Everything posted by Admiral Beez
Nail polish remover (acetone) will quickly remove CA from your tools and anything else. My tweezers sometimes get clogged with CA, so I keep a glass jar of my daughter's nail polish remover with stainless steel balls in the bottom to raise the level. I then leave my CA encrusted tools in the jar for perhaps ten minutes and they come out looking brand new.
The book on rigging has been a godsend for this project. I may not be to Royal Navy spec, but my rigging will be as close to the book as possible. My custom pin rails seem to be working out nicely. The kit only provides about ten sets of blocks, so I am using them sparingly across the build.
I'm pleased with how it turned out. I bought a micro pin vise drill to ream out the holes, necessary as some of the CA glue blocked them. We'll now start installing the running rigging, running it through the holes in the pin rails below - but not knotting it permanently until I am sure there are no crossed lines. When we're done I'll mock up belaying pins.
I bought a sheet of v-groove styrene today at my local hobby shop. I was trying to figure out how I was going to hold the usual small styrene strips down to drill the holes so I could pull the running ringing through them. But with the styrene sheet I can drill the holes before I cut it. And I have lots of material for trial and error. My goal is to have the running rigging done in a few weeks.
That's a good idea. Did you affix a vertical support underneath to keep them level and help adhere them to the hull sides? I like how you've replaced the central stairway to the poop with the traditional British separate stairways. I'd already painted and assembled mine by the time I'd realized that was needed. So, in my mind my ship's recently captured and not yet fully converted to RN spec.
I've gone as far as I wanted on masts and booms. I'm stuck at the moment as the running rigging can't get around the belaying pins as provided, so I must pull them off and redesign it.
All standing (black) rigging complete, all yards (less the mizzen booms) now hoisted. Now onto the natural (tan) colour running rigging that will straighten out the yards. I’ve switched to natural line for the topgallant yard lifts.
Standing rigging and ratlines now complete, less bowsprit shrouds (WIP). I should get through the yards, sails and running rigging fast enough. I think this will be the last (and my first) rigged model I build for a while.
Landlubber Mike's technique for furled sails
Admiral Beez replied to Landlubber Mike's topic in Masting, rigging and sails
Thank you for sharing this. I shall give it a go. -
Some progress. Just eight more sets of rat lines to make. The white paper structure is to prevent ratline trimmings from falling into the waist.
The ratline harp tool didn't work for me, perhaps because my shrouds are too wide at the top. If someone else would like this tool and would pay for postage you can have it. So, here's what I'm doing for my ratlines. I've taken the original Heller shroud tool, cut out the middle piece and then wrapped around this 0.25mm horizontal lines (the 0.4 mm vertical lines are already on the line). Then I coated all these lines with clear craft glue diluted with water. Then using a wide paint brush I covered the lines with the glue/water mixture and left it to dry overnight. In the morning I repeated this treatment, leaving it again overnight. On the next day the lines were now stiff with glue. I then cut these off and basketweaved them around the vertical shrouds, followed by each intersection get a dab of clear craft glue with an old paint brush. So far I am happy with the look and am pleased to have finally found a method that works for me, helping me to overcome the procrastination that's delayed this project for a year or more.
Alrighty, we've today received the ratline tool. I realize now that I should have waiting before tying the line between the port and starboard shrouds as now I must cut something to fit the ratline tool. Anyway, I shall report back.
Main and Fore Preventor Stay
Admiral Beez replied to Admiral Beez's topic in Masting, rigging and sails
Thanks. I don’t see the crows feet on most Napoleonic era models. Did HMS Victory ever have them? -
No, it did not work - it was just a mess of broken lines and a waste of thread. I therefore today ordered this tool to help make the ratlines https://houdinimodels.com/harp/ It's made for the 1/150 scale Heller model I'm building, and the videos online look easy enough. On the plus side, my stays are coming along nicely. Notice the last picture where I have placed a long carbon rod with a green tape flag at the end. That's to prevent me from, once again, breaking off the jibboom with my "jimmy hand" as I move around the model.
Newbie question here. On my model build (see here) of Heller's 1/150 Le Superbe (but built to a British fashion), the front of the main and foremast top platforms have a line of small holes. The image below says lines from these holes should connect with the fore and main preventor stays, but I do not see this feature on other models. Maybe it was a French feature I can ignore in my captured HMS vessel?
Topmast shrouds now complete. Ratlines are next. I’m considering using the Heller shroud loom for just the horizontal lines to create the ratlines without having to tie hundreds of tiny knots. If it works, I’ll CA glue the hardened horizontal lines to the shrouds.
Ready to begin the upper shrouds. The rigging around the tops was tricky, and when I had the window open in the rain, the damp caused all my lower shrouds and stays to droop. Thankfully when the weather improved they tightened again, but this made me think of the men on the high seas having to constantly adjust line tension with the weather. My ship will live in a sealed plastic case, so the weather outside shouldn’t impact the lines.
Fabricating the futtock shrouds using 0.4 mm chord and 1mm carbon rod. I tied them at the bottom near the deadeyes, and then pushed them up to just above the first ring on the mast, matching the blueprints. I then CA glued the knots to the shrouds, and trimmed off the excess chord.
Proper stays now installed. I was looking at the shrouds and thinking how to keep them spread for the ratlines. I then realized this kit does not include the lower futtock shrouds and catharpins needed to spread the shrouds and to secure the top platform deadlines from below the top. I suppose Heller didn't see these as necessary since their shroud tool does the job. So I can fabricate these myself.
I’ve decided to not use the Heller shroud tool and instead thread them myself. Here’s today’s update. Disregard the forestays, those are just temporary to prevent the shrouds from pulling the masts backwards during installation.
Before I try the shroud tool again I've decided to install the deadeyes to the chain whales, so that they'll serve as a guide for shroud alignment. The deadeyes are all painted and clear coated. The outward face has simulated rope, the backside is flat. My plan is to glue the shrouds behind the deadeyes (as per the Heller instructions) and then paint the portion between the deadlines with the tan colour used for running rigging (see HMS Victory below). At this scale I think I'll be happy with that.
I shall give that a go. Before I string in the horizontal threads I will first check alignment with the holes in the chain whales.
