Everything posted by HIPEXEC
	Can you post the prints for the Connie's "spanker". Constructo's plans are very poor.
- 1,756 replies
- constitution
 - constructo
	These photos finally do your ship justice! Great job. I'm glad I got to see it up close. Your work is excellent.
- 831 replies
- Armed Virginia Sloop
 - Model Shipways
- 1,756 replies
- constitution
 - constructo
	I've got the jibstays half done. I knocked my model crooked in its cradle so it looks like she's charging on a larboard tack.
- 1,756 replies
- constitution
 - constructo
	I'm stopping rigging the square sails while I rectify the Constructo omission of not telling me I needed jibstays. I should have known better since I sailed for several decades on modern fore & aft rigged boats. They all had jibstays. I placed a rubber absorbent mat under my work area to "catch" fallen tiny hanks. I dropped most of them and it caught all but one. Goodness knows where all these little dropped parts disappear to. Now that the brass hanks are on the jibs...I shall attempt to install jibstays.
- 1,756 replies
- constitution
 - constructo
	These are great plans...I shall refer to them the rest of the rigging progress. Thanks
- 1,756 replies
- constitution
 - constructo
	Here I'm practicing making a splice to a stay. The rigging plan calls for most braces to be rigged with a block and a line spliced to a shroud.
- 1,756 replies
- constitution
 - constructo
	That's what I figured. I wonder why Constructo eliminated the jib stays? I'll probably retrofit jib stays once I can figure out how to do it easily.
- 1,756 replies
- constitution
 - constructo
	Now that I've rigged the two foresails (jibs) according to Constructo's plans....I'm puzzled why they hang like staysails instead of being run up and down on jib stays? How are the actual jibs on the real Constitution set?
- 1,756 replies
- constitution
 - constructo
	Jack, Frank, Geoff and all of you....thanks for the support & help.
- 1,756 replies
- constitution
 - constructo
	Slow and not very sure rigging progress. I now have to buy some very long tweezers and sissors since it's getting very hard to reach into the inner recesses to attach lines to belaying pins. I have drilled some sheaves to run lines through the gunwales.
- 1,756 replies
- constitution
 - constructo
	The actual ship used for the movie is in San Diego. It looks a lot like the Connie.
- 1,756 replies
- constitution
 - constructo
	If you want great reading about the ships we build, check out Patrick O'Brian's Master and Commander. It was very good. Now, I'm on his second book.
- 1,756 replies
- constitution
 - constructo
	I took Bill up on his idea to just remove a belaying pin and run the line through the hole then re-insert the pin. It works great!
- 1,756 replies
- constitution
 - constructo
	Well my rigging is progressing very slowly while I learn "the ropes". However, since all my rigging works...that is, all the rigging can be adjusted, I don't want to tie anything down until it's all rigged. What to do with the "rats nest" I've created?
- 1,756 replies
- constitution
 - constructo
	Now you all see why my rigging has slowed down.....I must figure out how these square riggers sailed. I'm reading all the Patrick O'Brian books starting with Master and Commander to help me, as well as all of you. Thanks!
- 1,756 replies
- constitution
 - constructo
	Here I'm putting some wind in a jib. Rigging the jibs makes easy sense to me. The rest of the rigging still remains a mystery.
- 1,756 replies
- constitution
 - constructo
	Progress is going to be very, very slow while I figure our exactly how to rig all these lines. I really need to see a picture of how a block is attached to a shroud so the line doesn't hang on the hammock nets. Drilling holes is difficult for me to bring myself to do, but I probably will create sheaves.
- 1,756 replies
- constitution
 - constructo
	Thank you all for this amazing help.
- 1,756 replies
- constitution
 - constructo
	Thirteen pictures are worth a thousand words....thank you so much!
- 1,756 replies
- constitution
 - constructo
	Thanks George and Augie. I'd love to see a picture.
- 1,756 replies
- constitution
 - constructo
