CTDavies
1,925 profile views
  1. Good evening All! The first planking on the port side is now done. I think it took me close to two months to do the area below the main wale, although I very rarely do any modelling during the week. The material used is 4 x 1mm boxwood throughout except for the wales which is wallnut, and I eyeballed most of the planking, trying to follow the real way of doing it, just to get a feeling of what to expect when I do the second planking. 4 x 1mm turned out to be the easiest to use as it shapes very well with soaking and applying heat. I learned the hard way that pre-shaping the planks is essential, and best achieved with heat (an iron) soaking for a short while beforehand. Although it's not strictly accurate, I do know now what I need to watch out for. The bullwalk outer skins haven't been planked yet as I actually want to build the Diana as she was when she left the shipyard, i.e. with the lower bullwalks. The instructions says to use a plywood skin pieces for the later version but I couldn't find them either in the kit or the parts diagramms, so i guess these parts were abandoned at some time during the production. I'll decide as I go along. 4 Unfortunatly like most other ship models, this one also has an other side. Now I need to pluck up enough motivation to get started there. Thanks for stopping by. Comments are welcome. Chris
  2. Here you can see a very slight dent along to planking... ... this was pried carefully away from the former with a sharp chisel and a hammer (you can see the gap)... ... which was filled with a superglued balsa shim... ... run of the planks saved.
  3. One thing I totally ignored was 'am I achieving a nice even curve with the planking when viewed from the top'? I noticed that I wasn't when I was way into the planking. The instructions does say 'The edges of the bulkheads must also be bevelled and shaped to follow the run of the planks', but who needs the instructions, eh? So instead I placed thin balsa shims where the run was uneven and caused dents and bruises. In some places I had to part the planking strip from the bulkhead with a sharp chisel. Checking the run of the port side plank: Shim pieces installed on the starboard side. These will be cut down after planking and the next layer will be started again from anew. Also it turned out to be beneficial to connect the individual planks with strips from the inside. I use thin super glue for planking and hadn't glued the planks to each other. So the skin wasn't rigid which made sanding very difficult. In some places I also ran a line of thin super glue along the planking joints to add rigidity. Taking short cuts on the first planking can cause problems later on. This is where I'm at right now. Thanks for checking in, Chris
  4. Progress ist still slow... I'm using Walnut for the wales and Boxwood for the rest. I ran out of Boxwood just after I had started so I ordered a bunch 4 and 5mm wide strips. Not only was this new material much darker than what I had it was also much wider. So I can only assume what I had been using below the wales was 3mm material. Bummer (although it measured out to be 3,5 of 4mm). I want to stay with that width as it is a lot easier using and shaping narrower planks although it might be more work in the end. Above the wales 5mm was used as the curvature was mainly in one direction and no shaping with water was necessary. I didn't check if the formers produced a nice curved line and did end up with some deep ends and higher bits. As I was moving ahead quite swiftly and enjoying it this was only noticed after a few planks above the wale had been done. Below the wales wasn't an issue as the balsa fillers assisted in a nice and even curvature. To rectify this I used thin Balsa packing strips placed stratigically where needed between the frames and the planking. A bit of wood filler was needed here and there. Remember this is the first planking, but I want to do this right to avoid extra work when I'm doing the second.
  5. Progress is slow. This is the first planking. However, I thought I'd accurately position the main wale etc. to 'get a feel' for what's coming up on the second planking. But now I need to order more boxwood.
  6. Got a few days off over Easter Hope to get some more done tomorrow and on Monday perhaps -- Chris
  7. No real reason to be overly meticulous here, as this is actually still the first planking. But I think it might help in the long run to do the first planking exactly like the second to get 'a feel' for the quirks of it all. Sort of a full dress rehearsal. We'll see... For the wale I'm using walnut, for the rest I will be using a lighter wood, maybe boxwood, for a contrast
  8. Thanks, No Idea, that's very kind. So now, after 10 years, something exciting is happening: the main wale. This is probably the most vital part of any scale model boat. Get it wrong and it will jump at you for ever like a tooth gap in a smile. So I'm taking my time with this. I used the side view of Sheet 1 and measured the distance from a reference line below the keel and made a pencil mark on the model at the precise point of the bottom line of the wale. The reference line was actually the building board where the model is mounted on. Dimensions drawn onto the Sheet 1... ...and the point of the bottom line of the wale transfered on the formers, according to the dimensions Taking my time with this, but hopefully not another ten years Thanks for looking in, Chris
  9. It is almost 10 years ago to the day that I bought this kit. This is far too embarrasing, as the saga with the lower deck continues. I did the columns yet once more as I found an online dealer who had ones for sale. Although they had a square profile, they were easily rounded off by fixing them in a Dremel and shaping them with a file. Although far from 100% scale accurate they were good enough for this purpose. In the lower deck they will be hard to see once the upper deck has been added. Finally the whole thing could be buttoned up and the false gun deck glued in place. So what I did in the past 10 years is basically the first chapter on page three. Instead of adding the hatches and planking the instructions says here 'Stain the centre section of this deck Walnut as a small part is just visible in the completed model'. Filling the space between the bulkheads is also not required per the instructions, I did this because I am hoping for some benefits when planking the hull, which will be the next step. I turned 64 just before Christmas, so I have at least another 36 years to go, so I'm in good shape so far. Chris, from Germany
  10. From our short holiday in Den Helder, north-west Holland. Previously know as Willemsoord, this is where the Dutch Royal Navy was stationed for the past 300 or so years. This is the No.1 dock there, where the (ex HMS) Diana was destroyed in a fire. This place is a lot like the historic docks in Plymouth and I’m going back tomorrow to check some of the historic buildings there.
