Twokidsnosleep
Members-
Everything posted by Twokidsnosleep
What a most thorough and excellent answer SHJ This is why I joined here, just great advice on this site so far I am a woodworker so clearly understand your lesson. I was worried I was missing that this wrapping tied into the rigging somehow, but could not see that on any of the research pics so far. So your answers absolutely makes sense and I thank you a ton 👍🏻😎
Working on the foremast I believe this is called I re-inforced the mast with a wooden dowel ála Mr OC And then took it to the lathe to remove the six moulded rope windings so I can add the Ropes of Scale rope I was fully prepared to make a wooden mast if this broke or I FUBAR’’d it Was careful and it came out ok, but the styrene is very flexi on the lathe and so hard to turn concentric Now in primer to get the oil paints today Edit: added the oil painting pics
Thanking OC for another modification…the catheads to support the anchors 3D printed out a couple of lion heads in various sizes to make the carved face at the end of the beam The Pearl has the carvings, though hard to see some research pics, this isn’t the Pearl My 3D prints and the styrene beams I have a couple back ups and larger versions to test out my patina paint efforts for weathering You can dial down the sizes on the print program so these are 10% , 2.5% and 2% of the full figure size. It also correlates the sizes in mm’s
I gotta get my wiring into the hull now so I can move on and keep the build going forward. Managed to fry a couple orange LED’s in my test circuit wiring for the lighting🙄 The calculations said I was ok with the 3 volts and specifications of the bulbs but clearly not. I had to put a 100 ohm resistor on the positive line and then it was all ok and no smoking E8B45A5D-0BB2-4886-B844-9173451F118E.MOV
Thanks Jeff , I am glad you like them….still think I can do better and get cleaner/sharper details at 1/72 but it is hard Priming: I do a flat black…stylenrez or Ultimate model products Weathering wash: I made a “magic wash” one flat and one clear. It is just clear acrylic+india ink. At 1/72 scale I think it gives too muddy a look. Jack sparrow got the wash and Gibbs didn’t and I think Gibbs looks better. The larger scale Jack sparrow definitely got acrylic magic washes. Before leather I prime a loose layer (ie not super dense, thinned slightly) of a tan primer again stylenrez, then oil burnt umber on top and you can wipe some off before it fully dries to show wear. Other brown oils can be used for lighter leather For faces: Flesh is Tamiya flat flesh..but I think vajello or citadel might brush paint easier Trick layer is a coat of a rusty red stylenrz, very thin like a glaze. It gives a reddish alive with blood look to the face this is a good video summary of faces and pretty much what was done
Made some more of the deadeyes today. I have about 25 more to go to get the 130 or so I will make Switched gears and worked on some figures to bring the ship to life Modify the same set of figures OC used. Made two main characters of POTC, Capt Jack Sparrow and Mr Gibbs I like this one. They stand at the wheel watching the sea, missing most of their boat, but that is beside the point
Is there a trick to making deadeyes?
Twokidsnosleep replied to Schooners's topic in Masting, rigging and sails
This is another old thread I am going to pull up and add my two cents ( no sense) to I again thank each end ever one of you who commented, provided photos or referenced material to help a newbie figure out how to make these. I did a little video to show what I came up with to make my dead eyes. Maybe not perfect, but absolutely workable for my 1/72 Black Pearl kit modifications.
