Posts posted by Pete38
Nice going David, very usefull information...........now where is that limb I been saving?????
Guy.....as long as you are an active participant in the triton builds, you should have access to the downloadable plans.
Looking forward to your build
If you go to the WOOD discussion forum there are 2 pinned items on where to buy wood/suppliers. Don't know if will help or not but mayu be a good place to put any suppliers you find here (have it in one place) Good luck
http://modelshipworld.com/index.php?/forum/20-wood-discussion/
Give yourself a toast....
the frame raising is done. Looking good... now on to the fun job of sanding...sanding...sanding...
For the false keel you could go either way, going with cherry/cherry simulate your caulking to show. Going with cherry/african blackwood no caulking needed.
I kinda lean toward the african blackwood...it just gives it something....but if you go this way how to you plan to display it. If going this way display it so it can been seen
You gonna use a cradle, mount flat to baseboard or use some standoffs and have it up off the baseboard a little...something to think on.
Either way you go it will look great
Happy desision making
Kip.....HAPPY BIRTHDAY
Welcome to the Triton build, I am with Daniel, use both Pear for the frames and Beech for the planking. Your build use what woods you want. Good luck
Beautiful job on your build. I had forgotten how nice a job you have done on this. It is looking great.
This will be one of the best Sultana build there is. Something for the rest of the builders to try an accomplish. Keep up the great work and thanks for reposting -
Thank for posting Russ. Very nice for a "generic" cross section
Very nice set up. Will have to look into the knex if I ever need to make my own ropes. Thanks for posting
If you ever come up with three or more hands...I believe the Admiral will have control of the extra hands
Grant, nice work on the bits for the cannons, very nice set up for the blocks on the mill. Mill makes it nice doesn't it
Looking forwar to seeing your rope walk -
Aldo
Welcome to the Triton build. You will get a lot of great help here. As far as a simplified approach....it is your ship....build it the way you want....there is no wrong or right way
Beautiful work Rusty....the contrast between your framing, decking and deck beam woods just highlights your very nice joints and craftmanship of this build. Thanks so much for sharing
Russ was typing at the same time as I was, He's faster. I had asked the same question here http://modelshipworld.com/index.php?/topic/336-understanding-the-frame-layouts/
Thanks Russ
Your small forest is looking good, Is great to have neighbors like that.
Very nice "restart" to your build. That cherry is real nice and the v-groove looks straight and clean...Great job
I am sure you will be much happier with the cherry.
Nice looking keel....scarf joint is real nice
Still working on the treenail for the frames,,,only 2 more to go....
When I get one frame done and the treenails trimmed I have been getting ready to raise the frames on the build board.
Pictures are a better explanation:
I glue a tempory batten arcoss the top using the framing layout pdf to get the correct distance from side to side at the top
I then mark the center of the temporary batten to match up to the center mark on my build board
Also have been marking the center of the frames at the keel also as a way to double check
Here is one temporary place to see how it is going to work out
Once all the frames are raised and attached to the keel I plan on cutting some support from cherry to go between the frames while fairing the hull. I may leave them in since will be planking over where I place them.
Everyone have a Happy Easter
Rummy that is looking real nice. Good job on going back and redoing...treenail the lower deck.... if it did not look right to you, it would have bothered you for the rest of the build. Good going
And Happy Easter
The oil does look good, I like the natural color that oil bring out of the wood. Good Job
I for one would like to know how you do this, I have blender installeed bt have only fooled around with it once or twice. I find this all very interesting,
You should see my toolbox at work. Maintenance on cnc machinery and metal parts fabrication. We have machine built in america from the 1940's to present, then we also have machines from Japan, Germany, England, Australia, Sweden, China, Taiwan, just to name a few. Some were partially built overseas then finished here, makes it a real nightmare to work on them
Paddy, seen your post on MSB in my log. I used a dremel tool (metal cutting disc) to make my scraper for the notch. If you use this method, make sure to wear eye protection and clamp the razor up in some sort of clamp....Good luck
Triton by Pete38 - 1:48 - cross-section
in Cross Section Build Logs for HMS TRITON
Gentlemen, Thank you very much for looking in and the nice comments. I Love This Place
All the treenails in the frames are done. so getting ready to raise the frames. I have found 3 advantages so far at building at this bigger scale
1. It is not nearly so hard on my eyes
2. The treenail are alot bigger....don't have to keep breaking them while pulling through the drawplate to the smaller size
3. I can use my regular size powertools on this build such as my sanders
This is my detail sander, sanding the side before raising with a 320 grit, making sure the treenail are even
With that done I started raising the first frame "C"
Was wanting to make sure the build board was square to the base first
After that I clamped it in place to make sure it did not move
I first test fitted the frame adjusting the keel notch slightly with a sanding stick (cheap fingernail file) Glued it in place and clamped it to the face board
Then check for squareness again
Rest of the frames waiting to be raised
Now I have a Question for you.....Would you wait to pin (treenail) the frame to the keel after all frames are in place or would it be better to pin each frame as I go.
Also..Since this is a bigger scale I thought about using 2 treenails per frame maybe pin at slight angles to each other. This would prevent any movement at all.
Please voice your opinion.
Thanks
