DmitriyOG
  1. So Im debating still on how to proceed with these cannons. These are the types Iam planning to use for lower deck. As you can see the middle fat cannon in the below pic can only go in by it self and they do look good and big. 2 on the left can be turned in to a 3 pair. 2nd from the right is the 4 multi canon set up, as a single cannon it looks pretty tiny in the pic below. The first from right probably best used as solo as well. Keeping in mind, pirate ghost ship set up cannons should be a little interesting thats why Im thinking to put some multi cannons
  2. @Jeff T hey what do you think of such cannons here. Im thinking to use a few multi set ups. Just to make it look more scarier
  3. As promised some updates. For now gold glitters. All the gunports in and working. Cannons and chains are coming next for the lower deck.
  4. Hey every one! Thank you for checking my build out! More modifications have been done. Pics are incoming later tonight
  5. All the gun port chain entry points r done. And primed with gold. Also anchor chain hole decor complete primed in gold as well
  6. Well I havent had a chance to get to it yet. Will keep you guys posted. Coming soon in the next couple of weeks mb even this sunday, we shall see if I have time.
  7. I have been debating with that. Will be experementing first to see what works better. This weekend should be some progress thou.
  8. Originaly I wanted only 1 chain attached to the lids. Since they were metal and I had to drill them out, corner holes were best option
  9. It will be very time consuming per canon. I need a rope/chain entry in to the hull. Driling a hole wont suffice. I have started on some decor-square pices to mount to run the chain thru. Not much luck yet on production. I will need around 46 entry points. Pieces I am trying to make arpund 1 mm thick Very hard to cut identical thikness. Almost imposible to sand after as they are tiny
