Pete Jaquith
Everything posted by Pete Jaquith
  1. Next step was drafting/installing the ships name. Key points include: >>> Stern name, hailing port, and bow name were developed using MS Word >>> Stern name and hailind port were expanded (curved) to look properly when installed >>> Bow names were raked to suit stem profile >>> Bow names will be installed on spray rails (later in the construction sequence) Pete Jaquith Shipbuilder
  2. This posting will cover the pin rails, channels, cap rails, and installing the plankshear. Key points include: >>> Pin rails installed to suit rigging plans >>> Channels installed to suit run of shrouds and backstays (runs simulated w dowels) >>> Cap rails fabricated from 3/64" sheet stock w scarf joints >>> Caprails trimmed with 3/64" double bead stock >>> Padding for anchor stowages was installed >>> Interior bulwarks painted before installing cap rails and upper catheads >>> Exterior hull painted before installing cap rails, upper catheads, and plankshear >>> Forward cap rail left loose to suit installation of bowsprit Pete Jaquith Shipbuilder
  3. Next up is the interior bulwark framing. Key construction points include: >>> Timberheads were 3/32" x 3/32" >>> Heavy framing forward where the stem rakes forward >>> Catheads built in (2) pieces to follow paint line >>> Framing for bulwark sheaves included >>> Framing for mooring ports included >>> Mooring ports fabricated from flattened brass tube with brass wire lips >>> Hause pipes fabricated from brass tube with brass wire lips >>> Chain pipes were fabricated from brass tube/sheet >>> Wood/iron cleats included to suit rigging plan >>> Construction/installition sequenced to suit paint boundries Next steps include the pin rails, channels, cap rails, etc. Pete Jaquith Shipbuilder
  4. John, I think the thickness will work out. I have plans of a similar steam tugs of the period with 3/8" hull plating. That is close at 1:64 scale and I believe I can find Bristol board in various thicknesses. Pete
  5. Ship Modelers, I am considering a plate on solid hull scratch build of the steam salvage tug "Foundation Franklin" 1918. Has anyone had experience in using Bristol board to simulate lapped riveted iron/steel hull plating? I have seen Bristol board used for plating on deckhouse structure and it was very effective. The material used was textured Bristol board ~.012" in thickness. I have used Bristol board on other models and it takes paint well. "Foundation Franklin" was a steam salvage tug working the North Atlantic out of Maritime Canada in the 1930's and 1940's. She became well known to lovers of the battle between men and the sea through Farley Mowat's book "Grey Seas Under". If you have not read the book, it's a great read about tugs and their men. Pete Jaquith Shipbuilder
  6. One more post to finish off the deck planking. Key Points include: >>> Planking fitted from the centerline working outboard >>> Margin planks and nibbing worked from both the bow and stern >>> Care taken to maintain a symetrical nibbing pattern P/S (select even width planks) >>> Deck scuppers (5/32" thin wall brass tubing) drilled prior to fitting outboard planking >>> Following completion of all planking; coamings, waterways, covering boards, windlass support planks removed for painting >>> Planking finished with several coats of Minwax "Ipswich Pine" oil stain followed by multiple coats of Bartley's "oil based wiping varnish" ribbed down with ultra fine steel wool >>> After finishing/painting; coamings, waterways, covering boards, windlass support planks were reinstalled >>> Deck scuppers were installed from the outside and sanded flush (outside surface) This completes the deck planking. As time permits, we will continue with the interior bulwark framing and finally finish off the cap rails. Pete Jaquith Shipbuilder
  7. Thank you for your interest in "Newsboy" With the deck framing complete, next steps include deck planking, waterways, covering boards, deck scuppers, hause & chain pipes. I enjoy this work as it requires some design work to optain the desired effect and with finishing it will start to give the model some color. Key points include: >>> Deck planking fitted around hatch/house coamings, anchor windlass support planks, etc, >>> Deck planking and margin planks fitted to waterway planks >>> Deck planking nibbed into margin planks >>> 1/16" x 3/32" deck planking >>> Caucking simulated with black non-blead fabric markers (quick pass on one edge only) >>> Waterways rise forward as covering board/plankshear have greater shear than deck planking >>> Coamings, waterways, covering boards, and anchor windlass support planks left loose (final installation after painting and deck finishing) It should be noted that this arrangement is typical of vessels build with machine cut planks. Prior to the advent of machine sawed planks, ~1800, deck planking often curved and was nibbed inboard into adjacent planks. Pete Jaquith Shipbuilder
