GGibson
Everything posted by GGibson
  1. So, I worked a bit on closing the gaps between the deck underside and the bulkheads, and am satisfied those look better now. Now to work on the two gunport bulwarks. After soaking the bulwark sheets in warm water for an hour as recommended, they were pretty easy to work with. After dry-fitting, it was time to glue. I always love the visual of a dozen or more colorful spring vises doing their thing. I do have a bit of concern on the aft end of the bulwarks. In fitting them so that they came down just past the deck level, the tops of the bulwarks ended up about 2-3mm below the top of the stern counter. This may be a critical error on my part, as the first planking could have covered any gaps at the deck and it's more important for the bulwarks to be even with the stern counter. Thoughts? Advice? Will I be able to simply sand down the stern counter without any other repercussions? Going out of town for an extended weekend beginning Thursday, so don't think I'll start the first planking until my return. Appreciate the read and the advice. Gregg
  2. Thanks, Dan. I am now following and catching up on your Lobster Smack build log, as well. Looking good from what I have seen, but still reading your text. Hope it all goes well for you! Druxey, appreciate your comments. Definitely all a fun learning process.
  3. Well, I received the additional rigging rope that I ordered in order to complete the rigging on this Lobster Smack, so wanted to finish this boat. I am very pleased with the rigging line I ordered. All in all, the completed Lobster Smack came out well, and I learned a lot to do differently/better in future builds. I left off my build log at the point where I had painted the deck, the roof and other topside pieces and was working on painting the hull. A few comments on how I finished everything and what I'd do differently... Mast - I did a much better job in shaping the mast on the Lobster Smack than I did with the Norwegian Sailing Pran (NSP). Used the spar holder to knock down the four corners, but didn't overkill it, then used 100 and 150 grit sandpaper to shape into the round to fit the mast hole. Wanted to do this better than I did on the Sailing Pran (which ended up more oval than round), and I succeeded. Took similar attention to shaping the boom and the gaff. Sail (Mainsail & Jib Sail) - Thought I had done a good job in making the sail on the NSP, and did well with the two sails on this Lobster Smack, too. Probably the most challenging part of the sail preparation was drilling the holes for the lashings and hanks. The combined thickness of the sail material along with the reef bands along the edges, and compounded by the corner gussets, made for some tired and sore hands drilling all of the needed holes. As suggested in the instructions, I threaded some small beads (not sure if they're visible in the pictures) when attaching the gaff and boom to the mast, which I thought gave it a nice touch. Rigging - This was challenging, but yet kind of fun getting the various lines... the throat halyard, peak halyard, jib halyard, bobstay, fore stay, back stay, jib sheet and topping lift... in their proper places and belayed/tied to their appropriate locations. As suggested in the instructions, I did a lot of the preparation (attaching blocks, running rigging, etc.) before placing the mast in its socket. One thing I would like to improve on is knot tying. I've just been doing some simple knots, double knots, sometimes triple knot or knots on top of knots. I'd like to do them "cleaner", if that makes sense. Painting and paint scheme - I think I mentioned earlier in this build log, I wasn't wild about the color scheme I ended up with on this Lobster Smack, and wish I would have done it a bit differently. With that said, I'm also not pleased with how the toe rails and rub rails look, and it was difficult to paint the rails different colors without some bleeding onto other parts. Perhaps the solution to that would have been to paint the different rails prior to placement. I also did not place the sliding hatch runners correctly. I've got them laying on their side and discovered the error after I had glued them in place. Oops... That's about everything I can think of for now. Glad this one is finally finished. I started this back in March 2021, but had some delays with grandkids visiting during the summer and some other "real life" issues that had this sitting idle for a longer time than I wanted. On now to the Ballahoo, which I have already started while I was waiting on the additional rigging line. I will, though, try to look at ongoing Lobster Smack builds to see everyone's progress, and to offer my 2 cents worth of advice when asked. Thanks to those who followed my progress on this one, albeit with my delays. Happy building, everyone! Gregg
  4. OK, so I do have a question and looking for advice... I made a previous comment on how well the false deck fit around the bulkheads, but now as I am sanding the bulkhead edges to be flush against the deck, I am noticing gaps between the false deck bottom and the outside tops of several of the bulkheads. When I glued the deck down, the center obviously glued securely, but because of the slight curvature in the bulkhead tops, the deck is not touching the bulkheads on the edges. I should probably go around and spot-glue those areas, correct? This will probably have an effect on how the gunport bulwarks and the hull planking fit? Thanks in advance for any advice! Gregg
  5. Thanks for the feedback, George! And for the advance warnings on the masts, carronades and anchors. I'll watch for those concerns and report back! Thanks!
