Does pre-staining wood with something like Minwax prior to assembly have any effect on the efficacy of normal wood (carpenter's) glue?
A wood dye should have no effect on a PVA bond.  A stain is a surface coat - similar to paint - it would depend on the specific product  - but there is a chance that a bond may fail because the stain seals the wood pores and blocks penetration of the glue polymers.
Your best bet is to do the experiment on scrap wood and determine the effect.  The stain manufacturer could have altered the formulation and if someone had an answer from years ago, it may not apply to your situation.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
My experience is that solvent based stains result in weaker joints over extended time. I have had great results using a water based with strong joints with both the PVA glues as well as super glue. Also a quicker assembly time due to quicker drying timers of the water based stains. Just my two cents.
Edited by xken
Ken
Current build: Maersk Detroit"
Future builds:  Mamoli HMS Victory 1:90
Completed builds: US Brig Niagara, Dirty Dozen, USS Constitution, 18th Century Armed Longboat
https://modelshipworld.com/index.php?/topic/11935-uss-constitution-by-xken-model-shipways-scale-1768/
