placement of the stern fascia.
Hi Jason,
Thanks for the kind words of encouragement. I have certainly been following the build logs of other members. There is so much information and inspiration to be found there. I have been shamelessly pilfering ideas and details from your log for a while now as it is the gold standard for Artois builds. I do not know how you do it Even if I was building at a scale of 1:10 I couldn't hope to match the detail and workmanship you achieve.Regards,
David
29 minutes ago, DaveBaxt said:
Great to see another build log of the Diana by Caldercraft and one I would like to follow from the beginning, live as it were. I like how you did the blocks fore and aft but more than usual ie as soon as the area where the planks start to bend. In the past I have always had to add filler in this area after the first layer of planks have been layed.. I too was think of adding blocks nearer to midships so think you will get a better smoother curve with your planking.
Great idea too for the tree nails. Well done. Keep up the good work and I look forward to your progress. Best regards Dave
Hi Dave,
Welcome aboard. Hull planking does seem to be a bit of a dark art. I think it will take another two ships before I begin to get the hang of it.
It looks like you are progressing very nicely on your Endeavour. Happy building.
Regards,
David
5 hours ago, allanyed said:
Pretty ingenious David. It's good seeing you go through the experimentation to get what you were looking for. They look far better than most, especially at 1:64. Can you make or are there other nozzle sizes so you can then make the various size treenails needed from 3/4" to about 1.5" or 2" ?
As to bamboo, when you say lathe, did you actually try to turn these? Splitting bamboo skewers to a slightly larger than needed size then running through a good quality draw plate is fast work for those that do not have a 3D printer. Making in the neighborhood of 10,000 treenails though may justify an investment in a printer. 😀
Allan
Hi Allan,
I have tried the drawplate method but I have never managed to achieve the smaller sizes without them disintegrating into a frayed mess. There are other nozzle sizes available. I think the smallest is around 0.2mm in diameter going up to 0.8mm in increments of 0 1mm. Changing the nozzle is not a simple task though and requires disassembling the print head to do so and I hear the smallest sizes are prone to clogging.
I have decided to attempt a build log. I learn so much from the build logs of other members that I felt that I should venture something in return so, after a gentle prod from Dunnock, here we go. I am fairly new to the hobby having taken it up two years ago. I had just completed the Charles W. Morgan which was very enjoyable and selected the HMS Diana for my next build as it is a very pretty ship. I did hear that the kit itself has issues but thus far it has gone together without too much trauma. I started this build in January 2021 so the first few posts will be a catch up to where I am now.
The book The Frigate Diana from the Anatomy of the Ship Series by David White (AOTSD) is a very valuable resource for anyone attempting this build and is my first call for reference having more or less shelved the drawings and instructions. I also reference the drawings of the Artois class ships housed in the National Maritime Museum (NMM) along with photos of their collection of contemporary models and of course the wealth of information contained in the build logs of other members.
The basic frame went together fairly easily but I did have to use the heavy file to get the pieces to fit together. I introduced some balsa blocks to fill the bow and stern section as my hull planking skills are a bit shaky and I need as much help as I can get when tackling the complicated curves in these areas. I also sawed off the section at the bow and replaced it with a new piece made out of 5mm thick lime wood as I was not happy with the exposed edge of the ply. I wish I had done the same at the stern post.I suspect that there may be something not quite right in the positioning of the rear deck that forms the lower edge of the counter. Having now completed the build in this area I found that the quarter deck galleries ended up sitting too high. There is a good possibility that this may be a result of my bungling but I have noticed this phenomenon in other builds. If I was starting again I would do a lot more checking of the profiles of the aft bulkheads against the drawings in the AOTSD and the drawings from the NMM. It is only around 4 or 5mm difference but it is quite a difference to what is shown in the NMM drawings. It should be noted that these sit a bit higher in the drawings for the Jason and the Seahorse but these are still lower than where mine ended up. I will just have to live with whatever I have as it is too late to go back and do any modifications.
The lowest deck can only be glimpsed through the gun deck hatches so I used this an opportunity to test out some planking mockups. I settled on a maple plank and I tried to give it a more distressed look using various stains and pastels but feel that the end result was a bit dark. I went a touch lighter for the gun deck itself. I am aiming for a more weathered look as I do not possess the mad skills required to produce one if those immaculate looking models and I can always pass off any wonkyness as an intentional depiction of wear and tear.
