3DShipWright
Members-
Everything posted by 3DShipWright
First off, the hull is not bad as is, but yes, there are a few anomalies that can probably be fixed. To my eyes, you actually have dents more than bulges, but the fix I propose is the same either way. A couple more slightly more feasible alternatives than redoing the hull: 1. Use a 'Smooth corrective' modifier with 'Pin Boundaries' and 'Only Smooth' selected, placed higher up in the stack (above any sub-surf unless you're willing/able to apply the SS first). OR 2. Light sculpting, specifically the fill tool (low strength, broad radius, top-to-bottom strokes), followed by the smooth tool. General philosophy here would be expand areas first, then subtract. Again - the model still looks good in current form, so it'll be up to you to decide if the juice is worth the squeeze. -Nate
Looking great Kurtis! Not sure how you plan on doing the rigging, but as a comparative performance estimate: My brig is around 1.35Mil vertices with no rigging and 5.98mil vertices with. That said I did a few 'uber high poly' lines where I thought I may want to do closeup renders later, but even without those, I'd estimate that the total count with rigging to be about 4.25mil (currently I'm about 80% done with rigging), or about 75% of the actual mesh when all is said and done. I'm using 10-sided cylinders as in the base rope segment. If you can back that down to octagons, you'll shave 20% off the top + an exponential factor (my math is good, but not that good) when you merge duplicates caused by the segment arrays. Whatever you decide, keep up the good work! -Nate
Okay - I see the problem on the stern port height - and yes, it is the deck itself. I wrapped the deck in a black stringer where the deck planks meet the inner hull. While this is accurate for the sides and the bow, the stern has a series of two-three planks that quite literally curve up to where it meets the back wall. Let me see what I can do.
Argh - That's truly frustrating because I did it the way you described on a previous model and someone told me that the plan lines were inclusive of the planking. Now you're telling me that there's misinformation on the internet?!? Say What??? Lol - still with a maximum breadth of 30 feet 6 inches and external planking thickness of 2 inches (x2 sides) we're talking about a disparity of 4in/366in, or 1.09% - I'd hardly call that a 'severe' problem. As Jack Sparrow said, 'You need to find yourself a girl, mate!' Sincerely though, thanks for all the support.
So not having comprehensive documentation on a single ship or class of brig when I began (my fault, and it won't happen again lol), this project has been - since its inception - a frankenstein. Only now do I realize the monster I created asking a community of nautical historians/enthusiasts their feedback, as each person approaches this with a pre-conceived notion of a brig from a specific time period and a specific configuration. I will also say that nothing I did was pulled out of thin air. @mtaylor and @druxey - I agree that a poop deck that small may seem pointless/arbitrary, but it's not if you stop and think about it: It's elevated enough to allow the captain a vantage point without having to go aloft, and that's all it was intended to do. It's actually called a bridge deck, and sources I've read assert that it was the origin of the term 'bridge' for the command point on a ship. The USS Niagara has one and it was part of the original 1813 build. That said, I'm extending it and I will be adding deck house underneath it soon. Give me some time to incorporate your suggestions and I'm happy to take additional thoughts/comments. Best Regards, -N.
Yep, on it. I gotta take it plank by plank so it takes a while. I think I'm going to bring it a bit further forward still, but I'm pausing here till I build the paneled closet dividers.
Okay, I've stripped down the stern, only keeping the corner ornaments and the basic trim board. The rudder chain will be re-positioned once I get a general idea of how the steering rigging will go. Tiller has been modelled, but I still need to rework the back section on a large scale
@Martes - Ahh, gotcha! So I can incorporate a wheel if I cosmetically like the look of it (which was kind of the whole reason I did one), you're saying I just need to model the tiller on the top of the rudder as well.. Perfect, consider it done! The model you're showing is really good - Would you mind sharing a few more images of the back-end detail for reference? Any actual diagrams or dimentions of the tiller? As a general rule, if I eyeball something it comes out wrong, so i'd like to start as accurate as possible. Regarding the rudder chain, no problem - I'm using curves and the array modifier so its easy to reposition. Something felt wrong about the way I'd done it anyway, I just couldn't put my finger on it. @druxey - Yeah, as both you and @Martes have alluded to - I think I need to make a decision on whether I'm going for real or creative, historical or retro-fitted. Tell ya what - I'll first complete the model realistically and historically, then when I'm done, I'll duplicate the project and go creatively nuts! Does that work for everyone? Lol Thanks guys, much appreciated, as always. -N.
