Everything posted by Stuka
Main mast now assembled, Got some adjustments to do on the yards/spars. Then im adding the boom gaffs,
- 129 replies
- vanguard models
- Sherbourne
Hello its been a while. I have been struggling with the rigging and even bought books, reached out in other threads and searched the internet. And by looking at all of these together I have now finally got over some of these headaches. For the driver boom connection I did the following which was something ECK taught me. I took the string around a toothpick then did 3 knots, After that I tied the string around the block and did 2 knots. Finally using only one of the 2 strings I took it through the eyebolt on the boom and then tied it to the base of the knot. It didnt end up perfectly but imperfection is its own perfection especially on a novice model like this so I think Il leave it be. I also added the parrel beads to the two booms so they are ready for attachment. Finally today I figured out a way to get the lower hard done with the string. I thought it was abit unclear of what knot to use at the places and if this string was to be connected all the way to the block that hangs down. I recently bought Ashleys book of knots and a week ago I noticed some really good Yard/Spar knots so thats where I went. I used a clove hitch which I dont know if they were applied in this fashion but for me it served the purpose as I could tie it at the middle and then again at the egde of the yard to finally use the end string and tie my block in all in one go. So thats what I did. Not much progress but the ball is once again rolling.
- 129 replies
- vanguard models
- Sherbourne
Thanks for all the help guys, Hopefully with the help I can improve on my rigging in the future but I reached out to ECK and he did another variant of this which involves first tying string around a toothpick then he had this open loop which could then just be tied normally around the block. Finally one of the 2 strings goes into the eyebolt and then is tied to the base of the knot around the block. I kinda got this okay at best I will say but it will do for now I reckon. But I will contemplate redoing it or maybe let the imperfection be its own perfection.
Hello I appreciate the help however I do have a hard time to follow. If I would take a big loop around the block to get two eyes one each side with seizing. How do I get one of the eyes to be attached to the eyebolt of the gaff boom? Also how would I solve one end with has to the two loose ends of string. Cause the loop around the eyebolt has to be closed like in the picture does it not? Sorry for all the questions but I have trouble to visualize this. See the picture which hopefully shows my question.
Chucks guide on stropping is a marvel I just read through it and I will try employ some of those technics on my Speedy in the future and maybe on this Sherbourne. However I dont have access to any hooks to do and alternative variant of this gaff boom attachment. But many Thanks anyways for this Piece of marvel 👍
Hello, I have been stuck for weeks now I just cant figure out a good way to get this done. As you will see in the picture this block has to be attached with a loop or something to the first eyelet off the gaff boom then have an open loop on the other side. I just cant grasp how this is supposedly done? The pictures in the instruction isnt that clear either. This is my first model so im very unsure how to proceed. Any directions or suggestions would be appreciated as long as a rookie like me cant achieve it.
Whats the best book on rigging for a beginner?
Stuka replied to Stuka's topic in Masting, rigging and sails
Thanks, and many others suggested it too so I will probably get it along with the other 3. Its just a shame I have to order it from abroad but I believe it will be worth the money. -
Thank you for your time and effort. Il make sure to take a look on the build log and read up upon what you suggested and Il look up the book recommendation too 👍 -
Well Thanks for all the suggestions people. regarding Lees book will it be of any relevance to my cutter Sherbourne or will it only maybe be usefull for the Speedy?. Also Regarding the rigging im not aiming for 100% historical accurate but instead I want to give it some believable look and have some good looking rigging. This task is very big for me since its my first time but hopefully il manage somehow one step at a time. But it is very hard to find info the terminology in this rigging subject. So I hope the books I mentioned will do me good. -
Thanks Gregory. I did see some of those discussions buty didnt dwelve to deep into it. However Petersson has a book called rigging period ships models aswell as the fore and aft rigging one. Anybody know the the diffirence cause wouldnt he cover the fore and aft rigging in his other one? -
Thank you for this post. To give some background Im currently rigging the Cutter Sherbourne. My next vessel will be Speedy but for now Im focused on tSherbourne. Do you know what sets Peterssons books apart since you recommended the fore and aft craft? I have seen that he has another book about period model ships aswell. -
Thank you all so much for the Help and suggestions. Im very grateful for that. So I have considered for now not just one but maybe as was suggested 3 or more books to give me more coverage. Im considering the following, The book of Knots by Ashley, Lees masting and rigging English ships of war, The Riggers Apprentice" by Brion Toss and then Lennarth Petersson's Rigging Period Fore-And-Aft Craft. Though Peterssens Is more about visuals if I understood correctly. But Peterssen has several books about rigging. Can I just get one or do I need more? -
As long as its just a good book relevant for model ships im good. Or maybe just a book on knots even. -
Thanks for the suggestions. My goal is just trying to find something that illustrates very good how the rigging is done and in my case thats the 1750-1800s era of ships. Now money is not a problem for me as long as the book itself is worth the effort. -
Im aware of that they show a diffirent ship but that comes just after after these Images I pointed out. Though looking through the blueprints these "2 missing blocks" are not present on any blueprint so that talks for what you say. But im still unsure what to think, You can even see these blocks by the mainmast on the boxcover of the model.
