OldDan
  1. Thank you for the mention, @Keith Black! I used the side of a fine brush for the scroll work on this kit. I didn't know about the use of transfer decals suggested by @g8rfan. Sounds like a much easier option!
  2. Last one! I've covered the bulk of my customizations, so there's not much to say about the rest of the build. Here are some shots of the sails going on while simultaneously adding braces. I'm happy that I was able to minimize the plastic sheen of the sails. I'm less happy with how I attached the jibs. I wish I opted to secure them with one thread on either end instead of ten threads! Oh well. But that's about it! I'll make a post for the finished model soon. Thank you for following along.
  3. Thank you! And that's a good question. I think it would be the old Revell Mayflower because I have it on hand, it's a smaller ship on a larger scale, and because it includes blocks. I also have a Scientific Cutty Sark kit, but that's made of wood and I need to gain some more experience to avoid messing it up. Are there any that you're working on?
  4. Here's another entry. Despite my lack of knowledge of knots, terminology and the function of any given section of rigging, I was happy to find the process fairly straightforward. It was a time commitment, but I didn't loathe any part of it, and felt great satisfaction as I progressed. I did make some embellishments to the running rigging, but I couldn't tell you whether these were jeers, halyards, lifts or what. I tied some pieces to the pin rail to add extra detail. At some point, I bumped the mainmast's lower yard and broke the cement, but it was roughly held in place by the rigging. I'm not sure why, but that made me feel downright jolly. When most of the rigging was done, I experimented with different combinations of washes and flat paint to weather the sails (sheets?). I finished them with acrylic matte medium, which made them look as canvas-like as possible. Again, it was nice to have two kits because I was able to pick and choose which pieces had the nicest texture and fewest cracks (these kits are on the older side). The righthand set are a different color and incomplete, but had better molding). I added the spanker and the remaining whaleboats. I didn't like how the boats were intended to hang from the davits, so I altered them slightly and hung them with thin wire. Does anyone know why the port boat is green?
  5. Thank you, Bill! I hope you're enjoying the kit. I appreciate the kind words and I'll post more updates shortly. Dan
  6. Hello again! It's been a while and, full disclosure, the model is done! I'll compile the remaining process into a few larger updates. With the shrouds complete, I moved on to rigging the bowsprit. This was done by trying to decipher photo reference of the real ship. That was too difficult, so most of the subsequent rigging was done by abbreviating the plans from the 1:96 kit. I made matters more difficult by using a hot pin to carefully make holes in the plastic, then added tiny pieces of wire to add a little more complexity. I also added anchor chain. Not sure how accurate that is to any specific time period, but I like the look of it. I put the standing rigging on hold while I found a couple more distractions. One of these was digitally sculpting replica catheads. I know digital tools can be a controversial topic, but I think it's worth mentioning as I believe it improved my model and was achieved through real-life know-how. Anyway, I used free sculpting software to get the design close enough, then mail ordered four 3D-printed copies. The whole thing took a couple hours and cost $10. Was it worth it when reduced down to a couple millimeters? Probably not, but it was an interesting exercise and I had fun. Afterword, another distraction presented itself. I decided to try making extra railings by soldering together pieces of staples and wire. I painted these and covered them with tulle Eventually, I did continue with the rigging. Here's most of the forestays done and moving on to backstays.
  7. Here's some more progress: I always thought the head area of the model looked a little empty, but couldn't figure out what was supposed to go there. After some research, I was amused at the answer and decided to drill some holes. I also set about making some tiny grating. Through trial and error, I made a paper template that fit well enough, then used this to cut a thin piece of plastic to the same shape. Then, I covered the plastic piece with 1/64" tape. I'm sure there are way better methods/materials for this, but it's all I could come up with. I painted and sealed the whole piece, then cut off the excess and glued it in place. Being happy enough with the result, I wanted to repeat the process to add extra detail to the deck. This meant removing the single boat and its supports, which I had glued in place previously. I'm not sure what this area is called, but I made rectangular assemblies of tape to create more grating. It was more straightforward this time but also more tedious. Having done all that work, the logical next step was to obscure it with an inordinate number boats. Using the 1:96 kit's instructions as a guide, I slightly reshaped two of the whale boats from my spare 1:196 kit and offset the larger boat to one side. I also made a fourth, smaller boat out of a plastic pry tool to mimic the larger kit.
  8. This brings us to this year, when I resumed working on the kit after shelving it for many years. One big issue was that I never painted the hull black and opted to leave it as plain plastic which I regret. What's more regretful is that I tried to make up for it by making even more modifications in a lipstick-on-a-pig situation. I drilled extra holes and modified the crosstree platforms to allow for thread to be passed through for simple futtock shrouds. This also meant abandoning the kit's plastic shrouds and making my own ratlines out of thin thread. I wish I used thicker thread for the shrouds. Actually, I wish I used the ones from the kit. I will post more later. Thank you for reading!!
  9. Hello, everyone! I've been quietly reading these forums for some time and finally decided to chime in with my own build. Others' build logs have been a huge source of information and encouragement for me during the build process, so I hope this log can be of some benefit to others. I worked on this kit for a week or so about nine years ago, and only picked it up again this year. It's my first model kit I've built as an adult and first ship of any kind (Although as a teenager, I painted the hull of the larger 1:96 kit from Revell, then immediately gave up). I also started with zero knowledge of ships, so this whole thing is a learning experience. Much of the work I've done recently has aimed to undo or improve mistakes I made when I first started. One of my biggest mistakes was choosing to modify anything at all, as this slowed the process and made me feel daunted at various points. As a beginner, I regret spending so much time tweaking this kit instead of progressing through multiple kits over the years. Still, I'll mostly focus on modifications here because that's what I've most closely documented. These first photos are from 2015, so some of this is more retrospective. My earliest record is of hastily assembling the hull and deck and painting various details. I tried replicating the paint of the real ship, which lead me to notice differences in the bow and other details. I couldn't figure out why the model had a figurehead, which lead me to research that interesting history. At this point, I should mention that I had two of these kits to work with. Both were purchased at Goodwill totaling less than $5, so I recklessly decided to sacrifice one in an effort to make the bow section more closely resemble the real ship in its current state. Even though I had already installed the boomkins and metallic anchor thread, I ripped everything apart and temporarily ruined both kits. I cut off part of the stem from the donor ship far enough down so that it would extend to roughly the correct height when reshaped and attached to the working model. A bit of jump, but here's the result. I tried filling the gaps with Tamiya putty but you can still see the seam where the two pieces meet and the decorative relief doesn't match up. The other white details were made using thin strips of masking tape for curves and covered with acrylic sealant. The whole endeavor still misses the mark for accuracy, but it makes the bow more recognizable in profile, which I count as a success. At some point, I also lined the hull with real copper leaf but didn't like the look of it and painted over it with green. I think this was because most of my reference photos showed the ship in dry dock.
  10. Welcome! Good to see your Constitution build as I've been working on the same kit. You've done a fine job.