@Martes And the taff rail I did is pretty low, I think the angle of the image may have been deceptive. Here's a character in the scene for reference. She's 5-1 if that helps. Best, -N.
Hey @Martes - No offense taken, I always appreciate constructive feedback, and hopefully you noticed that I already incorporated some of your previous suggestions. To unpack your comments a bit: Metal Rings - I believe those rings are sockets for supports when the ship is in drydock. Google real images and you'll notice that they can be seen on the HMS Victory in Portsmouth, the HMS Surprise (Rose reconstruction, renamed for the Master and Commander movie) in San Diego, the USS Constitution in Boston, and so on. The Anatomy of the Ship illustrations also show them on the Pandora and Essex, so I'm guessing they're not a new invention. Wheel vs. Tiller - The picture you just shared shows a brig with a helm's wheel, yet you told me previously there was no room - J'Accuse! Taff Rail - You're kind of right, kind of wrong here - Brigs don't typically have taff rails that are really distinguishable from the cap rail. If they do have a bridge deck or a poop deck, yes, they will usually use metal rods with rope instead of a wooden rail. However, no where is it written that a perminant wooden fixture couldn't be used instead. You can believe me or not, but I used to live in Galveston Tx and have personally set foot on a couple of operational brigs that did have raised wooden taff railings along the back. Best Regards, -Nate
A few bowspirt updates as well: I removed the secondary boom segment (Not sure what this called... Flying Jib Boom, maybe?) Thanks @Martes for the tough love lol - it sucks to remove a piece I worked hard on, but I gotta admit it does look much more in proportion without it. The spirt was modelled from the HMS Pandora, so it's always going to be a bit big for this Brig, but its definitely within the realm of possibility now. The mesh safety netting has been added as well. This was a first attempt, so not ready for feedback just yet - It was mostly an experiment to see if I could get away with a 2D plane that uses a mesh texture with alpha (transparency) instead of modelling every tiny rope that makes up the netting. I'm happy with the results, I just have to make the sides connect beneath the boom and model the gasket rails along the sides of the main bowspirt - still a much easier approach though. Finally, I've introduced a bump map onto the sail cloth that I'm hoping will simulate the tiny wrinkles that real sails form around the seams. Right now you can see this effect on the jibs, but it's only randomly placed using a noise texture. I will eventually 'paint' the effect onto where these wrinkles actually occur, which should produce stunning results. Sadly, this screenshot also points out all the work that remains to be done on this part of the ship, including: Add the downhaul lines to the jibs Cut out the sheeves and add the underlying support blocks for the bowspirt bees Add the double Jeer blocks, metal hooks, and rigging that connect the anchor stock loops to the catheads Improve the collar cleats on the bowspirt Model the gammoning cleats on the bowspirt Add the saddle for the jib boom onto the bowspirt Wrap the bowspirt woolding with rope Add 2 additional rope loops and thimbles to the tip of the jib boom Decide between knight's heads or a flying forecastle to lock the bowspirt in place
Finally showing some long overdue love to the stern: The stern lantern has been completed, including mounting brackets. The taff rail has been modelled. Newel posts along the back have been placed (still missing supports along the sides, though I want these to look different) Corbel-style relief carvings (baroque ornamentation) added beneath the davits. Floral scrollwork has been added to visually separate the gallery planking from undercarriage, as the angle between these is not overly pronounced. Red painted wood texture has been enhanced to show random areas of scuffing (similar to the yellow wood texture)
