Riotvan88
Members-
Everything posted by Riotvan88
Hello Picked up a billings smit rotterdam kit. Its the old kit. The wood is very grainy and flimsy. Anyone who has built this old kit will probably know what I'm talking about. My question is how do you cut out the windows from the superstructure pannels without them crumbling? When a row of windows are placed I find it just falls apart especially when cutting accross the grain. I'm thinking of trying miniture chisels. How did othwrs do it?
Hello I just picked u a billings smit rotterdam kit second hand. The frame is built and stern deck installed. I'm wondering how to seal the grain to get a smooth surface. I'm going to be sealing and painting parts as I build as I imagine painting some areas will be difficult when complete. The kit came with a tin of humbrol sanding sealer but this is very thick. Can I thin it? (What with?) would varnish be better or any kind of spray wood sealer/primer? Also the rear deck has been painted without sealer. Can I seal over this to repaint?
I'm looking for some plans for CAP SAN DIEGO as I've decided I'm going to start a 1:100 scale RC build. Found one website with plans seemingly available for purchase. Sent an email however the site looks like its from the 90s so I'm skeptical I'll get a reply. Any ides where plans for this ship can be obtained? Thanks
Thanks for all the advice. I've tried to make a shooting board. Very basic with the materials I have at hand as buying more wood is difficult now. I planed flat the edge of a strip of wood using a vice and a board I've then glued this onto an mdf board and added a stop to it. If this isn't precise enough I'll probably just buy a dedicated tool or a disc sander. Hopfuly when my mini planer arrives I'll be able to true up the edges for my bulkhead filler blocks. I did want to ask what exactly would be regarded as an acceptable tolerance for a wooden kit? I understand that no measure is ever perfect I'm an engineer in aerospace even a supersonic jet isn't 100% as per the drawing there's always a tolerance. I just hope my attempt at a shooting board is within an acceptable error.
Thanks for all the advice from everyone. Problem I'm having is I can't make anything with a 90 degree angle or flat face so if I try make those jigs it's pointless as they won't be straight themselves. I've tried planing a pice of wood flat to make a shooting board I can get the length straight but the thickness edge I can't get 90 degree it's always sloped. I've seen mixed reviews on disc sanders sub £250 price range and I'm not willing to spend that much. On second thoughts I might try using a square on a base and a sanding block.
Hi guys Feel daft asking this but I need a tool to cut precise 90 degree cuts to make the blocks to fill my Hull. So far I bought a mitre box and saw I can make a square no problem but the saw has so much play that the cuts are never perfectly vertical. So for this reason I'm having trouble getting perfect filler blocks. I'm considering this https://www.drapertools.com/product/88192/550mm-Precision-Mitre-Saw But it has mixed reviews on accuracy so. I thought I'd ask on here is there are any recommendations for a good tool to make very fine, precise cuts. Thanks
OK thanks, I've not made any cuts in the keel but I plan to use blocks like you did. Are those the blocks in the picture or did you completely fill the spaces? Also did you paint the interior structure with varnish prior to sealing it behind planking? Just the colour of yours in the photo looks darker than mine.
Thanks for all the advice, I went and built a basic jig to clamp the keel straight using wood blocks Thanks for all the advice from everyone. I considered contacting the kit maker the kit is a caldercraft Sherborne 1:64. However looking at the build logs I feel this is common issue so I need to learn to deal with it early on. So I made a basic jig using a base board and square wooden blocks I arranged this to clamp the keel tightly. This seems to have worked its difficult to tell how straight because of the sheer bit I definitely think it's an improvement. I then fitted the false deck to the false keel with pins, nothing is glued yet. I'm thinking if I glue this up and then fit basswood blocks to every space between the molds/bulkheads as someone suggested hopefully it'll then stay straight.
Hi again Sorry for the daft questions but it's my 1st build and I'm wanting to make sure I do everything correctly and not rush any steps. From the pictures you can see my keel is curved from bow to stern slightly, the photos makes it look worse than it actually is but in any case its not straight. My question is can I make a jig by gluing wood blocks to a solid base the idea bieng to sandwich the keel between the blocks and keep it straight. Then whilst in this jig glue and pin the bulkheads , false deck and add balsa blocks between the bulkheads. Or should I soak the keel and clamp flat overnight? I thought best to seek advice from this forum 1st before continuing as its been great so far. Thanks
Hello I went and bought the Caldercraft HMS Sherborne kit. It's my first plank on bulkhead kit. Just started the build yesterday . So far I have removed the bulkheads and sanded smooth. I'm going to attach the keel pieces together next. My keel has three dark coloured woo pieces that attach to the main light coloured piece. These three dark wood pieces are wider than the lighter coloured main keel. I'm curious how I should glue this up. Should I try to center the main piece so that the same amount sits proud on either side or should it be sanded so all pieces have uniform thickness? Thanks
Billings Bluenose 2 good beginners kit?
Riotvan88 replied to Riotvan88's topic in Wood ship model kits
Good to hear, I've gone ahead and bought it. Going to go slow and keep checking this site for reference . I'll be back asking for help in no time I'm sure. Since I'm stuck at home now for the foreseeable I'll have plenty of time to work on it. -
OK thanks for the advice think I'm going to buy the caldercraft cutter Sherbourne as it's fitting the type of ship and era I'm interested in. I think if I ever do a yacht like bluenose I'll get the MS kit but too expensive for me as a 1st kit -
I've found a billings Bluenose 2 kit on ebay complete and unstarted for a reasonably cheap price compared to buying it new. I have decent amount of experience building 1/350 scale plastic and brass ship kits but never built a wood kit. I've read ship modeling simplified by Frank Mastini and so now I'm encouraged to look for a good beginners wooden kit. Is this kit any good or should I look for a artisena or model shipway kit instead? Some have said billings are no good? Alternatively some have suggested Amati endeavour 1/80, caldercraft Hm cutter, pickle or supply brig as a good starter kits Generally I'm interested in age of sail warships more than yachts. I however appreciate that I should start off with a POB kit that's on the easier end of the spectrum. I hope to eventually one day work up to a HMS Diana or similar. Specifically I've seen the billings Bluenose 2 kits Hull is built in 2 half's which seems unconventional. Would this unusual method be unsuitable to learn the art with? All advice much appreciated Cheers
