Posts posted by schooner
Here's another option for the tiller rope problem.
The attached photo is of the Syren model at the US Naval Academy Museum. I seem to recall that Chuck mentioned this model as weighing in his decision to select the Syren to develop his own model. Anyway, in case this photo doesn't post clear enough to see, it shows the tiller as LONGER but not necessarily higher, giving the aft guns sufficient recoil room, although it pushes the end of the tiller very close to the steering wheel. It also uses 3 blocks on each side - one on the end of the tiller, one on the upper bulwark aft of the end of the tiller and one the upper bulwark
forward of the end of the tiller. The steering ropes are secured to the end of the tiller, run thru the aft block, thru the tiller block, thru the forward block and then to the wheel creating an X pattern when looking at the finished product port and starboard. Hope this helps
Tim
P.S. If you click on the photo it expands a lot
As far as your carronades sitting too high in the ports - I remember that problem with the Bluejacket carronades from an earlier Syren build log, it was on pg 9 of Rafine's build log (I made a note in my practicum at the time). I ran across it again yesterday on Google, I think under images for "24lb carronade" but damned if I can't find it now. Anyway, Rafine fixed the problem by modifying the lug on the bottom of the barrel to lower it closer to the sled. Looking at the pix of your completed carronade it looks like you have a lot of room to lower the barrel, probably enough to put the trucks back on and avoid messing with the waterways. Worth a try.
Chuck,
I have no doubt that what you cast and sent MS was correct in all respects but I can't compare your photos to what I have in hand.
What MS sent out as replacements, while much cleaner than the originals and their length is accurate, their width is almost 50% too small per the drawings and they don't look anything like the photos in you practicum - their width is almost uniform from muzzle to base while the photos in the practicum and the drawings show the typical wide base associated with carronades, regardless of shot weight .
Don't assume what you sent them is what we got, ask them to send you a sample and match it to your drawings - if your happy then I'll just assume I've got some vision problem.
Thanks
Tim
Chuck (and everyone else) -
I just got my replacements today and I wish I could say I'm satisfied with them but I'm not.
It appears that all MS did was "clean up" the castings without fixing the obvious underscale problems. There is now a hole on the cascabel instead of a stick but they are still exactly the same dimensions as the old ones , i.e. so skinny they look like swivel guns. All the MS folks had to do was lay the new ones on top of the drawings and they would see how inadequate they are. They are only about 60% wide as the drawings call for. These things don't even resemble carrondades.
This is a real let down, I'll probably pack the kit up and send it back to MS since guns are the heart of any warship model and its not too much to ask that they get them right.
I hope the MS folks follow this thread, pull out the "new" ones and compare them to yours and their own drawings and fix this.
Tim
USS Constitution by Snatch Block - BlueJacket Shipcrafters - Bicentennial Edition - 1812-1815 configuration
Hi Ger,
I've built a couple of BJ's solid hull kits (but not the Connie, maybe someday when I have the room). Carving a solid hull to shape is not easy but with your previous woodworking experience and some patience it should not be a problem. You may want to Google for some videos showing how to do it.
I generally use a Dremel tool with a flap sander to get close to the right dimensions then shift to rasps and files to get even closer and finally use flexible sanding sticks to get the curves right and bring it to the final dimensions. That's just my way of doing it, others use carving tools for the entire job - whatever you are comfortable with.
If it seems like you can't reconcile the hull templates with the main deck dimensions you should always keep the main deck dimensions (outline) true - If your main deck is too long, short, wide or narrow you will have multiple problems for the rest of the build.
One important thing to keep in mind (and to keep you from tossing it in the fireplace) is to remember that with a solid hull if you take off too much you can easily fix it by gluing a piece of wood over the mistake a sanding it to shape. With the addition of paint, let alone planking or copper plates, no one will ever know.
I'm looking forward to watching your build, good luck
Tim