A few definitions to start things off. This is a public forum, and in practice many experienced CG artists will use these terms interchangeably, which is fine because we can usually infer the correct terminology from context. I want give precise definitions upfront so any replies to this topic don't inadvertently confuse someone who is trying to learn for the first time. And if you are new to this, DON'T WORRY - it's not as complex as it may initially seem. I promise. Texturing: The art of overlaying materials onto the mesh of your model so that it looks like it's actually made of real-world substances Material: A 3D simulation of a substance that exists in real life such as wood, metal, fabric, etc. In a 3d application such as blender, the term 'Material encompasses the entire node set-up including textures, operators, and shaders. Physics Based Rendering (PBR) Materials: A Physics Based Rendering, or 'PBR' material is generally understood to be any material that is contains more than just color data. The foundation for any PBR material is a related set of textures. Screenshot #1: A set of PBR Textures from the textures.com website. Texture: a 2-dimensional image file (.jpg, png, .tga) that contains some sort of light-based physics information. Most texture files begin as actual photographs taken with a camera. Multiple copies of the photo are made, and each is edited differently to serve a unique purpose in the 3D application. Once imported into the 3D software they are once again combined and processed through a shader, at which point the rendering engine can interpret the data to simulate color, ambient occlusion, roughness, specular, displacement, transparency, translucency, emission, and much more. The thing that all of those have in common is they are all real-world properties/behaviors of light. Shader: A 'hub' node which allows the input of various textures and/or values of certain properties, then combines and calculates the results of the overall material Screenshot #2: The Principled Shader in Blender. Note all the different properties that can be edited. We can set these values manually or import and hookup our PBR textures to the shader. In many cases, the name of the texture file will match its corresponding input on the shader (compare screenshot #1 to screenshot #2). For example, the 'normal' texture file maps to 'normal' input on the shader, and same goes for the 'roughness' and 'metallic' files. If the name doesn't match, for example, the 'albedo' or 'height' files - there's usually a good reason, such as they require an operator between the texture and the shader, or we have a choice on how we use those files (For the experienced folks - I'm talking about displacement vs. bump mapping here) Node: A visualization of any component of a material (i.e. texture, operator, shader) and the relations to other components inputs and outputs. Screenshot #2: Any 'box' in the screenshot below is considered a node. Okay! With then definitions out of the way, let's create some materials for our ship...
Topic Opener: My favorite Blender tutorial vlogger, Andrew Price, once said [paraphrased] "Google the words 'Blender + Car' and I bet you'll find over 1,000 videos on how to model a 3D car, but not one video on how to present that model." Now, I recognize and respect that my audience for this topic may be pretty niche - after all, to the vast majority of members here, the only function of 3D software in ship modelling is drafting usable plans or exporting datasets for 3D printing parts. I'd wager that the notion of a 3D ship model as the final output instead of an input is a foreign or uninteresting concept to many, but I have gotten a few requests to cover texturing and materials, so here we are. With that in mind, I'd like to formally introduce this topic as a way to help one another breathe life into our digital ship models and to be able to display them as evocative artwork in still renders, movie clips or video games. Here's my agenda and I hope to do one section/week. I'm also happy to focus more on certain topics or skip over others based upon your feedback: 1. Understanding PBR (and why it matters) 2. To Plank or not to Plank - Which technique is really more accurate? 3. UV magic: It's all about that scale, 4. Avoiding the Pitfalls: reverse color grading 5. Avoiding the Pitfalls: use of color palettes 6. Cliche's to Live By 7. Special Effects and Overlays We'll dive in soon gang, -Nate
@Lieste Thanks for the feedback. So I'm not sure I complete follow what you are saying, but I was careful to shape each sail from a real-world template (HMS Pandora). It is possible, however, that the wind simulation I used didn't affect the sails the same way it would in real life. Here's a screenshot of the actual cut of the sail canvass with no wind in them Let me know if it still seems off to you and I'll take it under consideration. Thanks!
@Martes - So I got a rather interesting answer regarding our mystery barrels: Turns out they are a fitting for whaling ships and were filled with fire suppressant powder (sand could be used in a pinch). Similar to grease fires, water has little to no effect in putting out fires fueled by whale oil/gasses. Obviously, I'm not doing a whaling ship here, so I'm removing them, but I thought I'd share as its interesting.