  8. In surveying the machine carved hull; I found that the deck surface was too low, lacked adequate camber, and lacked shear forward. This problem was corrected by fitting a deck framing system constructed from bass strip wood. After completing/fairing the deck framing system, the location of major deck structures were laid out. The mast holes were drilled at this time with the aid of a pedistal drill press. In preparation for deck planking the following were fabricated: >>> Hatch/house coaming were fabricated with half lapped corners >>> Bowsprit, jibboom, dolphin striker, and Samson post >>> Anchor windlass (used portions of a Bluejacket windlass kit) With the heavy construction complete, future construction will turn to the finer points of deck planking, deck furniture, etc. Pete Jaquith Shipbuilder
  9. With the exterior hull planking complete, the next challenge was carving the bulwark interior surfaces. Carving was done with sharp gouges, sanding sticks, and an electronic thickness guage. Note that in installing the exterior counter planking, two coats of wood glue was used to ensure the glue had an opportunity to soak into the the end grain of the counter. This created a strong ply type structure that could withstand the strain of carving out the bulwarks' interior. Pete Jaquith Shipbuilder
  10. Thanks for your interest in "Newsboy" 1854 I have attached a thumbnail of a print of Brigantine "Newsboy" 1854 by George F. Campbell. This is the picture illustrated on the cover of a "Ship Modeler's Jackstay" by George F. Cambell (good reference for your library available from Model Shipways). While I have no family connection to "Newsboy", my fore farthers did sail on similar merchant craft in the mid 1800's. Other ship of this period which I have a connection is "Volante" 1853 by William H. Webb (also on my build list). I am a graduate of Webb Institute of Naval Architecture founded by the shipbuilder William H. Webb. With respect to the Topsail Schooner "Eagle" 1848, I have posted pictures in MSW's Completed Scratch Build Gallery. I will consider posting a build log after we complete "Newsboy". Pete Jaquith Shipbuilder
  11. Next steps include laying out and fitting exterior hull planking. Planking butts were laid in the normal pattern using the table illustrated below. Due to their shape, the bulwark counter planks were templated with a sheet of clear mylar. Planking material included: (a) 3/64" x 1/8" hull planking; ( 3/64 double bead plankshear; and, © 1/32" x 3/32" bulwark planking. Planks tapered at the bow and stern, but with the exception of the counter plank shapes were not extreme. The plankshear was fitted at this time but will be glued in place after painting in order to establish a clear color break. As the hull will be coppered, hull planking started approximately 1/8" below the waterline. Pete Jaquith Shipbuilder
  12. Thanks for your interest in "Newsboy". The principal component used from the original kit was the carved hull. After surveying, the hull was carved in the inverted position using a building board and art board templates. The hull block was positioned with the waterline level, parallel to the building board, and with stations vertical. Shaping was accomplished using sharp gouges, chissels, and firm sanding sticks for fairing. As the hull will be overplanked, the hull was finished using 180 grit sandpaper. After the hull was carved to the outer hull lines, the upper hull from 1/8" below the waterline to the cap rail was recessed 3/64" for hull and bulwark planking. Following completion of hull shaping; the stem, keel, and stern post were fitted. Additionally, the rudder was fitted (to be installed later) and the pedestal holes drilled at this time. Pete Jaquith Shipbuilder
  13. The brigantine Newsboy was designed by Dennison J. Lawlor of Chelsea, MA (designer of the very successful pilot schooners Dancing Feather, Hesper, and Phantom) for owners Dabney & Cunningham of Boston. Newsboy was built at the Joshua C. Adams and Elisha Brown shipyard in Owl’s Head, ME where she was launched in June, 1854. She had a length of 111 feet, beam of 27 feet, depth of 12 feet, and tonnage of 290 tons. While described as a brigantine, the rig is more accurately described as a hermaphrodite brig because there were no square sails on the main mast. The Newsboy was engaged in the triangular trade: carrying lumber and manufactured goods from New England to the Mediterranean; transporting wine, oil, and fruits to the West Indies; and returning to New England with rum, molasses, and sugar. The Monthly Nautical Magazine said “having a reputation for speed, by wringing reluctant laurels from her competitors who have chanced to fall in company with her at sea….she does her designers no discredit…her log will speak for itself”. The model is built to a scale of 3/16” to the foot (1:64) based on an old Model Shipways solid hull kit and plans by George F. Campbell. The model is plank on solid construction, with built up bulwarks, planked decks and topsides, coppered bottom, and scratch built deck furniture/fittings. Limited commercial fittings will be utilized where appropriate, and the rigging will be proportional linen line with Warner Woods’ blocks. The Brigantine Newsboy is my 4th wooden ship model and the 2nd in my series of mid 1800’s American merchant sailing ship models. As time permits, I will attempt to post the high points of my previous MSW Build Log. Peter Jaquith Shipbuilder
