Johngr
Everything posted by Johngr
  1. Hi, I did a simple test to compare the paints for Oak, Sapele and Walnut from the two companies. All samples were done with two coats of paint. The Ballistol sample is not a paint but an oil and I included it as there was an empty space!. As for Oak dye, in contrast to Occre, Artesania is a semi gloss varnish with dye. What is your opinion?
  2. With great care the sanding was completed and now it is the turn of the planking.
  3. Thank you Alistair, It really needs a lot of attention, I already managed to break two pieces but fortunately I was able to repair them.
  4. Thank you Andrew, mine is not part of any larger project and is intended as a gift to the wife for her office.
  5. I recently bought a small wooden kit as a break from the plastic EMC HOOD. I've uploaded a short video of the contents and started building it here.
  6. After a long period of intensive work I am back. And in parallel with HMS HOOD I decided to start a relatively small project from Vanguard Models the 22ft Yawl ship boat. The quality of the kit is excellent and so are the instructions, In fact comparing them to a similar kit from ModelExpo that I have is like night and day. And at the start I managed to break one of the bulkhead. Special care must be taken because MDF is relatively fragile and delicate. However, I managed to fix it by putting the small pieces together.!! Then all the temporary bulkheads were placed on the jig, glued and waiting for the glue to dry.
  7. Very slow progress, all the parts are too small and require too much concentration.
  8. Too many details and too many small parts but without facing any particular issue, but the chimney was a very demanding job with such fragile and delicate parts.
  9. Thank you Ken, A very good solution is also the ultra glue from MIG. For some strange reason, while I have bought it, I haven't used it!!🤔
  10. The main cannons painted and temporary fitting to bow.
  11. I have used the combination successfully many times, but in this particular case the glue was probably to blame!! Nevertheless, I agree that CA is a better choice but I try to avoid it as much as possible!
  12. I implemented a very simple technique after much experimentation. First I applied a very light layer of color using colored pencils. Here I used AK weathering pencils 10016 & 10017. Then I removed most of the color with an eraser.
  13. Yes of course I took it out, but I saw that the glue on the edges was not strong enough for that and I put the PVA. Unfortunately, probably my fault, the glue was not strong enough and I fixed it with super glue.
  14. Too many very small items to be placed on the deck. The process will take some time but I have to say that the wooden deck is very nice even though in many places I had loosened it and had to re-glue it with super glue. It seems that the first gluing I did with the PVA glue did not have the result I expected. Maybe they needed more.
  15. No significant progress these days. Masking the hull took a considerable amount of time and the paint had to dry completely for the next layers.
  16. Too many sprues to prime!! It took almost the entire bottle of Mr. surfacer 1500. I must note that the detail in this kit is excellent.!
  17. On top of the wooden deck I placed the masks provided in the kit but the real challenge was fitting the brass pieces some of which are less than 1mm.
  18. For now I installed the wooden decks by first applying a thin layer of PVA glue. I have to say they really add quite a bit to the whole look.
  19. The journey has begun and I have the impression that this will be quite a long one. Initially the two parts of the hull were glued but especially on one side the application is not perfect, leaving a very small step. I used Mr.color dissolved putty and after letting it dry for a day I sanded it down. I have to admit that it was quite a difficult task as the surface along its entire length is not flat and in fact in a place where there is a small protrusion the surface is very small and does not allow easy access. Nevertheless, after enough rubbing with different grits, it seems that the result will probably be better than before. Surely this will be seen when the first layer of primer falls. The next step is to remove some surface details and open the corresponding holes once and later the supplied turned metal ones will be installed which are really excellent. That's all for now. Good night to all.
  20. Many thanks for the link. It will help a lot.
