robdurant
Everything posted by robdurant
  1. Brilliant stuff! Great to see you making such good progress.
  2. Looking great, Sal. Do think about access to the top of the rudder post once fitted, too. I cut an extra hatch in, which ends up hidden under the superstructure. It will allow you to attach the rudder horn (tiller effectively) easily when you get to that stage. You can see it at the stern in the photo attached... the hole is much more easily cut out before the false deckis attached, and you may decide to modify the frames around that part, too so that you get a good run for the arm between the rudder horn and the servo . I can't remember if I had to. Apologies if I'm teaching granny to suck eggs Rob
  3. A great start. You should be okay for vibration as the rpms should be farily low - it isn't a race boat - but if you want to be doubly cautious, making a part that sits inside bh6 that acts as a support for the prop tube could also damp any vibrations that might form?
  4. Great to see this log. All the best for your build nice hat, too. We live on top of a big hill, so in the middle of winter a hat like that can come in handy. I imagine on fishing grounds in the North Sea or Atlantic it would be essential wear.
  5. Wow, what a handsome model. I fear you are ahead of me and I will therefore be little help to you at this stage, but I wish you every success in finishing the task.
  6. Hi Morten, That's my log Chris has linked to above... sadly I had to pause the build having suffered a brain injury that put the mental requirements somewhat beyond my current abilities, but I still have all the plans (albeit packed away in the loft), and the model sat on my desk next to me. If I can be any help, I will gladly try. Am I right in thinking that you are looking for runs of rigging (i.e. which side of spars / other lines things pass), belaying point details, positions of yards when not carrying sails, etc? To my recollection I never really quite reached that point... indeed it was that task that I found most daunting in this model. As you'll see in the pictures on the log above, I placed the sails but they have no rigging attached, and there is no other running rigging at present. Ultimately, (and apologies if I get this wrong) as a minimum, I guess you want halyards to hold the yard up from the centre, braces for horizontal planar direction from the ends of the yards, and lifts for the vertical alignment going to the ends of the yards? The difference between rigged and unrigged is then that the yard is in its lowered position. The final part of the puzzle would be where to belay all of those lines... some through a block on the deck and then up to the centre pin rails (halyards?), some onto the belaying pins down the sides of the deck. Which side do they belay to? Is it higher yards further forward or aft? All of those would begin to make a plan of sorts.... and for the rest, well.... it's a collier trying to make a profit, not a royal navy vessel trying to pass inspection 😉 Rob
  7. Well I haven't stopped to write down much about the rigging, but there are far more capable modellers on this forum who have written excellent guides. I have, however, completed this model, which is something of a triumph! Just eight days short of a year since my journey with encephalitis began, to have recovered to the point where I was able to finish this model is both a personal win, and a great testament to the model that Vanguard Models have made here. Anyway - enough talk. Here are some pictures. I'm deeply grateful to all those who have been an encouragement and who have spurred me on through this build. And I'm thrilled with the results. I'm marking this one done Rob
  8. Thanks Andrew, I managed to get the other shroud on the mainmast done today, so things are really chugging along now Onto the mizzen shrouds next. Rob
  9. A belated happy Christmas and a very happy new year to you all! Some final details were added to the main mast. I put the mast hoops on and tied the sails to the yards before attaching them to the mast hoops in situ. Masking tape was used to ensure the mast hoops didn't move too far while they were attached. And a photo with the sails roughly in place... Progress has slowed significantly as I've retaught myself to do stays with rigging, dead-eyes, and lanyards, and attached the sails to the masts. I had to relearn how to tie ratlines (despite having tied in excess of three thousand of them previously!) - and I'm finally getting into the swing of things. I find that putting a lined sheet behind the ratlines (with the angle of the shrouds drawn onto it), helps in a number of ways. Firstly, it helps me to get the knots tied without the shrouds getting pulled gradually inwards by the knot tension (where they are, I can stretch it back out again as it goes). Secondly, when I thread the rope to make the knot, it gets pinched between the shroud and the paper, holding it in place while I move my fingers / tweezers to the other side. The only thing to watch out for is that you don't stick the ratlines to the paper when you glue them in place with watered down glue. Using only a little glue, and running a metal ruler between the shrouds and the paper shortly after gluing seem to keep this under control. Thanks as always for looking in. Progress may not be fast, but I'm happy enough with how it's going. And given how 2024 was, it's amazing I've achieved any of it, really. Every blessing for 2025! Rob
  10. I've finished shaping the masts and spars, fitted the bowsprit, and added all of the hardware... Next up comes the rigging in earnest In retrospect, I wish I'd used a round file to sand the inner edges of these small parts on the spars so they fitted up against the spar better when glued in place, rather than being a flat surface gluing onto a round one. I'm sure I used to know that - it just got lost somewhere along the line! Otherwise, I'm pleased with progress. Thanks as always for the likes and encouragement. I'm really beginning to think I can bring this build home, now Slow and steady! Rob
  11. Looking very smart. One tip I've found helpful in the past is to mask up the lines and then paint on some clear matt varnish. If this bleeds it doesn't matter. You can then paint the black over it, and it's less.likely to bleed as the gaps are already filled by the varnish. I've used this trick a few times and not had any issue. With that said, your tidying up efforts look very neat. Rob
