Hello MSW
Before all, I really would like to thank everyone here , for all the help and guiding they provided to me , even without knowing that I do exist :)
Business has been going slowly in Egypt due to the ongoings , so , i decided to do something to spend quality time , and your site was very inspiring.
I did choose the Mare Nostrum to start with , build up my tools and learning how to go around things.
I got several pics to attach , though my camera is not of that high resolution as it should , but , it gives an idea about what has been going on
thanks alot again everybody in MSW again
Mohamad
and there's where I was few weeks back
Of course , I ran out of the Mahogany veneers , so i bought a sheet of the same color and used a surgical blade # 11 to cut the 5mm's
also bought a walnut wood and manged to come up with 4 , 5 , 6 X 1.5 mm sticks
and also missing a lot of the brass small pieces that didn't come with the kit , but , I'm managing
Mohamad, glad to see you start a build log. Your Mare looks very nice. Will follow your log with interest.
Regards,
John
<span style='font-family: courier new'>In progress: <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/177-king-of-the-mississippi-artesania-latina-scale-180/'>King of the Mississippi</a></span><br />
<br />
<span style='font-family: courier new'>Completed : <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/176-mare-nostrum-4331-artesania-latina-scale-135/'>Mare Nostrum 4331</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://modelshipworld.com/index.php?/gallery/album/51-16th-century-galeass-imai-scale-1160/'>16th century Galeass</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://members.upc.nl/carla.en.john/Modelbouw/Rocket.htm'>George Stephenson Rocket Locomotive</a></span><br />
<br />
<span style='font-family: courier new'>Next build : sl Louise</span>
Hello again MSW
here comes more of what i've been doing the past 2 weeks
the kit came missing several brass pieces , i had to do some , bought a 7mm brass rod and manages to do the rollers with a hand drill and a saw - cheated for a  lathe :)
about the wood work , all came out well , put the boxes were not accurate  +/- 1mm , they will look very naive
i think I'll redo them when i buy a sanding table
the pieces are still unfinished and need sanding for the glue remains
Hello again MSW
Mohamad, nice progress on this tiny stuff.
Regards,
John
<br />
<br />
thank you John and Brian
as for the boxes , they are not on the same length  ( the 29 mms ) and they will look like a mess when they are but together in place , but the sides are perpendicular , i used an aluminium L shaped angle to place the sides till the glue dries , and it worked just well
as for boxes support , I calculated it's height ( given that i'm using sticks that I milled 2 X 5 mm cross section to build the boxes )
8 boxes , the height of each box is 8 mm ( 2mm base thickness + 5 mm  sides + 1mm for box's grip )  it would give 64 mms in total for the boxes and i added and extra .5 cm on the top , and  but the number of horizontals , i worked on 3 mm vertical stick witha 3mm spacing in between .
and i'll cut the extra length from the bottom
as for the verticals ,  in the beginning i used 4 verticals (2 X 2 mm ) , but it felt so weak and very breakable , so i decided to support it with an extra  two 2 X 5 mm verticals
I think it all will come to shape when it's assembled
and about the plans , i'm not sticking to it down to the very mm of it , guess i have that since i was playing with  ( lego bricks ) back in the 60's :)
thank you for dropping by gentelmen & enjoy your build Brian
Mohamad
Hello Brian
things around here feels like loooong loong Mexican soap opera :) , but i'm progressing as well in my build ( slower than you ) , put following what's going on , actually I liked the idea of covering the plywood sides with a black pen !
The plinth is not in my kit , actually I got used to miss things on the kit , there lot of these 1 mm brass bars missing , I used 1 mm copper from an electricity wire to keep on going on ! missed the mahogany veneers , 5 mm walnut sticks , engine's internal chimney , the ladder sides , the wench brass handles and god knows what else.
i thought that this was only in my kit , but it's common
anyway , I really like your ship , it's becoming one of fine Mares in the forum
Regards
Hello MSW
Here goes that latest with my Mare Nostrum
I almost finished the wood work , the fittings and the coating
I also build a display stand
still have the rigging job that hopefully will be carried out later tomorrow
with all your building logs I could add no more , gratefully , thanks u all IN MSW for all the help you offered
Brian , if you meant by "plinth"  the horizontal bar over the mast , it must be there !
and also , the rack of the boxes turned out to be high , i had the take it out and reduce it's height , u were right
Will miss your comments Dear John
Mohamad
Thank you Brin fir your nice comments
about the brass parts , I have a friend who has a mini lathe , and he was kind enough to let me use it , and thank to your help and info I could get the parts in the right scale
and yes , i scrach built the capping peices on the side walls :) , i tried to bend the kit's original pieces , but i forgot them boiling untill the water dried out and tottaly burned
pinting the engine was an idea i got from john's build ( i beleive )
I got it all now rigged , but the Rope ladder's steps are not done so far , will post the pics as soon as possibe
I have a job now in hand , but as soon as I can , I'll scrach build ( el Nina ) , I have this thing with that ship
hopw all is well with you and all in MSW
Mohamad
  • 2 months later...
