Posts posted by Bedford
All seemed to go well until well into the sanding and finishing of the lower hull when I noticed that the third layer was delaminating!
I peeled it off and resanded the second layer and tried again being very mindful of the instructions on the spray contact adhesive, the same happened again so I removed the new third layer and then sanded the second in preparation for a more conventional wood glue but when I attached the third layer piece by piece it buckled up because of the moisture in the glue.
At this point I decided that double planking is a tried and true method of cunstruction so I removed all the offending layers from the bottom of the hull and bought planks to lay, so much for using up excess timbers.
I did the sides in the double plank format from the word go because of the dramas I had with the bottom but I decided to opt for walnut outer planks because they have a finer grain thereby having finer edges which fit together much more neatly and the finer grain looks more scale.
I started this little project a few years ago with the intent of using up leftover planking and other materials from tall ship builds. I like building R/C and made a 1:8.5 scale Land Rover Defender 90 a while back and this will go on a trailer behind it. I don't "play" with these things much as it is the build that I like. The Defender was scratch built based on a commercially available body and drive train components.
I always loved the look of the Riva Aquarama and this is losely based on that boat. I drew the plans myself then bought a set of plans for the Aquarama to make sure the shape of the bow was right.
The basic concept was to build plank on frame, with a difference. I was going to build up a three ply hull in situ by laying one layer of 0.6mm limewood (from memory) sheet along the bottom of the hull. Then cut the sheet into short lengths and glue to the first layer at right angles using spray contact adhesive. Then repeat the process in the original direction for the third layer.
The sides were to follow the same technique using mahogany sheets.
This was my third build, and the first I took some progress pics of.
This kit was bought by a friend of mine after she saw my Schooner for Port Jackson, she loved it and had always wanted to build one. Once she looked at the plans she was too affraid to start it inspite of my offers of guidance. One day she decided to give it to me so I built it and gave it back to her. She had done the eulogy for my 13 year old daughter, Caroline, which was a huge thing to do, this was my thankyou gift to her.
The main problems I had with this kit were that two of the hull frames seemed to be misnumbered as I had to add timber to the outside of one frame to make the curves flow properly so if you are building this kit keep that in mind and dry fit all the frames first and use your judgment. Some of the deck house frames were also not the best so I made them myself.
I have never put sails on a model before because I don't think they ever look right but I knew this schooner would carry them well.
I will let her speak for herself...
- kier, tasmanian, GrandpaPhil and 1 other
4
Runabout by Bedford - RADIO - Mahogany and Walnut
Then began the long drawn out task of spraying and sanding and spraying.....you get the idea.
It has come up rather well though.
