Hi guys,
I’m a newbie here, and I come from Taiwan(not Thailand).
here I'd like to show you my little tips & tricks:
You can get the wooden Christmas card or any wooden book card:
to make carved doors or carved wall
And the lead ball is better then steel balls to simulating the cannonball ….
using syringe to control the flow of glue
May the force be with you.
Edited by thelastronald
the cheaper nail files (you can get them from the body shop)
Using the colored side to smooth small parts.
and the white side to buff to shine.
this oil painting is cutted from An art magazine
the picture frame is one of the construction model (21mm x11 mm)
Always measuring the size of kits by a human model:
We know the length of body in 1:50 scale is about 36mm, but it's hard to imagine,
such as Stair step height, the Size of a Table.. and so,
let's make a human model with the wood or paper on the cheap.
The plywood is cheap, but it can't touch water. There’s one safe way to Bend those kits made by Plywood:
using steam-bending.
1. put it into a food steamer
2. steam above water for 10 minutes
3. Bending the Curve.
4. When it cooling down, repeat all steps above until you finish it.
But if the thickness of plywood less than 4 mm, using an iron(put a wet cloth under it)
Bending the plywood while it is hot.
  • 2 years later...
