In the course of Montanes construction for production of details I used  available for me jig saw (table saw) - self-made "minifactory" for thin laths and an interline interval, FET PROXXON for thickness to 20 mm and MJ10200J Feida for thickness to 40 mm). I have come to a conclusion about necessity of construction jig saw, deprived, whenever possible, lacks of the listed units (the design features sometimes essentially complicating operation; time and the efforts spent for maintenance of accuracy of a cutting; the big noise etc.). In particular, at FET saw a disk – tightening the screw constantly so gets jammed the extremely unsuccessful knot of fastening that I already two times had to cut off its head, differently a disk was not to remove (the same lack marked also others modellers).
Initial ideas of construction were:
- The basic range of a cutting – wood in the thickness from 0,5 to 20 mm;
- Accuracy of a cutting 0,1мм;
- A cutting under various corners;
- Table adjustment on height;
- Reliable knot of fastening  a cutting disk and simplicity of its replacement;
- The stock of capacity excluding (reducing) overheat of the engine at long work;
- Noise reduction.
As a result of viewing and the analysis of a considerable quantity of descriptions industrial and self-made jig saw at me the design shown on a photo  has turned out   http://modelshipworld.com/index.php?/topic/82-montanes-by-garward-occre/page-33.
Edited by Garward
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Jig Saw in work: cutting of levels 13 mm thick from wood of a black hornbeam for battle station Le Fleuron.
Best regards,
Garward
Continuation
Best regards,
Garward
The disk with a diameter of 100 mm with hard-alloy slips is used
Best regards,
Garward
Actually, this is a table saw. A jig saw is a hand held motorized saw to cut shapes. :)
Russ
Well, it is an example of use of the above described saw, anything essentially new.  :)
Best regards,
Garward
I understand what you meant, however, the title of the thread might mislead those who are expecting to see an actual jig saw rather than a table saw. :)
Russ
Edited by russ
Russ, You are right, but I didn't begin to change the name, on old MSW this subject was called as as JIG SAW. Tradition tribute...  :)
Best regards,
Garward
Garward,
  Now that is a nice setup you have. Thank you for showing this.
Many thanks for an assessment!  :)  :D
Best regards,
Garward
