I've reached the rigging stage of the Syren, and am planning on serving the ropes.
Would the inner and outer martingale stays and back rope be served for their entire length?
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
I have read some different opinions on the efficacy of serving on wet ropes. One is that the service helps to keep the water out of the rope and the opposite, that the service tends to trap water in and hasten rot.  I suppose it would be  up to the Bo's'un which way to go here.  Martingale stays and back ropes get awfully wet.
The other thing to consider is the method of rigging the stays. Are they fixed lengths that are seized or shackled to the martingale, or do they run in one part through a hole.  If they run through a hole or a crook in the martingale then I would consider servicing a short length in the way of the martingale in order to reduce friction at that point.
Regards,
Henry
Laissez le bon temps rouler !
Thank you Henry, that makes a lot of sense! I believe on the Syren they are seized to the bottom of the martingale, so I may skip serving them. Thanks again!
Current:
Complete:
On the shelf:
