Hi Jon,
Regarding port holes, yeah, I was aware of it.  Actually, the whole thing looks to be proud of the hull surface, but only slightly - like a plate that is screwed to the outside. I just envisioned losing about 1/2 of them inside the hull if I did it the "correct" way and so I settled for what I did. If it ends up bothering me enough, I may file down the whole thing to about 1/2 thickness - we'll see.
I like what you did with the scuppers - I just didn't have the patience for it.  Mine, like the port holes are "too proud" of the surface.  There will be other things down the road that will require more patience and will be worth the kit bashing time for me to work out - like your canopy frames (great job!).
Thanks for the "likes" folks.  This weekend, I'll be putting more time into it, and will hopefully be timelier in posting to this build log🙄.
Midshipman 3/c (Ret.) Bob
Current Build:      Model Shipways USS Constitution
Previous Builds:  Model Shipways Lowell Grand Banks Dory
                               Model Shipways Norwegian Sailing Pram
                               Model Shipways 18th Century Long Boat
On 2/27/2025 at 12:20 AM, bthoe said:
Finally, I drilled holes for port lights and scuppers.
Here they are installed and the paint extended to below the waterline:
I used the MS scuppers rather than create my own, so they are closed, which is ok by me.  It just means that they aren't forced open by escaping water.
This gets me up to date.  Now I can figure out if I should:
             1.  Copper the bottom
             2.  Detail the outsides of Qtr Galleries and Stern
             3.  Add the head rails
             4.  Something Else?
For those of you who are beyond these, which did you choose, or which do you wish you would have done first?
Thanks,
Your progress is looking great! I’m looking forward to seeing more of your build!
My scuppers and portlights are a little to proud too on my build. After I had them painted, I came to the realization that I should have made my holes larger so they would sit flush to the hull. On my portlights, I filled the holes with Testors canopy glue. After it dries it’ll be completely clear and make them look like they all have windows in them. It just took a couple of days to be completely clear.IMG_8741.thumb.png.e334ee0b739f14784f1b1a6367208489.png
