munst3r
Posts posted by munst3r
On 10/25/2021 at 3:59 PM, MrBlueJacket said:
Hello @MrBlueJacket, I'm also working this model. Question. The instructions state:
Is that accurate? Drill a hole all the way through? Looking at your photos, it seems you did the same.
Added the Bulwark Cap and Rail Cap. Sanded down excess glue, and am priming it again. (Shouldn't have primed it earlier. Rookie mistake).
The instructions recommend sanding inside the railcap. I assume to bring both the railing and boat in-sync. After reviewing, I felt this was overkill for a railing inside the boat. I left it as is.- king derelict, GrandpaPhil, gsdpic and 2 others
- 5
Then I applied a coat of offwhite primer spray paint:
After sanding, I filled holes and gaps with standard drywall filler.
I accept that this shoddy work, but I'm not ready to move into precision work. Its my first model, and I want to keep this moving, and not stop for want of proper equipment. I will probably take other shortcuts to complete this model.Post Sanding:
Then I applied the filler to even out the holes
The ship hull had excessive molding on it, not sure why. Maybe this is normal. I had to sand all this down, 15 min job.
Hi Everyone,
New to ship building, and started with the Schooner Wendameen by BlueJacket Shipcrafters.
Hopefully a useful blog as I only see one other user building this boat at the moment.
Simple unboxing pics:
- Duanelaker, ccoyle and GrandpaPhil
- 3
Wendameen by munst3r - BlueJacket Shipcrafters - 1:87 - RESIN - schooner
Bunch of work completed:
Drilling out holes
LongBoat
Next steps: Painting the hull. I'm awaiting the arrival of the paints.
