When building plastic model ships, what tools do you use to remove molded detail. I have been using a hobby knife, but I seem to leave a lot of scratches around the detail area. Somewhere I saw a chisel type tool that had rounded corners, but I can't seem to find it again.
Any ideas will be greatly appreciated.
Thanks,  Bill
I use an exacto knife and a variety of different blades. If there are any marks left over I buff them out with a super fine sanding stick or just some 1200 grit sand paper.
MicroMark sells several chisels with rounded corners. Or you can save a few bucks and round off the corners of some exacto-type chisel blades. And strop the edges. Post removal of the details, super fine grit to smooth the surface.
Ken
Started: MS Bounty Longboat,
