Bucasso Tool Storage
Go to solution Solved by Jaager,
  • Solution
I question if something that  ..... fixed .... specifically organized..?  would serve very well  with ship modeling - which has many varied stages - each with different tools.
I have had good luck   using project Styrofoam.
2 inches thick - about the size of a brick --  Home Depot sells smaller sheets of 1" project Styrofoam
It is porous -so PVA will bond two cut to size pieces  which is then glued to a 1/2" plywood base with a lip/porch on all 4 sides - a longer porch on one side makes for a handy stage for in-use tools.
Punch holes in the top of the foam using the tool handles and they standup - fixed - visible and ready to grab -  there can be a different brick for each type of work. Easy to move and store.
PVA will not melt it - most plastic glues will - a hot glue gun was a disaster -  PVA does not work with most plastic but most plastic is not full of tiny holes.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
I looked again -  and brick is a bit small
4"x11"   6"x9    pick a size and hope it matches your need .
I also made a smaller "table"  with a 1" foam top.  I made holes in it to hold my carving chisels - the height set to keep the tips hanging suspended, but the base is a layer of foam "just in case" it is not high enough.  The suspension keeps the blades in view so I can see which is which - side slots hold my scrapers - you want a set of small size luthier's scrapers -  shop - boy is there a wide range of prices  for a set like this:
Peachtree's $25 does not seem that bad.
NRG member 50 years
Current:
NMS
Other
