December 23: in mid-November, I started coughing, I think for the sawdust powder. that cough, I broke the ribs and I've been on bed rest until I started rehabilitation today.
and soon, when I have a little more mobility, we are acting up again.
until then: Merry Christmas and happy holidays to all.
Edited by cabrapente
April 7: Well here we are again. physiotherapist says that in two weeks, term rehabilitation.
when I had the accident, I did several things wrong: Cut pieces of frames too tight, and that allows few adjustments when sanding.
rode the town in record time, using only one arm, and inserting dowels between frames to give rigidity.
these tacos, squeezed to remove excess and tier ship once sanding, I encounter a big problem of destruction.
short: as I could, I removed almost all the frames, and I'm starting again.
Good work!
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
earlier, similar to buying a Proxxon, but the leaves are leaving with great ease and cost 18 euros.
Now I bought this in makro and it cost around 90 euros. with the advantage that it is much higher, and the production leaves me a man who makes them for professional carpenters.
cost between 7-10 euros, according to the paper.
I have removed some protections caps (which do not do that ...) and I get blocks cutting 10 cm.
I start with the interior
I start the beams of the first cover
to place the beams, I fabricated "Styrofoam" some beams, which intersect with the simplest to cuter, can be bent, and at one point becomes one test, which you copied in wood
