Posts posted by Pete38
Knees look great...Keep up the good work
Just a small update. Started doing a little of the sanding...time is getting tight since the warm weather has moved in...Gardens and yard work loom ahead, have to get all the mowers and tractors going taking away from the cross section
So here are a few pictures of where I am at.............
Took measurements from the plans and transferred to the frames
Marked each frame for the flat to be sanded
Made up a sanding stick with 100 grit long enough to reach from end to end so sanding would be equal for each frame
Pencil marked each frame to gauge when I had sanded down to make the frames level with each other
Check with a straight edge to make sure was sanding evenly
Also used the keesson to check
Once this is sanded to suit me I will replace the temporary block between the frames with the permenant cherry wood.
So back to sanding and yard work.....
- aykutansin, rummy, isabuncu and 4 others
7
That is a nice stack of wood
Good start on the keel and stem
Bob
Sorry to see the beautiful planking needed pulling. Looking at the pictures I still did not see it until I read your latter post, I am sure you will feel better knowing that the planking will now match.
Beautiful work
Very nice, good to see it posted back
They sure looks great to me!
How about making about 80 more for everyone else!
Make mine just a weeee bit bigger please.
Looking good
I agree with Paddy frames looks good. Great start.
Really like the weathering on the decks
Nice progress, like the extra you went on the limber boards, looks great.....
Very nice accomplishment
Frames are looking great.
Thanks for checking in. All the frames are raised and in place. The next job will be to fair the frames, hope there is enough meat on the frames for this.
Here's a few pictures of my progress to date.
Just had to take it out of the jig to see how it looked. Surprised how strong the frames are already...
Time to start sanding....sanding...sanding....
- bbrockel, harvey1847, aviaamator and 5 others
8
Very nice, beautiful work. Thank you so much for reposting this great build.
Very nice work and really like the weathered look...
Tony
If you look back to page 3 part way down it show where he drilled multiple nail with needle then cut the end off letting the nail fall out.....neat
Thanks Russ. the glue was only diluted very little to help run into the hole.
As stated before I am treenailing as I go. Since I am at a larger scale I am going with a larger treenail for holding power than the scale calls for. They are about .047 dia. and 5/8" long.
With 2 per frame at a slight angle (like an X) should provide a strong joint.
Here is the first frame standing on it own
Drilling the holes with my flex shaft on the dremmel
Holes drilled
Next installed treenails with diluted glue
Rusty...Russ....Paddy...Aldo...Sinan Thank you for looking in and the comments and suggestions. I will be treenailing each frame as I go
So back to the workshop.......picture progress to follow...
Very nice start. Stem looks good. What type of wood are you using for the build?
Very nice start to your build sir. looking forward to more
Very nice work, it looks great , Really like the ships boats.
Very nice on the jib, maple looks good.
That is looking very nice, like the color of the decks.
Creole Queen by wim500 - 1/82 - sternwheeler
Time well spent. Looks very nice
