Posts posted by Bedford
Now that we have run amok with your thread Robbyn I will just wish you were here and let you get back to your build, it is coming along well and the gun ports look great.
Steve
Did you drill through the beak and dowell it yet Robbyn?
I fear we will find this more and more as manufacturers find ways to cut costs by using generic parts across the range on a "that'll do" basis. We had this discussion with the rudder hinges earlier.
I wonder if there is one manufacturer who will stay true to scale, they would cost more but be worth it.
Steve
Glad it worked Robbyn.
I mentioned "flexible beach" that's what they call it at MS here in Aus. Next time you order timber get some, probably about 5mm x 1.5mm, sorry, you guys who ditched imperial rule centuries ago but still keep imperial measurements will have to convert that yourselves
These are pics of my first model tall ship "Schooner for Port Jackson" from the supplier I mentioned above. The pics are not great because she is behind glass but if you look between the lanyards or ropes that attach the shroud lines to the hull you will see a piece of timber on the bulwalk bent down to follow a step in the sides. This is flexible beach and I bent it with the domestic iron by just soaking it in warm water for about 10 minutes then placing it flat on the table with the iron on it, back and forth a little with the iron then just hold it down with the iron and bend the plank upward around the edge of the sole plate of the iron, move the iron a little and bend some more etc to get the appropriate radius. It was so easy to bend and work with. Like I said, first ship, first real tight wood bend and dead easy, first go was perfect. This is excellent timber for bending. Keep it seperate from any other beach you have though because it looks the same.
I have no idea how hot a curling iron gets but I would imagine not very.
From the look of your profile pic you wouldn't have any other use for one though
Have you made any progress with this Robbyn ?
You should find as you make a few models there will be timber left over from each, never throw this out as I am sure you would appreciate. It becomes very handy in subsequent builds.
For future reference there is a type of "beach" that is very flexible and although a bit dearer than most woods it is well worth it and I get it from MS as required.
In this instance though if you do not have a planking iron, and I have never seen the need, get it nice and hot and wet and lay it flat on a suitable surface and iron it with your domestic steam iron. Rub it over the piece once or twice then working from one end rub it forward about two inches and then back to the start and hold it down firmly as a clamp for the wood and start bending the plank, moving the iron back and forth between bending efforts. When you have a bit of bend holding in the timber move the iron over it again and keep working your way forward.
You will find this easier if you don't cut the timber to length first as you will have more to work with and hold on to and the process takes practice to become accurate with so cutting after bending is the best option. I start from the tightest radius end and work my way out so I need about two inches infront of the bend to allow holding the plank down under the iron.
Hope this makes sense.
Steve
Nice progress Robbyn, looking good.
Yes it is always better to inset doors and the like so they don't just look stuck on. Good on you for going above and beyond.
Steve
Robbyn, mail order is your friend.
There is a place here called Modellers Shipyard and their website lists all the timbers and dimensions they have available and they post every day, I am sure there would be a few such places there and they advertise on this website.
I would also imagine that it would be a fair bit cheaper in the U.S. than here too.
You will be able to order whatever individual pieces your heart desires.
You won't find the timbers you want locally but online there will be plenty.
Steve
Wow, you must have appreciated it to thank me twice
Hey Robbyn I don't know if this would be helpfull or not but I posted consctruction pics of the replica Endeavour made in Perth in 1993, http://modelshipworld.com/index.php?/topic/1207-endeavour-replica-construction-pics/
If nothing else you can see just how woefully inaccurate the rudder hinges supplied with a kit are.
It might help with the line of external timbers though.
Steve
Yeah, this is one of the benefits of not having a dog !!
I am not sure but a good model ship supplier that sells ships decorations separately for the scratch builder might be your best bet for a replacement.
Steve
I have been tossing around the colour scheme for mine as I normally don't paint my ships, I like the beauty of the timber.
The Caroline will be special and needs to look it's best and colour will be required to bring out the full beauty of the ship. I have thought I would do pretty much what you have done but was toying with leaving the white off below the water line. Having seen yours I think that will work nicely.
I second the motion, looking good now.
Ah, you have truly entered the ranks of the ship modeller, this is confirmed in two ways.
1 You were not happy with an aspect of the kit so you decided to make the parts yourself.
2 You are even dreaming of the solutions, good, the craft is well established in your mind.
Seriously though, well done, I think the new doors will look much better.
I have all this to look forward to...............
Thanks for the excellent insight, looking very good.
Steve
Perhaps it's to make them feel less steep? They are steep anyways but I imagine if the went straight down they would be all the more.
Yes, if they went straight down but I was thinking linear in line with the existing top and bottom fixing points like a normal staircase.
Thanks mtaylor, I was thinking that must be the reason, the French do like their style.
Yeah Robbyn, forums like this can be very helpful and comforting.
Especially when you realise that we have ALL done something like that.
What did Thomas Edison say when trying to invent the light bulb? "I did not fail 600 times, I discovered 600 ways not to make a light bulb"
You have adopted the right attitude and are smart enough to learn from this..
The Schooner For Port Jackson was my first and I had no forum and no-one I knew to turn to. My ex can attest to the power of my self control because it came within milliseconds of becoming a flying boat on many occasions
Steve
Hey Robbyn
I know you have other things on your plate with those sneaky gun ports popping up in the wrong places but you owe me pics of the rudder hinges my dear.
Not wishing to sound pushy or presumpuous of course.
Steve
To paraphrase a well known semi-pirate, "A craftsman always likes to know his help is appreciated" Can't wait to aee the pics Robbyn.
Steve
San Francisco 2 by Shaz - FINISHED - Artesania Latina - Wood
Yes Robbyn you will learn a lot as you go, as I have said, I have the CWMorgan and the plans and instructions are to say the least - some form of plan and or instruction. I will tackle her one day though and I will do what I do which is make her to a form that looks right to me.
There are so many beautiful ships to build though aren't there?
Steve