- 177 replies
- Sherbourne
- vanguard models
(and 3 more)
This is probably it for me. I have considered Peterssens book on the rigging but I looked around here and heard it doesnt accurately depict ships of that era or similiar and that the book should not be recommended to new people like me rigging my first. The book of knots is a good suggestion thanks for that. -
Good progress you are making on the Sherbourne Palmerit. I have gotten very stuck on this model cause the instructions are unclear and the images just wrong in certain areas. But I skimmed through ECKs build log and once again we might have ourselves a blueprint error. The very knot on the main mast with the 2 thimble blocks. Apparently the images in the manual show a diffirent setup having them on the very top end of the main mast while the blueprint location of the 2 thimble blocks is just two blocks though im unsure what exactly. You can spot this in the images of the manual now I just made this discovery so im trying to figure out what to do myself. But I wanted to give you a headsup aswell 👍 Take page 49 images for reference to the plan sheet 10. The location doesnt match.
- 177 replies
- Sherbourne
- vanguard models
(and 3 more)
Hello Im on the rigging phase currently on my Sherbourne and progress is halting due to me not knowing how to make certain knots or make the rope look in a certain way as the blueprints show. I was scrolling through and if anybody knows a really good book on showing how certain rigging knots and other things related are done then please do recommend.
Hello again. I have been procrastinating alot lately on the model but today I threw away my pondering to finally do something. And I got one of the thimble blocks done. Its probably not as correct as the manual shows but it took me barely 5 minutes to do so now its on too the next challange which is the double loop on the block to one of the gaff booms. Firstly I cant find in the blueprints what thread it is but looking at the image its natural colour thread but what size I dont yet know but I suspect maybe the thicker ones like 0,25mm or 0,5mm perhaps. How does one do a double loop like the one in the picture? Cause I had a thought of tying around something like a wire to make a loop firstly then knot and after tying it to the block. But then comes the question how do I make it on the other side thats going to be attached to the brass eyehole?
- 129 replies
- vanguard models
- Sherbourne
So with Chris help and clarification I managed now to get most blocks on the main mast done, Now all that remains is the elusive 2,5mm thimble block. Trying to look in the instructions for references but I cant get a clear picture. Is this just a regular knot or is it something else cause it has those lines just above the block indicating some thread added I think?
- 129 replies
- vanguard models
- Sherbourne
Thank you very much Chris! 👍. And by bigger blocks you mean the 4mm and 5mm?
- 129 replies
- vanguard models
- Sherbourne
Hello So I might be getting the hang of how to make the knots, now a new challange has arrived. Interpretering what thread to use at what time?. Its very hard to know what thread im supposed to use tying the blocks to the eyelets etc. Cause its impossible to use legend in the instructions of the threads when they differ barely a quarter of a mm. It is mentioned in the instructions on page 48 that on one block that a 0,25mm black thread was used however is this used on all the other blocks aswell? So alot of the blocks I have tied already with the 0,25 mm black thread and that has worked great. Im just afraid that some of the blocks are supposed to be tied with other threads cause again the instructions are not clear in that. I just hope Chris or somebody with the knowledge can step forth and shine some light on this question, would be greatly appreciated 🙂. Another thing is the driver boom on the back end there is this single block connected to one of the PE-1s and it looks like it has a loop on the other end which is confusing me. Is this just a threadloop or might this be some part? Bonus Earlier this week my next project arrived the Speedy, with copper sheets and even walnut blocks. So hopefully I can finish the Sherbourne soon and jump onto the next one.
- 129 replies
- vanguard models
- Sherbourne
Hey Palmerit, Good progress Im on the same step as you so im struggling aswell 😆. As for the PE-2sLook in the Plans 7,8 and 9. I have found Pe-2s to be used on the outer pattern close to the stern, aswell as 3 on the bow. Unlike you I have almost ran out of PE-2s so i wouldnt be surprised if I accidently used some while building the cannons. For the eyelets on the main masts above, I put them around the middle maybe slightly a little bit towards the extension mast I used manual side 49 as the picture for reference. Though in the reference picture It looks like the are slightly more on the end of the extension part. As for the 5mm triple block I did not find it either so likely it was overlooked in production, I did reach out to the only one I think so far thats finished the Sherbourne "ECK" and he said the following to me "I sanded down one side of a 5mm double then flattened slightly another double and glued them together" . Im thinking of doing something similiar or maybe putting together some blocks from another old kit I inherited. Good luck on the build!
- 177 replies
- Sherbourne
- vanguard models
(and 3 more)
So I have been adding PE parts to some of the parts in the meantime but I still cant find this part and Im wondering if im supposed to make this part myself? even though it says all blocks are included in the kit. If anybody knows what to do please reach out as im at this point stuck. Was I meant to order these triple 5mm blocks seperately or something?
- 129 replies
- vanguard models
- Sherbourne