Thanks @Martes Okay, so based upon your initial feedback: 1. I have removed the secondary jib boom, which reduces the overall length of the bowspirt quite a bit. 2. I will also re-work the spanker boom and gaffe (make them longer) because that much I can do without ripping the whole thing apart. I'll updated images when finished. Regarding your second post: 1. I'm honesty not sure about the barrels. I saw a photo of a model of the Niagara someone had done where in order, it went: main mast (and rails), grate, barrel storage (they are small barrels, and I would say powder kegs if that weren't so inherently dangerous), then capstan, then the binnacle, then the choice of either: a. hatch for the aft staircase followed by the tiller OR b. the Ship's wheel (for which the gooseneck and pulleys will fit below deck if you forego the lazarette space. Otherwise, you're correct, it has to be a tiller.) 2. Fair enough - this was a guess on my part. I've never been able to see what's in between the hammock cranes and mesh netting. I thought the name was coincidence, or it referred to how the netting was attached. I didn't know the actual hammocks were stored there... wouldn't they get soaked? 3. Already covered this, but using certain configurations, yes, brigs could have steering wheels in lieu of tillers, though I'm not sure how common this was. 4. This is another configuration choice. There are many dependencies when it comes to configuration choices, and I like to think of it like this: If there are deckhouses, a quarter gallery is required because the houses need to be positioned wide enough so as not to impede the swing of the tiller. Deckhouses also preclude the addition of the bridge deck because there is nowhere to climb up. So on my model there is a ship's wheel. The wheel means no lazarette to accommodate the gooseneck. No lazarette means the captains quarters can be on the birthing deck, which eliminates the need for deckhouses (small flag lockers still exist they just don't need their own room). Finally, no deck houses means we can have a bridge deck, for which I still need to model the stairs. 5. Hmm... I'm not sure I agree on that point. Flying Forecastles on brigs, especially those of the late 18th/ early 19th century, were not all that common. 6. Yep, you're right - but it's a lot of work and I'm not looking forward to it lol. 7. Yep, you're right - so how do you feel about Scotland Yard instead (get it?)
A few quick updates on the ship: 1. Gun port and sweep ports texture replaced to a smoother red painted look (compare to the anchor stock texture). 2. bevel added to the front edge of the keel and cutwater. Note: The decorative 'curl' from the upper headrail does extend beyond the cutwater bounds slightly, but any noticeable deformity should be covered up when I attach the figurehead 3. Detailed algae overlay added to the bottom strakes of the tarred planking just above the copper plating. This is only on the hull strakes right now, but I will be extending it around the cutwater on the bow, the stern post at the stern, and onto the rudder eventually. Algae does bleed onto the copper plating as well, but it interacts and visually looks quite different on metal than wood (pinkish streaks or an oxidized patina look), and I have yet to figure out how to handle that detail. 4. Parrels added around the spanker boom and spanker gaff, although I'm not too happy with the current grain. I also need to add the leather wrapping that prevents scuffing and chipping of the mast. That's al for now!
Thanks Martes. So I was definitely playing around with a weird focal length on that particular render, so it probably was the camera angle to a certain extent (my fault, see updated screenshot below). With regards to it being 'undermasted', this is a curious observation I'd like to pick your brain on... If anything, it should have the opposite problem - here's why: The masts, while modeled on the fore mast of the HMS Pandora, were scaled to the exact specs of the Niagara (120 ft above the waterline for the main mast and approx. 84 ft for the fore mast). The Alert calls for a 100 ft length 'deck', which I extrapolated to be around 105 ft from cutwater to taff rail. Niagara, by comparison, is 118 ft in the same dimension. Thus, the masts should be slightly oversized, not undersized. Take a look at the updated screenshot and tell me if it still appears that way to you, I'd be curious to know. Finally, thx for the info on the Sophie. Unfortunately, bc of the time spent modelling the rigging, I can't make any drastic replacements to the masts or yards on this project, but it'll be a good lesson-learned for any future brig I do. -Nate
Quick Comparative shot to self-test my skills. I'd be happy to know what you guys think. Truly - I'm not just fishing for complements here, any constructive criticism is very much welcome at this stage as I approach the final touchup phase and prepare her for use in animation, video games, and still renders. A couple things to note: - My model is actually based upon the hull from the HMS Alert (The 1779 twin-masted Brig version just to clarify because there were quite a few ships named 'HMS Alert' over the years), which is about 10 feet shorter and 34 years older than the US Brig Niagara of 1813. - The Masts, Yards, Bowspirt, Spanker Gaff and Boom were all drafted from HMS Pandora's plans. The main mast and yards on my model were actually from the fore mast of the Pandora (whose dimensions closely matches that of the Niagara's mains. Beyond that, I could find no documentation on Niagara's masts and yards other than total height, length, etc.. - The rigging is bastardized from multiple sources, but I tried to follow the Brig Niagara's where possible. - I chose to use the old-style head rails and cutwater from the HMS Alert. - I followed the classic Royal Navy's color palette. While the Niagara is also black and yellow with red trim, the Niagara was way too 'banana' yellow and saturated for my taste, so I went more towards the HMS victory's look instead. I then played with on overlay intended to scuff up the paint, which gives it a more muted look in certain lighting. Thanks! 3D Model: Brig Niagara:
