Hello all,
Although only about half way through building my Pickle, thoughts naturally turn to the "what next" question.
For ages, I had always planned to build Badger as a seemingly natural progression from Pickle.
...and then I had a look at your Granado build - now that looks interesting!!
I checked out the build logs and manuals available at Caldercraft/Jotika - looks a lot harder than Pickle that's for sure....
So, should it be Badger or Granado?
Any comments welcome from anyone on here - but please -  not the "Oh, do both" one!!!!
I think it depends upon how much complexity you want. I haven't built Badger but it looks to be less complex than Granado. I'm obviously biased, but I think Granado builds into a beautiful vessel; I'd go with her. The Caldercraft kit is very nice, and can be made even better with a few modifications.
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
Hi Joe
Thanks for your response. I found your Build Log earlier and will be taking a good look there.
You mention modifications? Can I presume that your suggestions are found in your log?
One modification that I have made to my current Pickle build is the addition of furled sails - well they will be added once I get something built to attach them on - I'm getting towards finishing the deck furniture, so am already starting to work out the additional beley points etc.
I am getting hooked on Granado the more I look in to this, so I look forward to a 'cuppa tea' and a good read of your log!!
Regards
John
hi John,
Yes. The modifications that I made are fairly well spelled out in my log. You might want to look at Timmo's log as well for some good ideas. I "borrowed" a bit from him...
It's a very good kit right out of the box, with the biggest issue being the walnut second planking material was a bit splintery in my kit. I chose to replace with boxwood.
If you have any questions don't hesitate to ask.
Joe Volz
Current build:
Many thanks Joe.
Yes, I've also earmarked Timmo's log also.
Re the walnut planking - I used the same for Pickle. I seem to have been lucky as I had not one strip that caused problems.
With all my planking I used to put 1-2 strips in the sink - covered with lukewarm water for 15 minutes or so, then when I was ready, out came one strip, in with a new one and so on. This allowed to bend the wood without any problems, tools or clamps. I just used paper clips using the previous plank as support to clip the new plank to as I went along.
I will no doubt be in touch in future so thanks for the offer of help.
Just a little matter of finishing Pickle then - so this time next year I might be just about ready to go.
John
