I'm about a third done with the first layer of POB planking on my Amati Fifie. It's going well so far, using full length planks with very little tapering. That of course will soon change though.
With that background, Amati supplied planks that are too short for the hull so for this first part have spliced lengths together for that full length. Since the soon and upcoming planks, things wont be so pretty with some expected gaps. Since this is a double planked hull, I'm trying to understand why some builds that I've seen, the builders are puttying/filling those gaps. Is that putty really needed beyond possible depressions? Then, since  this is an RC model it will be fiber glassed then painted for water proofing.
I have asked that question myself.  No answer yet.  Other than some compulsion against gaps between planks, I see no need for it either.
If there are hollows,  I think that scabbing actual wood veneer and paring that down would be better than any sort of Bondo or patching putty.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Still little (no) response to the question. Maybe because it's tradition that 'everyone' fills the gaps. Not really a big deal, just seems like a way to spend more time and materials for little or no return.
As far as depression filling. yes, that needs to be corrected. POB models with too few bulkheads seem to have an endemic problem with too much distance between them, allowing planks to sag. Filler blocks between them  first then a filler wood on top then sanded or otherwise fitted to proper dimensions/shape will work. I like balsa since it will form easily without distorting the planking but soft pine will also work if careful.
I agree that depressions should be filled, but that it would be far better to fill with wood than filler.  For my Triton, I filled the spaces between the bulkheads with basswood, but would use balsa wood if I had it to do over again.  Balsa is so much easier to sand/shape.
Alan
