Russ2025
Members-
Everything posted by Russ2025
Managed to find some pictures online to confirm the positioning so I believe I am back on track. Russ
- 14 replies
- Victory
- Artesania Latina
Hi, you kindly provided a diagram of the main mast channels for me from the book- HMS Victory, her construction,career and restoration by Alan McGowan. Would you be able to provide a diagram of how the chain plate configuration looks. The plate positions on video 20 don’t look very elegant but may be correct Any help would be great. Hope your build is going well. Russ
- 14 replies
- Victory
- Artesania Latina
- 20 replies
- Victory
- Artesania Latina
You are so right Roland. Mistakes have been made and hopefully they have been burned into my brain!It has been a ton of fun so far and being able to access the wealth of info and follow some of the experienced builders is great. Russ
- 20 replies
- Victory
- Artesania Latina
Just preparing for the remnants of Mellisa to pass through tomorrow so it should be a productive day. Since my last post I have finished stitching on the hammock crane netting which turned out to be an exercise in patience . I spent a bunch of time researching how these structures may have looked and functioned with no definitive answer so just kinda blended a number of ideas into my own interpretation. I’ve also decided to fill the hammock cranes with hammocks and have nearly finished those as well. Next up will probably be the chain plates. Thanks for looking in. Russ
- 20 replies
- Victory
- Artesania Latina
It looks great! Geometry be damned. Russ
- 16 replies
- Victory
- Artesania Latina
Ah! I remember those days. Coming along nicely. Russ
- 14 replies
- Victory
- Artesania Latina
Hi again, feels like the home stretch now. Worked on the quarter deck details this week. Most of my time spent re-threading my needle a thousand times while working on the hammock cranes. Also started the gunports and a few other bits and pieces. Should be able to finish by Christmas I guess. Then on to the NRG Merchantman planking kit for an introduction to the real stuff. And I thought I would be building the full Victory kit next. Cheers for now, Russ
- 20 replies
- Victory
- Artesania Latina
I believe that’s a good idea. I am currently at that point in the build, video 22ish, and I will need to fiddle around a bit because of the limited space. Russ
- 14 replies
- Victory
- Artesania Latina
Already envious of your approach to the build with the addition of better quality parts. I will adopt this approach going forward. Thanks for the help!
- 14 replies
- Victory
- Artesania Latina
Ha, cheers for that. Yes this is very helpful! As it turns out I went ahead last week and mounted the channels horizontally because it positioned the angled brackets in a better position. I have a few books to reference but none provided a clear view of the correct positioning. I added a piece and sanded it to the angle I needed. I have added a few pictures to illustrate. Also the photo on the box and videos appear to show the channels at a slight upward angle I guess because the frame of the ship is not vertical at that point. Having said all that I am on my first build so you may not experience the same problem.
- 20 replies
- Victory
- Artesania Latina
Nice! Look forward to following along. Russ2025
- 14 replies
- Victory
- Artesania Latina
Hi everyone, the time has arrived for some advice on how to manage this problem I’ve run into on my build. I’ve provided a few pictures for reference. The problem I have run into is fitting the platform that supports the deadeyes. The gusset type bracket provided seems to be short. Firstly I am wondering what angle the platform should be. If I mount it flush with the wale it will be slightly tilted up which seems correct to me based on nothing really. If I do that the brackets appear to be short and will interfere with the wale below the platform. I could notch the wale to accommodate or possibly add a plank under the platform to give the bracket some length. A longer bracket would be ideal but I guess I would have to fabricate them. Or maybe I’m just missing something! If anyone has built this kit or has some advice it would be appreciated.
- 20 replies
- Victory
- Artesania Latina
Hi, I have been steadily working away at painting the hull and adding the ladders if that is the correct terminology. Had some issues with keeping the ladder lengths consistent with the tools I have so will look into a more precise cutter going forward. I thinned the paints and that seemed to work well with a little more time spent adding coats. I have also taken time to look at a number of builds on the site and let’s just say it’s a humbling experience. The level of skill on display is incredible!!
- 20 replies
- Victory
- Artesania Latina
Thanks for the advice. I’ll order some and give it a try.
- 20 replies
- Victory
- Artesania Latina
A cool morning here in the Maritimes so started to paint the hull. I am using Artesania paints and find the hull colour quite thick. Does anyone have advice on thinning these paints, is it necessary etc. Thanks, Russ
- 20 replies
- Victory
- Artesania Latina
Hey everyone, I have been working away at this cross-section as a retirement project. My previous experience with model making goes back to plastic models as a much younger version of myself. Kind of just feeling my way through this project and realizing the learning curve is steep. I have made a few critical errors, one that is noticeable if viewed from the top, and the other being putting the heavier guns on the highest gun deck. Once I noticed the mistake it was too late to rectify the error but a lesson learned. Any feedback or suggestions would be welcomed. Cheers, Russ
- 20 replies
- Victory
- Artesania Latina
