MeandSuzy1
1 Follower
  1. Well i ain't been here in a while cause ain't been well enough to work on my project. But recently I thought I'd get back into her by serving some ropes. Bought a Chinese sanson server..instructions only in Chinese... HELP
  2. I'm gonna start some exterior planking.. rather than hammer taping which I've found inaccurate and loosens things is there a good way to push nails in Thanks guys
  3. Well part of me is back guys. I hardly even figured out how to log in. I was taken off a 21 yr string of a pill called clonazepam in early June. Put on antidepressants. Been on 4 different strings now. Each fail and my cognitive ability is worse each second. I look back and don't even remember putting the earlier pictures up. If I do anything inappropriate I apologize in advance. This is the worst thing in the world. My once not too bad of a mind is gone. I started rounding 4 some planking today. I'm gonna try something simple
  4. I'm back temporarily guys.. just a quick post and question.. I "think" I'm ready to plank hull. I'll have to figure out how to conceal wires as I go,but. What i think I've figured is I got to dremel radiuses on ribs so as to allow planks to form. I'm cutting guncase foam to fit in hopes of not trashing stuff inside.. any pointers appreciated
  5. Starting another cutlass. Found a piece of cheap costume jewelry for blade. Looks Damascus. Gotta clean glue off when dry
  6. So this is so far Sorry bout dog slopping water guys 20220817_193613.mp4
  7. Thanks buddy Put it on a wee pedestal I made. Cut top off a small AL barrel. Hallowed a Qtip shaft. I think nicer cause then the wire can go under deck
  8. Built a wee lantern for over plant pot area. Piece of ball point pen and used Milwaukee m18 lathe to turn little fineals for ends
  9. I made my upper grating a bit more robust. 4mmx4mm walnut (yes I'll probably run out of some woods) .. oh well. Squaring up the gratings to glue in.. I use one side of real sharp toe nail clippers. Clean. I put them together at approx length, then mix 50/50 white glue and water. Brush it on back side. Let dry then form to final size
  10. God I'm gonna talk to you directly some day you don't mind. I got a feeling you've forgotten more than I know
  11. Does anybody know how many nails are required to do the outside of an AL bounty model ?
  12. It's hard with those wee sliders to look 1700's and not like the teen end tables in my grandma's living room...however, . Some walnut gel stain gives brush strokes and darker kinda helps