  11. Thanks Dave, that was a very kind comment. I'm hoping I will post much more in future, although progress really takes time. I wasn't really happy with the pillars even in yellow ochre as they also got lost in the depths of the lower deck, so I decided to go all out and paint them white, at least the upper half of them. From what I have read the ship's captain had the right to 'personalise' his ship and paint it including its interior as he felt suitable. From brousing through books I couls see that on the Victory they were dark brown or black, on the Trincomalee also but on old pictures of the Implacable I could see two colour tones, so from this I assume there wasn't a strict code to adhere to. So mine are now white, at least the upper half of them is. I also painted the gratings gloss dark brown so that they remain conspicuous once everything has been buttoned up. Not 100% accurate but at least they can still be seen from the top, but only just. I started on the ladders just to see how they all fit into the scheme of things. Maybe a bit too chunky? The gun deck gratings will eventually cover everything up here, but I will leave the hatches open as if the ship is being loaded right now. A PIA was me being ham fisted all along and breaking off the the extensions on the bulkheads for the bulwalk planking and quarter deck beams. I decided it was time for a real fix here. Oh yes, extending the front main hatch as described in my previous post was wrong. So this was reversed.
  12. Fantastic answer, Henry!! I'm sure what you wrote about the Constitution also applies to the HMS Diana. I still need to dig into this a bit more though, as I'm not sure what a Viol is, but you've helped a huge bit forward. Thanks!!
  13. Good evening All, I've noticed something that seems to be unique on large frigattes concerning the handling of the anchors on large frigattes, maybe not only British ones. On HMS Diana (1794) the hawse pipes are slightly abover the upper (gun) deck. The riding bit is behind them on the same deck which means the cables enter the boat through the hawse pipes and remain on the upper (gun) deck at least as far as the riding bit. The cable tier on a large frigatte is about midship (according to Tosti) but two decks lower. My question is, where does the anchor cable pass into the lower deck and from there into the hold area with the anchor tier. I'm assuming a manger was behind the hawse pipes to scrape off the wet cables before these moved to the riding bit. But after this there is a gap in my trial of thought where the cables were connected to the messenger via several 'nippings'. The messenger must have been mounted right under a deck, via rollers. But which deck? And where did the cable drop from upper (gun) deck to the lower deck and from there to the cable tier? On the Victory this is easy. According to Nepean the hawse pipes were just above the lower gun deck. This is also where the riding bits were. Right under the lower gun decke was... (you guessed it) the cable tier. I hope I'm making sense here... Any help here is greatly appreciated. Chris
  14. I was a bit disappointed to see that the black pillars got totally lost under the upper (gun) deck so I painted the middle section yellow ochre hoping this would improve their visibilty a bit. Also, I still needed to add some gratings to the lower hatches that needed to be scratch built as the kit doesn't provide any materials for this. For them I ordered some generic items, which compared well size wise with others I have for 1/64th scale boats. At least the pillars are now slightly visible, heaven knows how conspicuous they will be under five or so jolly boats, though. But to get the gratings more conspicuous I painted them (or airbrushed them is more correct as most painting I do is done with an airbrush) gloss black. The reflection of the gloss paint helped them being more visible and, although they might be too glossy as they are right now, I might just leave them this way to prevent them from getting completely lost under the upper (gun) deck and boats and wotnot. I was thinking of adding anchor cables, but after some studying I realised that they were up on the gun deck. Question here is, would the messenger be in place all the time or would it be removed while the ship is out at sea? The anchor cables probably disappear down into the orlop deck holds through the very front hatch, but what about the messengers? Please tune in...
  15. The lower deck looked a bit bare, so to add a bit of business, I put some pillars where I expexted some would be. The AotS didn't show any but there were some on the Pandora drawings from which I could make an estimated guess. I also looked around a bit to find some information on the colour the could have been, and while Victory, Tricomalee and Unicorn are all pretty much the same here, the Victory's pillars were painted black as well as the coaming carlings. Problem with the pillars being black is, you can hardly see them once the gun deck is on. Oh well, I know they're there... I'm glad I didn't add any ladders here.
