Bluenose by Fubarelf - Model Shipways - Scale 1:64
9 hours ago, GGibson said:
Great sail work, Tim!  and I love the rope coils next to the belaying pins! Sharp looking!
A question on your picture just before your "Finished Sail" text, the one with the single block right next to the fife rail.  Where is that rigging going up to on the mast?  Not seeing this in the Sheet 5 or Sheet 6 Rigging details, but am overlooking it, I am sure.
Thank you, Gregg. The blocks on either side of the fire rail are for the main throat and peak halliards.  They support the main gaff. Detail is on plan 6.
Tim
Link to comment
Share on other sites
Continuing on with the sail rigging...Fore sail and fore top sail next, starting from the bottom with the fore sail.  There are a lot of blocks and a fair amount of rigging required for the peak and throat halliards.  Need to pay close attention to the rigging plan on sheet 6 to make sure all the lines run to the correct pins.
I attached the fore boom and loosely rigged the sheet and topping lift so that they could be tightened up as needed once the sail was rigged and attached.
IMG_1745.jpeg.846d9050c5060b31424cafda3bb4e07d.jpegIMG_1744.jpeg.73c5bc83f4130da9249fa9dd0fff636d.jpeg
Once the boom was in place I added all of the ties for the mast hoops to the fore sail and lashed the top of the sail to the fore gaff.
I thought I had taken pictures of the completed peak halliard before I added the fore top sail but, did not have any when I went to edit the pics for posting.
Once I had the gaff rigged, I lashed the bottom of the sail to the boom and then snugged all of the lines up.
IMG_1760.jpeg.5fbe22ae5509027ed837b4ccc6b9262c.jpegIMG_1759.jpeg.205d2704a2827589659a51d2cd4b7418.jpegIMG_1761.jpeg.add92d3ede8ab2494d563e0a72de27fa.jpeg
The fore top sail was next.  I learned from the main top sail to attach all of the clew line fairleads and blocks, the rigging line and block and the mast hoop ties BEFORE attaching the sail to the mast.  So much easier to work with the sail off of the ship, duh!  Unfortunately, I forgot to take pictures of this interim step and only have a photo of the sail fully rigged.
Once again, very important to study the rigging plan, check and double check all the lines to make sure they are all routed appropriately and tied off to the correct pin prior to any permanant attachment.  I finished off all of the tie offs with rope coils.  While I was looking things over, I noticed that my main top sail and fore top sail were rigged on opposite sides of their associated peak halliards.  What I discovered is that I had placed the main top sail on the wrong side.  Both sails are set to the port side, but the bottom corner of the main top sail and tack line goes over the main gaff to the starboard side.  This is noted on the plans.
IMG_1777.jpeg.fcc0338dd169bdb3391c686f703894d4.jpegIMG_1778.jpeg.e5965d617ad2a371b12c01d9845bad63.jpeg
On to the stay sail...4 more to go!
Tim
Link to comment
Tim, that looks real good.
When I will be back at my Bluenose I will make her naked......😀, no sails as it takes away a lot of the nice rigging.
Respectfully
Link to comment
Thank you, Nirvana!  I considered that, but really like the look of the bluenose in full sail.  It is a lot of rigging, but I am enjoying the process and learning a ton to apply to future builds.
Tim
Edited by Fubarelf
Accidentally submitted before typing reply.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