  12. And... onto the masts. I haven't cut down the top of the mast yet, but couldn't resist seeing how it looked in situ.
  13. It's been a productive week. So here's an update. I've finished off all the deck furniture, and added the belaying pins (blackened photo-etch), and the chain plates... The chain plates were marked out from the plans using masking tape to protect the hull as I put pencil marks on to show where they should go. Once I was happy with the arrangement, I drilled a hole in each to locate the first pin, and then removed the masking tape. The remaining holes were drilled, and the provided pins were fixed in, having first blackened the heads. (It's worth noting that on the top holes of the forward and rear chainplates, the hole shouldn't end up sticking out on the far side of the bulwark. To avoid this, I shortened the pin before gluing it in place with a small dab of superglue. I've also dyed the sail set (these are the premium sails sold separately by Chris at Vanguard, and they really do add to the model). I used Rit dyes for this. About two pints of water were boiled in a big stainless steel pan, then having given it a few minutes to start cooling, I added two teaspoons of Rit Wine powder and Rit Dark Brown powder, half a teaspoon of salt, and a tiny dribble of washing up liquid. Having thoroughly stirred the mixture, the sails were added, ensuring they were completely submerged and wet through. About 30 seconds later, I took out the sails, and lay them out to remove the worst of the liquid. They were then placed on a cooling rack to dry off, turning occasionally. I was really pleased with how these turned out. When I build Lady Isabella (the Zulu from Vanguard's range), I felt the sails ended up a little light... this time, I've managed to get a deeper, richer colour. I'm almost onto the masts now, so soon I'll get the chance to see how they look on Erycina! Thanks for all the likes and encouragement Rob
  14. Hi, A little bit more progress. I've added the details to the companionway, and installed it in place. I've also constructed the main sheet housing assembly and the eyelets in the deck. I replaced the photo-etch for these with wire versions (which I had left over from previous builds), as they're more rounded, and I think I prefer the look overall. Whether you'd really ever notice the difference is another matter entirely, but I'll know A (very-zoomed-in) comparison of the wire and the photo-etch eyelets: And installed... I haven't currently glued the eyebolt holding the double-block in place as I wasn't sure how easy it would be to rig, and I wanted to keep the option open to get more access if I wanted it. It amazes me how much slower building is these days. When I built Lady Isabella, I was working six-day weeks and it took me four months. But progress is progress, and I'm enjoying building this model immensely! Thanks for looking in Rob
  15. An excellent rescue glad you're back on track. I haven't built this model, so I'm not much help I'm afraid. I guess a dry fit will tell you if it will all fit okay?
  16. Sadly it looks like you've planked the wrong side of one of those superstructure sides, and you now have two very neat starboard sides 😟 Even more distressing as you've done such a lovely job of it. I hope the solution proves simple.
