This idea might have come up here before but I hope this helps someone.
There are always tedious little things to do in this hobby so when I come across an idea that can help speed things up it's worth sharing.
I am up to the stage in my build of rounding the bottom of the Balusters to 2mm dia (there are 34 to do) and the instructions says to round them with a file. Well...I found a small collet that comes with my Dremel and used that to round the Balusters. 👍
Edited by orion
That is a good idea especially since the collets come in different sizes.  Thanks for the tip.
Michael C. Warnick,
USAF SMSGT (Ret)
Current Build:  MS Fair American
Prior Builds:  AL Swift, AL San Francisco II, AL Mississippi
In the hanger:  MS Benjamin W. Latham
Are you using the collet as a rose cutter ? I wouldn't treat my collets like this ...
You can take a brass tube of suitable ID and file saw-tooth-like notches into the face. Depending on the wood you are working with, the cutter will need frequent sharpening.
