Looks like you almost have a solid hull there! Good luck!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Looks good! Planking is definitely a learning experience! I just hope I do well when I get to it. I can only do 1 layer.
-Elijah
Current build(s):
Completed build(s):
Member of:
Hi Rainbow
Looks like you have a very good start. Planking is a learning thing. Different types of ships will be harder then others.
The most important thing I learned is the planks should lay down without much force. I use the same bending tool as use have. It works well for bending the wood for the hull. I also use a curling iron at times.
For your first build and the tools you have you are doing really great. I started out with a lot of wood experience, ( I built rc airplanes, and other wooden projects ) and had a boat load of tools ( power and hand tools )
You will get better, and it will be easier with every build.
Joe
A hand dremel maybe?
-Elijah
Current build(s):
Completed build(s):
Member of:
I have a disk sander from Micro Mark. It seems I use that more then any other tool. I set it up for " 0 " clearence. If you don't know what that is let me know I will send a pic.
Also I have a dremel, and a dremel drill stand that I use for drilling, but also set up for a milling machine. If you would like to see I can send a pic.
I think you will need some type of sander soon. Trying to do all that sanding by hand get old real fast.
I am following your build so let me know if I can be of help, or shoot me a message.
Joe
Hey Joe,
Yeah I think as well I'll need some sander soon since it's annoying and really slowly to do this manually (feasible but still...).
If you have such disk sander ->
I see it's application but for example how I'll sand the planking (or balsa wood below it if needed) with it? Can't really imagine that.
@Elijah - you mean hand dremel with some Sanding Disc/Sanding Band? That might be more useful I guess.
Or might continue with this haha :bird-vi:
Hi Rainbow
If you are talking about sanding the planks on the hull, then I think hand sanding is the best.
I was talking about sanding the planks before they are on the hull.
I use my sander for so many things.
Also the the size of the dish helps.
Mine is 10 inch so I have 5 inch of sanding area.
I use mine for making the masts and yards cone shape.
It is really fast.
I spin the yard with left hand, and a little pressure with the right
You can also see how small I can make things with zero clearence.
Joe
Rainbow
I have been looking over a build log that you might want to see.
He does a great job planking.
http://modelshipworld.com/index.php/topic/11130-hms-victory-by-seventynet-caldercraft-scale-1-72/
Also as to what you were talking about sanding, I found a page about using scrapers.
I have never tried this, but I may in the future.
http://modelshipworld.com/index.php/topic/10704-do-you-use-a-scraper-in-shaping-instead-of-sanding/page-1#entry323292
Joe
  • 2 months later...
  • 5 months later...