  6. Started with the hull construction. Pleased so far in how the bulkheads fit into the keel and how the false ply deck fit down onto the tops of the bulkheads. When dry fitting the bulkheads, I needed to sand almost every one of the bulkhead slots so that they slid firmly in place, without being so tight as to be stuck but yet not so loose as to be wobbly. Was careful to use my mini square tool on each bulkhead (something I did not do well on earlier builds) to make sure they were at 90 degrees to the keel. This work paid off in having the false ply deck fit perfectly on the bulkheads. Other than Bulkhead 11, I did not sand or bevel any of the bulkhead edges prior to placement and gluing the deck, so working on doing that now. To make it easier to handle as I do this sanding, I am waiting on placement of the stern counter frames and the stern counter and fascia pieces, so that I don't accidentally snag them or break them. As everything fit pretty nicely, really only Bulkheads 1, 2 & 10 really need great attention. Yay! As I placed and glued the walnut bow and walnut keel, they didn't come together exactly perfectly, and there is a small gap at the join, so I will need to do some fill there. Once I am done with the bulkhead sanding to where they are all flush with the deck, looks like it's on to the gunport bulwarks and planking.
  7. Thanks, Chris! I recall seeing your comments on those other Ballahoo build logs, as well, so look forward to your follow on this one!
  8. Still trying to finish my Muscongus Bay Lobster Smack, but waiting on some more rigging line in order to finish rigging the sails, blocks, etc. So... while I am waiting on USPS to deliver that line, I thought I would begin my next project waiting in the shipyard. Decided to work on the Ballahoo. This one is going to be very much different than my first two builds... the Norwegian Sailing Pran or the Lobster Smack... in that the instructions are definitely not as detailed as those first two, which were specifically designed for the "novice" first-time shipbuilders. The Ballahoo comes with a 10-page instruction and part ID manual, as well as three (3) large 33" x 24" plan sheets. This Ballahoo ship has been sitting in the "shipyard waiting room" since last March when I purchased it, and I hadn't opened it until now. But, with an inventory check, it appears everything is in order. I've already reviewed a couple previous build logs for this Ballahoo, and will be referring back to them often as I progress through my own build. I welcome other comments, suggestions and advice, as well! Have started removing the bulkheads and keel from the sheet and sanding all the edges smooth. I'll update more as I move forward on this, with a brief pause to finish the Lobster Smack once I get that new rigging line. Thanks! Gregg
  9. Thanks for your input, as well, Dan! Yeah, I just looked back at the line I used for the Norwegian Sailing Pran, and I definitely have too thick of line for this run. Looking through my stash of leftover line, I think I've got enough to complete this, but have ordered some more line from Syren, which looked pretty good and should ship fairly promptly. Looking forward to watching your progress, Dan!
  10. Thanks for the reply, Chris. Yeah, for the Lobster Smack, these were the only size blocks provided, and the 0.7mm line is what was in the marked bag. I may send an email query to the folks at Model Expo, but otherwise think I'll find a size of line that will fit the block and look good. Appreciate your input! On a related topic, is anybody buying bulk rigging line? If so, where? I like the Ropes of Scale site, but wondering what shipping delays we might experience from Canada.
  11. Hi All - Not sure if anyone is still following me, as I have had some real life stuff come up this year at various times that have put my Lobster Smack build WAY behind. The other shipbuilders that I was tagging along with on this build have long finished their projects. Anyways, I have been working on the sail and the rigging, and have another silly question. The instructions for running the lines for the throat halyard, for example, suggest using the 0.7mm beige line included in the packet. How did everyone squeeze the 0.7mm line through the smaller holes on the blocks? Am I using the wrong size lines? Hope to get this completed in the coming weeks and start a new build soon. Not sure which boat I will do yet. Appreciate those of you still following, and hope your builds are going well! Thanks!
  12. So, here's how I painted the deck, the roof, and other top-side pieces. Working on painting the hull now.
  13. Your stained deck looked awesome, @SkiBee..! I was impressed! My color scheme on this boat is... different. I'll share a picture with you in a day or two how I painted the deck, the cabin, the doors, etc. Not what I had originally planned, I messed up on what I wanted to do with the deck, so I'm improvising the rest... Ha! I was out of practice for too long this summer! Thanks for checking in, sir. I need to peek at your Phantom New York Pilot Boat progress.
  14. Hello all! Well, I took the whole summer off from the "shipyard", enjoying the grandkids, doing some traveling, and other general summertime stuff. I'm now getting back to this Lobster Smack. And, I have noticed that fellow modelers who I was following like SkiBee and bobandlucy have long finished their Lobster Smacks. I will use their great work and documentation to help complete mine. With that said, it's time to go to work... I finished the bottom planking, and did my best to fill, sand, sand more, and sand more to make the strakes as smooth and seamless as possible for when it's time to paint. I then worked on the toe rails, rub rails, fairleads and oarlock pads. As suggested in the instructions, I soaked the coaming and the cabin sides in boiling water for several minutes each in order to soften for the curves. It seemed to work fairly well, although the basswood did crack a bit on the coaming, which I've tried to seal using some super glue. It seems to have worked satisfactorily. As also suggested in the instructions, I have painted the coaming and the cabin sides prior to placing them on the deck. I am seriously contemplating painting the deck, as well, before putting the coaming and cabin sides on, as I think it will be much easier to do it now than to use the flex tape, masking, etc. Any thoughts? Excited to get back in the shipyard! Hope there is a group of additional modelers that are working on the Lobster Smack now, too, so I can continue to share thoughts and concerns. Appreciate your time!
