Patrick B
Members-
Everything posted by Patrick B
Thanks for the info allanyed, good think I stuck ( without making a bad word play ), with CA glue. My only concern is that I have sometimes a little bit of glue that comes out on the sides of a plank. I try to sand it until it disapeares, but I hope it won't show when I will apply the Tung oil. Anyway, here is the progress of the hull. Please inform me if you see any CA leakage.
Planking update : The first side is finished planking. I am very happy with the result, as no wood filler was needed whatsoever, and little to no sanding was done too. Due to the carefull attention in the planking process, no "steps" where created. I leaved the nails in, contrarly to the popular behavior, as this didn't affect the sanding process at all. This choice was made because of the fact that I posses a nail pusher. Without it, I would have certainly took the nails off. I leaved the nails in, contrarly to the popular behavior, as this didn't affect the sanding process at all. This choice was made because of the fact that I posses a nail pusher. Without it, I would have certainly took the nails off.
You are right. But I still like the appearance of the 1-3-1 thwart pattern. This being my first ship, I incourage you to inform me about these interesting tricks the old sailors know. Keep in mind that I might change some other things afterwards if not too much added work is needed. I am very interested in those small tweaks that coulds make it more realistic.
I have bought the Beagle in the last 3 month, and a couple of things have changed. -The stained plywood was changed to solid africain walnut -The other mixed sheet was changed to solid wood (unknown) -The launche's sheet was changed to mdf -The blocks have changed again to (box?) wood -The little cylinders made from brass where changed to (box?) wood also. -The stained plywood stand was changed to unstained plywood. See photos
All right, I made a mistake. Not a modelling mistake tought. I went to one of my relatives, and brought the hull to show them the processus of ship building and how far I was. The thing is, I forgot it there. The good news is, I will go to this person's house again in about 2-3 weeks and I will be able to bring it back to the shipyard. In the meantime, I will be doing the several launches. Here is where I'm at for the (23 foot?) one. I don't think I will be painting it white if I do a good enought job on the hull.
