robdurant
Everything posted by robdurant
  1. Well, I've finished the second planking Cut out the bulkhead stubs... Planked the false deck... And then broken with the order of the instructions, because I wanted at least one coat of paint on before I started the coppering... I figured it might help me to end up with a neat line at the waterline... as it turns out, it just makes marking the waterline on a nightmare (pencil won't work on black paint!)... and all I had was a huge silver marker... anyway... it's done now. Waterline marked, and coppering complete: I'm really quite pleased with it... the planking isn't completely smooth, but I like the way it allows you to see the planking underneath.
  2. Another little update. I've almost finished the stealers in the starboard side, now... And I'm working my way down the port side... (trying to get something vaguely like symmetry as I go...) Slow and steady, but getting there, now. Thanks for all the encouragement. It really helps spur me on. And, yes, I'm dreading those little brass eyelets on the carronades... :S I'd forgotten how brass learns to fly when it's cut into tiny bits! Happy building and thanks for reading... Rob
  3. It's been a while since I put up an update... mainly because the progress is slow, but I'm trying not to rush, and get it right. For a first attempt I'm really quite pleased. Beginning to feel like a crying shame to cover all the wood up with copper and paint This is the starboard side so far... I've also started the carronades as a project to get on with while the glues setting on the planking... This is the progress as of yesterday evening... There are lots more photos of progress here: https://www.flickr.com/photos/150573193@N04/albums/72157680568137234 ... but it's mainly a record of the planking, so I thought I'd spare you Thanks for reading. Rob
  4. Time for an update... I filed down the frames at the back to help the run of planking towards the bearding line... in retrospect, now I'm thinking I didn't file it down quite enough - but I'll know for next time. I've completed the first layer of planking on the starboard side. This is definitely the 'messier' side... I'm happier with the results on the other side. But it looks like with a little sanding, it should tidy up okay. Not _too_ much clinkering... and I'm reasonably happy with the line the planks take up to the bow. I'd be interested to hear what people use for wood filler? Brands, etc...? I want to make sure this layer is absolutely right before I start the second planking, so I give myself a fighting chance Here's a shot of the other side, so far... Thanks for looking, and thanks for all your kinds comments and advice. It's all very welcome. Rob
  5. Thanks Mike. I've read a few books on Trafalgar, and the brief account of Pickle's race back to England, but nothing very detailed... fascinating story, though. It really captures the imagination - I think that's what drew me to this boat in the first place (coupled with the manageable size ) Rob
  6. That's really helpful... I'll definitely take another look at that area. Thanks Eamonn
  7. Hi - thanks for the encouragement. Cottesmore was a hull from Fleetscale, and fittings from Sirmar - the rest was scratch built from lots and lots of plasticard and brass rod, etc... You can see the whole build come together here: http://rnwarships.informe.com/forum/minehunters-and-minelayers-f25/hms-cottesmore-1-48-hunt-class-minesweeper-t823.html Barry at Sirmar does a River class fibreglass hull, and lots of the fittings for it. But be prepared to wait a while - he works full time, and only does this as a side job, so it can take him a while to fulfil orders - they're excellent when they arrive though. Take a look here... http://sirmarfittings.com/tyne.html
  8. Wow, you guys make planking look easy... I've decided to follow the instructions that come in the kit for the first planking... being my first attempt. I've finished bevelling the frames... Frames 1 and 9 are in place, and the stand's put together, and the gunport patterns are in place. Then I sanded the bearding lines, and wished I'd done it earlier!! Anyway - the first planking is underway - 6 strakes on one side, and 4 on the other... I've had to take a couple of planks off and redo them, but I think it's going okay now... time will tell. Thankfully, it's all going to be under paint or copper by the time the boat's finished. And hopefully the second planking will be a bit neater - I feel like I've learned a lot already: Not least, that it's tough to resist that urge to push the planks sideways. Happy building! Rob
  9. Hi Eamonn, "loblolly" - thanks for the kind words... it's an encouragement as I set out. Time to get on with the build... Something a bit different after HMS Cottesmore I'll be posting all the photos of the build up here: https://www.flickr.com/photos/150573193@N04/albums/72157680568137234 And here's an overview. So far, I've made a building board, fitted the false keel and stem, and drilled mounting holes into the bottom of the keel. Then I fitted all but two of the frames. The ninth frame is supposed to be left off, but the first frame had been cut somewhat unevenly. JoTiKa are sending a new one through as we speak... A small amount of adjustment was needed on part 32, so that it could fit over the keel, but it was only about 2mm, and easily done with a file. Pleased with how it's going so far Take care Rob
  10. Hi, I'm just in the process of finishing up my previous build - a 1:48 model of a Hunt class Mine Counter-Measure Vessel, HMS Cottesmore, and I've got this kit in ready to build next. The hope is that it will give me the skills to finish off a Panart Royal Yacht Caroline that my late father started. Also, it looks like a really lovely kit. I'm not expecting to match the efforts of some of the other superb models of Pickle I've seen on this site, but hopefully I'll end up with something I can look at and enjoy I've received the kit, so watch this space for updates. And thanks for reading. A couple of 'what's in the box' shots attached. Rob
