Octagon 7 10 7 ratio calculator?
Go to solution Solved by Ryland Craze,
Anyone have a link to a calculator for marking the 710-7 ratio to turn square stock into an octagon?
The one I used in the past is a dead link
Thanks in advance.
Regards,
Glenn
Current Build: HM Flirt
  • Solution
Glenn,
I have attached a 7-10-7 Template PDF that may be of some help for you.
7-10-7.pdf
Also, check out this post.  I found it very helpful.  Dunbrody explains in detail how he makes masts out of square stock.
Ryland
               - Nautical Research Guild