  17. Hi all, The rope handles have been added to the hatches. A note for other builders here... and a reminder that no matter how good the kit, it's always worth reading ahead. The instructions tell you to glue the hatches down, and in the next step tell you to install the rope handles. Clearly, if you've already glued in the hatch covers, doing things in this order means you'll have no access to the bottom of the hatch covers to install the rope... SO... either don't glue the hatch covers in until after you've put on the rope handles, OR install the rope handles, and THEN glue the hatches onto the deck. Your money, your choice I chose the latter, because that way I could install the hatch covers first, and know that the loose ends of the 0.5mm thread weren't going to foul the hatch surrounds. It's a simple enough job, a little superglue was used firstly to make a hardened end to make threading it easier, and then to fasten the threads. No knots were necessary. On the removable hatch cover, the glue was added to the underside of the cover where the thread came through, and it was then clipped back flush to allow the hatch to be placed over the others. Now, an admission... I began to assemble the steps and got engrossed, and completely neglected to take an afterwards photo.... It went together quite neatly. Getting rid of the char on the steps and the uprights was a little fiddly, but nothing too bad. I painted the inside of the hole in the deck where the companionway sits black to stop the MDF and plywood showing, and installed the steps. A little sanding on each side of the steps made it a neat fit. As the instructions say - don't drop the steps into the hull! I'm glad I didn't have to find out _how_ irritating and time-consuming it would be to retrieve them. I completely understand the design intent of the companionways, but this is perhaps one of the few areas of the kit where I'm not a great fan of the look. The companionways in the kit have notched edges to aid in getting a neat lined up assembly - these are certainly helpful, but those tabs, (in my personal opinion) slightly spoil the look of the finished article... If you're painting these parts, it's a non-issue. And they don't look terrible... I'm just not a great fan. Here's the photo from the assembly manual - Again, in fairness to Chris and James, it's worth noting that these photos have the char left on - if you sand these edges back the notches will be far less noticeable. Don't take any of this as a complaint. It really isn't. This kit rocks! And as is always the case with a wooden boat model - if you don't like it, scratch build it however you like... the kit's just the starting point. So here's my effort... Pear left over from the planking was split down the middle, and then glued back together to make boards of ~2mm wide planks. The original parts were then used as templates to make full sides. Once cut and sanded to shape (leaving the spaces for the notches in place on the sides, and removing the notches on the front of the companionway), it was assembled. Using the original parts for the front (with the tables removed) and the top, it was all assembled. Thanks to the hatch top, the assembly was reasonably sturdy. Here's a shot before the bottom edge was tidied up... Overall, I'm happier with the look. Next up are hinges and handles, etc... No photos of that yet. Thanks for looking in. Rob
  18. Hope you're feeling better soon, Chris. It's draining coughing all the time. Amazing what's possible with 3d printing now. Those ship's boats look fantastic.
  19. A brief update today. I realised I hadn't put on the vessel name decals yesterday... so on they went. Photo etch for the pintles and gudgeons next... (blackened using IPA to clean, "Casey's brass black", and then water to rinse) And then it was time to focus on the deck a little... Scuttles were blackened and then added... Hatches assembled... I'll leave the hatch open a little to show off the extra detail that Chris has designed in for this hatch. These are still dry-fitted at the moment, and I shall add the rope handles before gluing in place. One of the other builds I read on this forum noted that the forward hatch is offset to starboard very slightly, so hopefully I'll remember that when I come to gluing it in place. It's shown on the plans - just easy to miss. And a few more parts - the base for the steam winch, and another part - these were blackened / painted, and then glued in place making sure to line them up carefully using appropriate sized rods where they need to line up with holes in the deck. And finally... the view from above. Thanks for all the encouragement. It's so encouraging to see things moving ahead so well now, and to be spurred on by the likes. As I've said many times already, this kit really is beautifully designed, and makes the task of building a real joy. It's nice to get to the stage where you see real progress each time you work on it. Rob
  20. Decals on... I used Microset and then Microsol to apply the decals. This allowed me to get them to really soften round the wood grain. Thankfully, the wood seemed to take this really well, and although you can see the wet look on the wood in the last photo (from applying the depth marks to the other side of the keel, this has now dried to the same colour as it was before. A quick point of note- when you're marking out where the depth markings go, don't forget that at least some of the sheet plans aren't 1:1 scale with the model... In fact, they're about 1.3x smaller - so do factor up your measurements before you mark out where the decals are going. This becomes important again when measuring up and making the spars (which, it's worth noting, have the correct measurements written next to them.) Thanks for looking in Rob
