Couple of modeling related painting questions
Rich Sloop reacted to a post in a topic:
HMS Harpy 1796 by dunnock - Vanguard Models - 1:64
paul ron reacted to a post in a topic:
I’ve moved on to my second model and really want to preserve the etchings / laser engravings as I paint. I’m not an ‘air rusher’ and was curious if there is a solid technique for brush or rattle can painters. Some model train guys have suggested after WOP 1) thinning any paint to near water consistency 2) filling the engraving with shoe polish 3) using a pencil to outline the engraving. Or just give in and buy/learn to use an airbrush for the lightest coat possible?
Repurposing Pool Cue Lathes?
Rich Sloop started following Motivated Newbie , Repurposing Pool Cue Lathes? , Highlighting Laser Engraving and 2 others
Looking into options for tapering and finishing masts and yards. I see the Sherline extended bed lathe is used by some builders, but it’s through hole may not allow larger build at 1:48 or larger - plus it’s expensive. I see less expensive American and Chinese pool cue lathes offered at half or less that a Sherline with a much larger diameter through hole. The base on most is long and allows reordering of the support, motor and cutter elements. Seems like a possible option. Does anyone have experience with any of these? Short comings or limitations?
Model Machines LLC – Byrnes Model Machines - All machines to be back in production soon.
How do you all choose your next build?
How do I choose my next build? By my final objective - the HMS Centurion. I had no experience in model ships before last July. Actually, no experience in any modeling (Does Estes Model Rockets from my early youth count? Or are they models or simply toilet tubes with wings?). I anticipate Centurion will either be a scratch-built project or, if a kit evolves, it will be on the expert level. In preparation to tackle the Centurion, I have tried to select each build to slowly advance new skills and techniques that will make me a viable model shipwright for this project. The ships I have chosen for the queue are all mid to late 18th century. There aren't enough early 18th-century British ships for my needs. I have started with the Vanguard Sherbourne, experimenting with multiple planking techniques, different photo etch prep processes, trialing various paints, and testing different tools. My first Sherbourne is almost ready to rig, with another 2 Vanguard kits waiting. I hope that after completing these three kits, I will do a 'kit bash' project to sample some scratch building challenges. I regularly watch YouTube and read this site. Everything is selected to enable me to take on the anticipated complexity of the Centurion. Any effort that helps me prep for the phantom kit or a scratch build is the next build!
Loose Planks
Loose Planks
Rich Sloop replied to Rich Sloop's topic in Building, Framing, Planking and plating a ships hull and deck
I will look into a this CA. I have only used the thick stuff to date. -
Loose Planks
Not sure how to access the inside. Maybe I can use a needle to inject glue through the crack, let it set up and sand? -
I am working through my first build- a Vanguard Sherborne. I have taken my time reworked a few problems and so far am please with progress and what Ive learned. After applying the first coat of paint some cracks appeared. Not really cracks but some planks have loosened. Not enough glue? How to correct the two loose planks?
Painting question.... The painting needs for ship models seems to be fairly straightforward. If that is correct, what is the best basic airbrush kit offered that best meets most of ship modeling needs? Would the small handheld airbrush/compressor be good for painting bulwarks, wales, spars, hulls and maybe applying matt varnish? Really would like to find an easy, all-around airbrush kit that provides better results than brushes. Any advice to this newbie is appreciated.
Glen the ship looks great. You may be the reason I do me the Harpy next!
- 241 replies
- Vanguarrd Models
- Harpy
I've been on the site now for about a month and Im really enjoying it. While I am a complete 'newbie' to this hobby I am quite excited about participation so far. I am a tech guy for my 'day job', along with being a rabid history buff. This year I began working on my MA and also was trying to help a local museum with a display. The museum had planned a display including a model of the Centurion and several others ships. Looking deeper into the models for the museum I became hooked. Not only on the history aspect but the level of craftsmanship and artistry shown through members of this group. Very impressive... All of the builds here are inspirational. Currently I am about 35% through my first kit, a Vanguard Sherbourne and that has been a super experience. Much more interesting & complex than the Gillow's airplanes from my childhood. Between this site and YouTube I feel like I'm advancing my skills at an acceptable pace. (Thanks!). Already considering the second project which could be another Sherbourne in a different style - or reaching out of my novice comfort zone to try the Harpy. My ultimate goal will be gain the skills to complete an advanced model of the Centurion... which is a long way off. Any recommendations or advice are always appreciated!
Rich Sloop started following Glenn-UK
Rich Sloop started following Nightdive
Rich Sloop started following James H
