I know it's common to add a pencil (or whatever) line between the deck planks.  But what about the deck furniture?  Were they also caulked?  Was it just the roofs or the walls as well?
Derek
If you want to build a ship, don't drum up the men to gather wood, divide the work and give orders. Instead, teach them to yearn for the vast and endless sea
Antoine de Saint Exupery
Current Builds
Bluenose - Model Shipways - 1:64 Scale
Fair American - Model Shipways - 1:48 Scale
HMS Winchelsea 1764 - Group Build
On Deck
Guns of History Naval Smoothbore Deck Gun - 1:24 Scale
Finished Builds
Mare Nostrum - Artesania Latina - 1:35 Scale
Guns of History Carronade - Model Shipways - 1:24 Scale
Do you mean deck-houses by 'deck-furniture' ?
Deck-houses were normally built using carpentry 'tongue-and-feather' techniques, which make caulking unnecessary. This building technique is possible, because the differential movement of the parts is limited, so that no seams will open. Decks could be laid in the same way, but it is not (normally) done, because it would make it virtually impossible to replace single planks without ripping out the whole deck. This is not an issue for deck-houses.
Thanks Wefalck, that explains it perfectly.  And, yes, I did mean deck-houses.  Still getting to know the proper terms.
Derek
Current Builds
On Deck
Finished Builds
