Not sure where I put this discussion. Please move if needed
I purchased MS 2020 Mayflower at 1:76 scale = 5/32" = .1563" = 3.969 mm
I purchased Bob Hunt's Mayflower practicum, without paying attention, which is for the Artesania Latina model, at 1:64 scale = 3/16" = .1875" = .4.763 mm
Comparing the two .1563/.1875 = .8336
If Bob says cut 5" do I cut 5"x.8336 = 4.168"?
Likewise if he says use 1/4" square board do I use 1/4" x .8336 = .2084"?
Using mm may be more precise but the question remains the same.
I know I should consult the plans first but if there is not a clear picture can I make the modifications as outlined above?
Or maybe I'm simplifying the calculations too much and the approach should be entirely different? I'm obviously not a mathematician!
Thanks for your help.
John
John Gilchrist
Yukon, OK
Current build: MS Emma C Berry
Completed: MS Fair American, MS Armed Virginia, MS Pride of Baltimore, Mississippi River Steamboat, Peterboro Canoe, MS USS Constitution, Mayflower, Billings African Queen
I would do it 64/76 = 0.84  but for what you want, it is the way that I would approach it.   Remember that this is 3D so  it is l x 0.84 and w x 0.84 and d x 0.84.
With a digital caliper, it should be no problem doing measurements.   It sure beats vernier or going blind using a 1/64" graduated ruler.
Now, the trick is getting stock to match.
Hello Jim Byrnes and if you do that, it is hello dark side (scratch).
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Jaager,
While the volume of the finished model will be smaller by the cube of the three scale factors, to build the model John only need to concern himself with linear ones, ie; multiply linear dimensions in the practium by .84.
Roger
Roger,
OK.
Not knowing what the practicum involves, I was thinking about the actual wood pieces.
NRG member 50 years
Current:
NMS
Other
Thanks guys.
John Gilchrist
Yukon, OK
