Riotvan88
Everything posted by Riotvan88
  1. The bulkheads are quite an easy fit nothing is glued yet
  2. Hi again Sorry for the daft questions but it's my 1st build and I'm wanting to make sure I do everything correctly and not rush any steps. From the pictures you can see my keel is curved from bow to stern slightly, the photos makes it look worse than it actually is but in any case its not straight. My question is can I make a jig by gluing wood blocks to a solid base the idea bieng to sandwich the keel between the blocks and keep it straight. Then whilst in this jig glue and pin the bulkheads , false deck and add balsa blocks between the bulkheads. Or should I soak the keel and clamp flat overnight? I thought best to seek advice from this forum 1st before continuing as its been great so far. Thanks
  3. Thanks I'll go have a look at those builds I didn't realise I could glue these later, I guess where to follow the instructions and where to adapt will become obvious with experience. Much appreciated
  4. Hello I went and bought the Caldercraft HMS Sherborne kit. It's my first plank on bulkhead kit. Just started the build yesterday . So far I have removed the bulkheads and sanded smooth. I'm going to attach the keel pieces together next. My keel has three dark coloured woo pieces that attach to the main light coloured piece. These three dark wood pieces are wider than the lighter coloured main keel. I'm curious how I should glue this up. Should I try to center the main piece so that the same amount sits proud on either side or should it be sanded so all pieces have uniform thickness? Thanks
  5. Good to hear, I've gone ahead and bought it. Going to go slow and keep checking this site for reference . I'll be back asking for help in no time I'm sure. Since I'm stuck at home now for the foreseeable I'll have plenty of time to work on it.
  6. OK thanks for the advice think I'm going to buy the caldercraft cutter Sherbourne as it's fitting the type of ship and era I'm interested in. I think if I ever do a yacht like bluenose I'll get the MS kit but too expensive for me as a 1st kit
  7. I've found a billings Bluenose 2 kit on ebay complete and unstarted for a reasonably cheap price compared to buying it new. I have decent amount of experience building 1/350 scale plastic and brass ship kits but never built a wood kit. I've read ship modeling simplified by Frank Mastini and so now I'm encouraged to look for a good beginners wooden kit. Is this kit any good or should I look for a artisena or model shipway kit instead? Some have said billings are no good? Alternatively some have suggested Amati endeavour 1/80, caldercraft Hm cutter, pickle or supply brig as a good starter kits Generally I'm interested in age of sail warships more than yachts. I however appreciate that I should start off with a POB kit that's on the easier end of the spectrum. I hope to eventually one day work up to a HMS Diana or similar. Specifically I've seen the billings Bluenose 2 kits Hull is built in 2 half's which seems unconventional. Would this unusual method be unsuitable to learn the art with? All advice much appreciated Cheers