  15. Your Lobster Smack looks really great, Bob! Congrats on its completion! I have been away from modeling for several weeks now, as we are in the middle of a kitchen remodel and all of the summer activities with grandkids. Left off at sanding the hull and will get back to it after the first of August. You guys will be well on to your next project by that time. Will try to catch up with you all sometime soon!
  16. Peeking in to your progress, Bob. Looking really good! I am getting towards the tail end of my planking process. You may have already considered this, but I might suggest painting/staining the seat before you put the deck on, as it will be more accessible beforehand. Also, when putting the deck on, make sure you line up the two halves so that the notches toward the outside of the frames are still accessible, as you will need those exposed when placing the coaming and cabin sides. Looking great, though, at this point!
  17. Thanks, SkiBee. Appreciate the peek in. Yes, using a bunch of clamps (both the metal ones and the plastic ones), clothes pins, rubber bands... Seems to work fairly well. I am now on Strake 7. My "creep" isn't too bad as I look at the guidemarks on frames 3, 6 & 9, although they seem to be running a bit short. Not sure how to make that up without some significant gaps, but may not be as bad as I am perceiving. Just looking at it in a "worst case scenario", I suppose. As I recall, though, your fill came out looking really good. Probably won't finish the strakes before I'm taking a week to visit granddaughters. I'll check back in after I'm back and I get the bottom planking finished up. Again, thanks for checking in. I need to go over and check your progress in your log, as well!
  18. Been a few weeks, so thought I's give quick update (although I said I was going to wait until all the strakes were installed)... Been doing some outside things as much as I can lately (I think it's finally spring in Kansas City!), but finished the 2nd strake on both sides today. After soaking them in super hot water for several minutes, the planks are forming pretty well next to each other, especially on the two ends. While I may end up with a few small gaps in the plank seams, a little filler in those spots should work well. They are not very big at all (so far!). So, I'm continuing to move forward... SLOWLY!
  19. Quick update... Formed and glued both of the garboard strakes. Seemed to fit well and bend well where needed, especially at the aft end. Did a dry fit then on the first starboard side strake 1, and it will need a bit of a bend at both ends, but looks like it will fit snug against the garboard along the whole length once it is softened and formed slightly. Going to work now (slowly) on the remaining strakes. Unless I have a question/comment during this process, I'll check back in once I complete the sheer strakes at the deck level. Exciting, huh?!?
  20. Well, a brief, quick update. I think (I hope, anyways) that I spent a decent amount of time fairing the hull, prepping it for the planking. There were also several of the frames that stuck out past the edge of the deck, so I sanded those spots down, as well. A birds-eye view of the boat now doesn't reveal any frames, so I think I am good. The fairing was a process, getting spines beveled so that the planks fit nicely. I think as I mentioned in my last update, if I had to do it all over again, I would probably place the deck so that all of the frames were completely under the deck and would fill the gaps between the two deck halves with wood filler after-the-fact. I have also added the stem, keel and sternpost pieces along the bottom of the central spine on both sides. They went on pretty well. Before placing and gluing the central plank, though, I had to do a considerable amount of sanding on the bottom part of the transom so that the plank set flush against the spine. Now, time for planking. I am going to take my time with this process, as well. I have looked at the port-side garboard strake to see how this is going to fit, in order to start out well. The instructions state that the garboard strakes will have the most extreme twist to them. In dry-fitting this port-side strake, though, so it fits nicely in the rabbet along the keel, It doesn't seem like the twist at either end is TOO terrible, but we'll see how it goes. When I planked my first boat, the Sailing Pram, I soaked the planks and shaped them in a curve to dry quite a bit more than what it appears I'll have to do here. Anyone have comments on how this "plank-shaping" compared to other builds? What did you use to shape the planks? I have a large wire basket, probably about 18" in diameter, that I used to help me shape the Sailing Pram. Will probably use it again in shaping these planks. There was planking overlap on the Sailing Pram, but there won't be on this Lobster Smack, so hopefully everything will fit snuggly and smoothly. EDIT: OK, so I realized as I was getting ready to soak the first garboard strake that I "form" it across frames after I take it out of the hot water while it's still pliable. It did have a pretty noticeable bend to it on the aft end when forming, and I think it came out well, as it fit nicely in the rabbet. Glued it in place and will let it dry overnight. Will work on the starboard side tomorrow. Thanks to everyone who reads this. Appreciate your comments/suggestions/critique.
  21. Congrats on the completion, Bob. Looks really nice! Know the feeling of being finished... So... what's next?!? lol
  22. Thanks, Jim! Thanks, Jack! I'll look at those vendors' websites. Appreciate the guidance. Gregg
  23. Somewhere on the internet (I think it was on somebody's thread here on MSW), I saw a picture of someone holding a mini rafter square. It was small enough to be useful in squaring bulkheads, etc. Anyone use such a tool? Where did you get it?
