Wreck1919
Members-
Everything posted by Wreck1919
🤪..yes. By the same logic playing the piano is easy: simply push the key with your finger - and voila - sound 😎
Да , ты всё понял. Спасибо. and the construction of the plaform is your „usual“ soldering magic 👍🏻😎 very impressive. С.
Privjet Valeriy, can you share a picture of how you built the platforms ? cools stuff. Regards sascha
Thanks for your comments guys. A bit of update: didnt like the capstans, so made new ones (brass/wood) plus the chain deflectors . Lashing chains (? English?) are now also there. Bit of work that as it required to remove the studs from the first two links of the anchor chain and then threading the lashing chain through it and finally getting small shackles through to fix it to the eye on deck. Will need to touch up some paint as it took uncounted tries. some progress on the bridge with some interior „decoration“, glass for the windows. Built the 3m rangefinder and made my first piece of railing/handrail. latest were the first bollards plus fairleads (rollers still missing) .
Thanks for step-by-step Lecrenb. Wondering why you make the frames in halves, but will keep watching/reading. Look forward to more. 👍🏻
Thanks for the interest guys😀 mikegr, through a tip i found a company that delivers (mostly) precision cut wood in 1m lenght. So these are 1.5x1mm pear. Planks then cut to 6cm lenght (knife), caulking applied w black crayon. Valeriy, no worries j hope. Outside is fiberglass/epoxy over wooden frame, and inside just painted epoxy. Some areas in bow and stern reinforced with fiberglass. wood is btw balsa on (too thick as you mentioned😎) plywood frames. greetings sascha
Thank you for your likes guys 🙇♂️. Valeriy, the answer is simple and no sophisticated background: i‘ve always built with wood and some brass as i didnt know different. Only learned last year that a company like evergreen exists 😬. With brass i can only do basics since soldering is rocket science for me and no machinery (lathe or mill). Jeweler‘s saw and drill currently. But all - i hope - wooden surfaces inside or out are treated with epoxy or similar so i hope that this works. The wooden decking has a triple cover of clear paint (dont know the exact english term) so that should suffice for occasionally getting wet (not sunk😎). Watching builds here and on a german forum shows me how much more there is to learn. cheers sascha
Thanks for the nice words guys. Hi Martin, am trying to copy your technique for the deck (and some others 😬). It is indeed a puzzle, and with a steep learning curve 😎. Also now wrestling with a problem with bridge complex, as the plan i have shows - i think - partly a different ship and then the plan author invented a bit. Photos i have look different. Will keep looking for answers (which is how i came to find this forum).
Thanks for your thumbs up gentlemen. Further catch-up. the next pieces were the boat racks (sorry dont know the english word). There‘s quite a few to make and most are slightly different. On top comes the consideration of how/where to attach as the middle section (superstructure deck with funnels 2 and 3) is removable to get some access to rc. I‘ve tried brass and wood and settled for „brass reinforced polystyrene „😎 . Another case of available tools and my skills. The ones toward the bow also had loading cranes for torpedoes but i left those away and only built the mounting for them. This because a) they would have been stored somewhere when sailing and b) they would likely be the first thing to be ripped off when sailing the model.
Then my first try with making a linoleum flooring. The pieces were max 2x5m and held down with brass pieces. That translates to a puzzle.. (again thanks martin for the tip). then it was time to throw my machinery 😎 at making the portholes. Sometime i‘ll get a power-tool for things like this . Brass tube, then filled with epoxy. Just 120 …took me a while but its a hobby not a job. Oh and yes, (quite) some of them are not aligned. With practice that might improve.