I wanted to add trenails but ran into a bit of bother. I have heard that bamboo skewers can be lathed down to an appropriate trenail size but that proved very time consuming and frustrating and didn't provide a very good result. I think that the skewers are best left for the Kebabs. I then tried some 0.5mm diameter styrene which was good in terms of a consistent shape and size but they were too white and I needed something closer to a 0.3mm diameter. While wandering about the supermarket I found a scrubbing brush that had bristles that were 0.35mm diameter which was an improvement on the styrene but still too white. I then went back to the supermarket and found a brush, which I assume is for cleaning bottles, that had natural bristles that were a better colour and the correct diameter if you could be bothered sifting through them. Despite the fact that they are too dark and painful to work with I ploughed ahead and completed half the gun deck before I discovered that I could get excellent trenail material if I ran the faux wood filament through the 0.3mm diameter nozzle on my 3d printer without printing anything. It is the correct size and dimension and they almost become invisible depending of the angle of viewing much like the real thing. They are a little light but it is as good as I can do.
As this is my first post I will stop here and submit as I am not that confident of success.
- Beef Wellington, DaveBaxt, CiscoH and 11 others
- 14
Hi David,
I do not wish to hijack your log with more scuttle speculation but I am currently building a Diana and I am following your build with great interest. I have been looking closely at these openings and I believe that the AOTS drawings are correct albeit lacking in granular detail. The sectional drawing shows the scuttles flush without coamings as highlighted below and the double line around the scuttles with the mitred corners shown on the plans represents the flush frame of the hatch cover. This can be seen in the below photo of the same scuttle cover on the HMS Trincomalee (admittedly built 22 years later). I guess whatever way you go it is the modeler's perogative.
Good luck,
David- dunnock and Beef Wellington
- 2
HMS Diana by DavidEN - Caldercraft - 1:64
I started on the installation of the gun deck. I drew the planking pattern onto the false deck and then cut it in half lengthways for ease of fitting. I plumped for the top and butt planking for this deck noting the ambiguity in the AOTSD drawings. When placing the false deck on the model I noticed that some of the beams passed through the hatch openings. I relocated these with an inelegant detour although they would have had enough structural integrity as cantilevers and I probably could have gotten away with just cutting them out.
I made up the hatches using the kit supplied gratings and used walnut for the coamings. I stained the gratings using Golden Oak stain although the wood used in the gratings does not take the stain that well. If I were to do it again I would cut the false deck back around the coamings so that the edge is not visible through the openings. I have just painted this black at this location but on the upper deck I cut the false deck back and introduced secondary beams for the coamings to sit on.
I started on the ladders that go between the decks. I thought that I had been diddled out of these as I couldn’t locate them on any of the parts sheets. After making the ladders from scratch I discovered the kit supplied pieces on a small piece of ply that had become stuck to the back of another sheet of parts. Looking at the supplied pieces I do not think I would have used them anyway as they were fashioned out of poor quality splintery ply. I built a couple of wonky efforts before I decided to 3d print a jig which enabled me to get the grooves in both the stringers align with a higher degree of accuracy. I then made another jig to hold the treads parallel to each other when fitting them to the stringers. This holding jig was not that successful and requires some redesign. I used 1.5mm thick walnut for the stringers and 1mm thick walnut for the treads.
I started to build up the inner bulwark using the AOTSD drawings as a reference. I knocked up a couple of gun carriages for reference so as to check the height of the gun ports as I went along. This is the first time I have had to deal with gun carriages and later on I will dedicate a whole post to them to highlight some of the trauma I experienced.
There was a great clash between some of the gun port locations and the bulkheads. I tried to overcome this without resorting to major surgery by shifting the critical gunports to abutt the bulkheads and then dispersing the others more or less evenly in the remaining space. I did a lot of this by eye, being too lazy to measure everything exactly, but this cavalier attitude did come back to haunt me when installing the chain plates and channels.
Having located the gunports on the inner bulwark I turned to the problem of how to position these on the outer skin of the hull. I noticed that a lot of builders complete the first hull planking and then cut the gunports out. I was not at all confident about my ability to achieve that with any reasonable degree of accuracy or safety so I decided to build the lining of the gunports directly onto the inner bulwark and then continue the first planking such that it butted against this lining. The thinking was that I could then dremel these linings flush with the first planking and hide the whole mess with the second planking. I think that the method itself is a workable solution had I gone about it in a slightly different way. What transpired was that I didn't account for the slight curvature of the hull and neglected to chamfer the sills of the gunport lining such that they lay parallel to the gun deck. If I was to do it over I would assemble the entire gunport lining off the model and then profile the one side to match the curvature of the hull so that they fit snugly to the ship with the top and bottom sills parallel to the gun deck. For the sweep ports I just used some 4x4mm square brass tubing to give me something to plank to.
Once I got going the first planking was uneventful which I will not dwell on here as there are a lot better examples of how to plank a hull out there. I should note that after planking the first side I did pause to install the ladders, as well as the eyebolts to tie off the end of the rope handrails, while there was still access from the side. If I had waited I could imagine dropping one of these ladders into the completed hull and never being able to get it out again where it would be doomed to rattle about for all eternity.
