Riotvan88
Everything posted by Riotvan88
  1. You are probably correct. I've seen both red and black quoted for the antifoul. But Ibelieve most were black. That said I'm probably going to paint below the waterline a dark red because I think it will look better with the dark grey rather than grey and black whcih will be too similar. Although I'll check this first with some test pieces. I don't mind some artistic license for asthestic reasons on my models.
  2. This is my first wooden sailing ship started in 2020. Slow build. Progress so far,
  3. Hi guys, I've an old Revell 1/72 Flower class corvette kit that I'm builing as HMCS Pictou I chose this ship because I've never seen it modelled before (probably because the paint scheme is one of the more "boring" ones) and I really like the ship in a simple paint scheme without the dazzle camoflage. I think the dazzle schemes hide the ships lines and in my opinion the Flower class has quite elegant looking lines. Here is a photo of the ship. I asked google AI to colorise the photo and it created the color one. AI suggested the dark hull color is Royal navy fleet grey RN 507A whilst the lighter color would be RN light grey 507C or wstern approaches white. Anyone know what colors this should be? I think the color picture is probably fairly accurete but I still would be interested in suggestions. Thanks
  4. Some progress on my Nordkap trawler. Hull painted and base coats on superstructure. Superstructure rear deck still needs much sanding and final coat. The yellow stripe on the waterline is tape. I will paint a white boot top here before clear coating the hull
  5. Small progress, had to make the anchor details for the fore deck before being able to glue down the forcastle deck and finish painting the hull
  6. Thanks. It's 41 inch long 1/75 scale somewhat bigger than the billings kit which I believe is 1/90 scale. I'm not sure about the motor setup yet. Most likley a high torque low RPM 600 size motor powered by a 6v lead acid battery.
  7. After much messing about I finally got the hull prepped with penetrative epoxy then glassed over using cloth and Gflex resin. Now painted with red oxcide primer.
  8. Made a start on the deck. 3D printed jig for deck pattern
  9. Superstructure and wheelhouse built up but loosely fit.
  10. This is my Nordkap trawler build started in April it is based on the billings plans but since I wanted a small model it is built at 1:75 scale instead of 1:50 like the billings kit. This is my second scratch build alongside zwarte zee also 1:75. In the second picture you can see the small size of Nordkap compared to zwarte zee.
  11. Hi guys Building a scratch Zwarte Zee and now approaching the time to fiberglass the Hull. Previously built a smit rotterdam and used west systems Gflex epoxy only but this time I want to use cloth aswell. What is the best weight of cloth to use and what epoxy resin to use? The Gflex used previously was thick and probably not suitable for wetting out cloth. Just looking for suggestions and tips as to what everyone else uses. Cheers
  12. Thanks for all the info guys. Regarding the instructions apparently both kits come with a detailed booklet and online reviews rate both instructions as good. I think I'll buy those books so I can build a more accurate model either way.
  13. So I'm currently building a Caldercraft Sherborne, so far the Hull is coming together and I'm fairly happy with the result. This is my first period ship model although I have now built three wooden hulls previously. I'm looking to start the next model at some point in the new year. I'm keen on building the gallion Revenge. It appears there's two kits available the occre revenge kit and the Amati/victory models kit. Has anyone got any experience with either kit? The occre is much cheaper and looks to be a more decorative model whereas the Amati looks to be a more realistic representation of the real ship. The Occre kit also comes with sails and although less realistic I very much like its appearance. That said I also like to more scale realistic look of the Amati model too. I just wondered what people's opinions are on the two options. Additionally I think the occre kit is aimed more at beginners like myself so thats also a plus for that one. Would the planking be harder for these kits than the Sherbourne? Interesting to hear people's thoughts Cheers
  14. Recently picked this model up again after being shelved for a couple of years. Progress as of today.
  15. How did you get on with it? My kit was one of the early releases, the latest one looks much improved regarding the sequence and parts design.
  16. Bridge interior modelled using 3d printer. Unfortunately won't be very visable although I've added led lights so should be partially visable through the small windows when lit
  17. About 90% finished now. Still some railings and details to add along with decals. Will have to make some replacement ones as the kit ones are yellowed and creased. Started the next build scratch zwarte zee in same scale.
  18. Hello Is there a way to sand or remove a raise edge in paint where masking tape has been? For example along a Waterline? Without effecting the paint shine or matte level of the finish? Would rottenstone archive this? I've built a boat and there is an edge that can be felt where the red paint meets the black. The paint has the finish I want so I don't want to do any polish or sanding that will alter the finish.
  19. Now cut away internal structure for the access hatches and begun blocking the stern. Lots of sanding and fairing for now next step glue the decks down.
