Bounty is a very popular modeling subject, and a lot of kit manufacturers have offered a kit at one time or another. The contrasting wood colors on your model are typically what one sees in kits coming out of Spain, e.g. Artesania Latina, Constructo, or Dikar (now out of business). Any idea how old the model is?
Hi Ironmonkey and welcome!
Could also be the Amati one.
Size is an easy indication to go by, could you measure it?
The Artesania kit is larger than the others, just shy of 1m. The Amati and Constructo should be just above 70cm overall, with the Constructo one closer to 80cm.
Maybe someone who has the kits can recognise the brass castings in your last photo?
Edited by Sceatha
Good idea -- a shot from directly astern may be a give-away.
Now I'm thinking that this must surely be one of the older Spanish kits, e.g. Constructo.
The issue of a "minor repair" can be ticklish. Of course, it depends on how much work actually has to be done, but generally speaking repair work isn't cheap -- and that presupposes that you can actually find somebody willing and able to do the work. But if the model is otherwise in good shape, re-securing a few loose items, such as lines and blocks, may be something you could do yourself.
4 hours ago, Ironmonkey said:
Not sure
If those few bits at the stern are all that's loose, some of our champion rigger guys should be able to advise you. From here, the rest of the model looks to be in pretty good shape.
