The Robert E Peary is a WW2 Liberty Ship, she was built by Joshua Henry Ironworks of Sunnyvale California in 1940.
The story so far is;
 A late friend left me the Deans Marine kit “Robert E Peary” just be for went into the Hospice, Jack  had fitted the propshaft and rudder.
 The first things that I have to do is order a new set of drawings from Dean’s, make and relocate the rudder, the reason behind having to make a new rudder is that the rudder tube is missing and the rudder shaft is imperial, I could ask Ron to sell me a new one but as I have to wait for the new drawings I just as well make a new rudder form the stock that I have, I know that it will not be correct but in the end it will be made out of brass and not out of W/M and also I can just make it that bit bigger to help with the steering.
So on with the build.
Scale ; 1/96
Length ;  1384mm
Beam ; 185mm
Fred
Deans Marine   https://www.deansmarine.co.uk/
Nice to see another Lib Ship build.
Juuuuust in case, as you may already be aware there is another Dean's Robert E. Peary build log in progress here - look at page 3 of the 1901-Present Day kit builds and you will see it.
Good luck
Tim
Current build:  Syren
Past builds:    Continental Navy Frigate ALFRED (build log & Gallery)
                        Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         Lobster boat RED BARON (Build log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
I have now redrilled the rudder post hole, the one to the far right is the old one and the one to the left is the new one, I will be using Isopon P40 filler to fill the hole,
The motor mount has also been fitted and fixed with P40; I used clear silicone sealant to make the bed for the motor to sit on and a brass strip to fix the motor to the bed.
S7300319.JPG1.JPG.65557a346a128472e34b65f7d781eb7e.JPGS7300320.JPG1.JPG.87ea522cc04c8d8cbe9bb60a45d4a19e.JPG
In between doing this I cut out the ply subdeck’s, in the instructions it says to fix the deck support beams to the subdeck, now normally I would make a deck support frame and fix that to the hull, but as Jack would have followed the instructions I will also follow them.
S7300324.JPG1.JPG.fffc48b09b23602ae5030a9e623cfb5b.JPGS7300325.JPG1.JPG.8418db28a3bc86cd880808ca251e122d.JPG
I have also started to fix the deck to hull beams
This is were I am so far
Fred
